Post 456663 by JUDGENINJA on 2012-01-30 00:28:47
I know I could go to Volvo to Plug in my chassis number, but I was looking on euro car parts at pattern parts.
They list a SKF, orbis or SNR any ideas?
I'm guessing that SKF and Orbis are just different manufacturer.
The SNR does look odd with a bolt holding the driveshaft(??).
Anyway if anyone has a bit of identification advice I will be getting one tomorrow as the new wishbones have highlighted that the front hub was seriously loose in two areas..
Post 456664 by JUDGENINJA on 2012-01-30 00:42:13
Ah figured it out.. The c70 1998 seems
To have a later driveshaft..
Post 456665 by deathrider311271 on 2012-01-30 00:44:12
if yours is a ME7 car it should have a bolt holding the driveshaft as apposed to a large nut
Simon
Post 456666 by Volvostorm on 2012-01-30 00:46:28
97 cars, I'm fairly certain use the 850 type wheel bearing.
Your CV joint shold be held on with a nut, the later (late 99>) used a bolt
I'm guessin'g that SKF and Orbis are just different manufacturer.'
Yeah, they are, never heard of Orbis, I'd go with SKF, very good make.
