Post 456787 by Dan850r on 2012-01-30 17:34:09
The carbon trim looks pretty good and get some blank trims to go under the headlights
Post 456832 by I want a T5 on 2012-01-30 18:14:12
I like the CF wrapped side trims.......thinking of doing this on my silver V70. Dod you take the trim pieces off to wrap? If so, how do they come off?
Post 456842 by Peanut1 on 2012-01-30 18:31:12
mate, if you take em off you will have a mare putting them back on as their seriously stuck on! think you would end up doing em in situ!
Post 456846 by Dan850r on 2012-01-30 18:35:45
There not to bad, pop it off at the front and they slide back leaving the clips on the door, of vice versa, ill go have a look!
Post 456851 by Dan850r on 2012-01-30 18:39:47
No unclip at back and push forward
Post 456887 by t5steve on 2012-01-30 19:02:41
thanks for that info dan i have been wanting to remove mine to paint them for some time but didn't want to pull them in case i broke clips................game on now...........thanks
Post 456900 by endo-t5 on 2012-01-30 19:10:05
There's a rubber plug in the back of the door and it's got a torx screw in but use a magnet as they are a pain if u drop them and then they slide forward the wing ones pop off just open the doors slightly for the door trims to slide them forward.
I took mine off to do them as will be a pain if you try to wrap them on the car.
Post 457759 by endo-t5 on 2012-02-01 17:59:54
Got some new shocks/dampers and some h&r springs and new top mounts for the rear and new spring top mounts for front struts. Getting those nivomats off the rear at long last.
Did start it today but with disc in back is gone takes it toll on me and had to give up I'll wait till another day when it's not so cold and when I'm up to it plus think I'll wait till the missus is off at a weekend to give me a hand.
Post 461960 by endo-t5 on 2012-02-12 09:43:12
Stripped bumpers of the colour coding so their now grey again just got to do door strips now.
Fitted DVD headunit that I got cheap of a mate so when I go to a show and get bored or tired got something to do.
Post 461964 by Bigrobv70 on 2012-02-12 10:16:08
looks sweet
i like alot
Rob
Post 461973 by claymore on 2012-02-12 10:38:17
Looks good, but needs hitting with a stick
Post 464619 by endo-t5 on 2012-02-19 15:40:47
Soldered the abs ecu this morning when I had a night when I couldn't sleep so 4-30 am soldering and fitted back on and seems to work fine now.
Took recirculating valve off to find that the seal had twisted inside out so made a plate and blanked it off as had some 5mm alloy plate in the garage.
Post 465037 by endo-t5 on 2012-02-20 16:18:55
Finally fitted suspension
Big difference in new vs old springs
I'll take some of how it sits once it's settled and when I've cleaned it as its rotten.
Post 468420 by martybelfastt5 on 2012-02-29 21:29:33
looking good indeed suits the drop
Post 468436 by Volvostorm on 2012-02-29 21:45:32
Really nice look car, subtle mods :)
Post 468449 by endo-t5 on 2012-02-29 21:55:38
Thanks guys I'm happy with it now but I would of liked it a little lower but it handles well now and the suspension is so much better than the Nivomats that was on the rear.
think I need to do a new list as think poly bushes, 302 brakes, remap, maybe a bigger turbo when funds allow.
Post 480822 by endo-t5 on 2012-04-03 15:30:31
Tried something new.
Standard handle
Carbon wrapped
Post 526529 by endo-t5 on 2012-07-22 20:22:14
Been to a classic car show today and took pic of my car outside the castle
Post 526558 by V70 Graham on 2012-07-22 21:13:30
A nice old ruin......the castle's not bad either :haha:
Post 542497 by endo-t5 on 2012-10-17 18:34:12
Finally got new cv fitted today. Had to take hub off and mount in the vice and hit the cv joint for 20 minutes before it would move even soaked in oil for 2 hours but brand new cv joint fitted now. Going to fit new one to other side so more swearing to come.
Post 542508 by ajc106 on 2012-10-17 20:16:34
hi mods look good would like to know did the speakers fit straight into the door or did you have to do some cutting to make them fit also do the speaker grills still fit as i like to keep it looking standard thanks ps what is the code for the rear speakers thanks
Post 587948 by endo-t5 on 2013-03-23 22:57:45
Changed the alloys to another set of 18's. black Ronals
Also fitted poly bust to top engine mount as only had it for 12 months and fitted the subframe inserts and also put new steering rack on which took a while but nice and light now.
Just need to do some more poly bushing and get a new clutch but not sure what clutch is best or where to get it from.
Post 588048 by nottsgreent5 on 2013-03-24 09:27:27
Marshalls in notts do genuine 850R clutch kits for around 200 quid which i thought was cheap compared to ebay and most auto factors
Post 636161 by t5 pete on 2013-08-16 22:51:38
Nice update how you finding it with the new turbo
Post 636168 by endo-t5 on 2013-08-16 22:59:34
It's pulling much better now and sounds completely different and taking it easy at moment as not had great luck lately.
Need to get a remap as got a few mods done now and have some injectors to fit too.
