Inner Arch Studs P1 V70
Post 457281 by daza-b on 2012-01-31 17:08:59
Hiya guys, are the inner arch studs (the ones that connect the mud flaps, bumper and wing) re usable? if not where can i get new ones? if they are, how do you get them off? i cannot seem to be able to take them off without drilling, are they pop rivets? thanks in advance :)
Post 457284 by M-R-P on 2012-01-31 17:17:56
Are they a black plastic disk with what looks like a stud, ground flush with the centre? if so, poke the stud through and lever the disk out. it'll be a reusable spreader thingy (if it's what I think it is :))
Post 457285 by daza-b on 2012-01-31 17:18:49
[quote=martinrpeachey;457284]Are they a black plastic disk with what looks like a stud, ground flush with the centre? if so, poke the stud through and lever the disk out. it'll be a reusable spreader thingy (if it's what I think it is :))[/quote] no thats what i thought they were at 1st, they are like a metal peg...look like a rivet maybe?
Post 457287 by M-R-P on 2012-01-31 17:21:30
Oh, just drill it out and get some pop rivets with an extra wide skirt to re-fit ;)
Post 457291 by daza-b on 2012-01-31 17:29:23
they look like this at the front: Image and this at the back Image
Post 457296 by M-R-P on 2012-01-31 17:36:45
aaah, you might be able to press the center pin right through the rivet (front to back) and squeeze the barbs back in. Then just poke the pins back in (front to back) to re fit. Personally, I'd drill the bugger and bung rivets in it :)
Post 457297 by M-R-P on 2012-01-31 17:38:08
When my local indy did my timing belt (for a very good price, I might add) they drilled the rivets and used self-tappers to re-fit ???wtf!
Post 457298 by daza-b on 2012-01-31 17:38:37
lol just im fitting a wing onto foammanmarks t5 and needed to figure out what i needed to put it back together, just i have never seen anything like these before lol
Post 457311 by daza-b on 2012-01-31 18:00:10
can anyone suggest the tool and rivets i will need for this job? thanks
Post 457340 by foammanmark on 2012-01-31 18:48:12
[quote=daza-b;457298]lol just im fitting a wing onto foammanmarks t5 and needed to figure out what i needed to put it back together, just i have never seen anything like these before lol[/quote] Careful with my new wing please mate!!
Post 457420 by daza-b on 2012-01-31 19:56:46
[quote=foammanmark;457340]Careful with my new wing please mate!![/quote] always am lol
Post 457425 by foammanmark on 2012-01-31 19:59:42
[quote=daza-b;457420]always am lol[/quote] I know mate, I'm only messing. Used the T5 this morning for some local calls, and the leather seats are just fantastic. That was a great purchase thanks!
Post 457466 by daza-b on 2012-01-31 20:33:51
[quote=foammanmark;457425]I know mate, I'm only messing. Used the T5 this morning for some local calls, and the leather seats are just fantastic. That was a great purchase thanks![/quote] pleasure as always :)
Post 457468 by M-R-P on 2012-01-31 20:36:26
[quote=daza-b;457311]can anyone suggest the tool and rivets i will need for this job? thanks[/quote] Cordless drill, 4mm bit and a selection of wide skirt rivets (can send you some if you like ;)) That's for the MRP Cowboy method of removal and refitting :)
Post 457471 by daza-b on 2012-01-31 20:37:58
lol sounds like a plan there bud, where can i buy them from? also what tool will i need to fit them? just i have the wing to fit and also have my bumpers to fit etc etc lol
Post 457545 by M-R-P on 2012-01-31 21:23:28
[quote=daza-b;457471]lol sounds like a plan there bud, where can i buy them from? also what tool will i need to fit them? just i have the wing to fit and also have my bumpers to fit etc etc lol[/quote] I can bung you a load of rivets and backing washers (just to make sure) any pop rivet gun will do. ;)
Post 457548 by daza-b on 2012-01-31 21:25:59
[quote=martinrpeachey;457545]I can bung you a load of rivets and backing washers (just to make sure) any pop rivet gun will do. ;)[/quote] really appreciate that bud :) this one do? http://www.ebay.co.uk/itm/POP-RIVET-GUN-60-RIVETS-AND-NOZZLES-4-DIFFERENT-SIZE-RIVETS-INCLUDED-/170774873319?pt=UK_Hand_Tools_Equipment&hash=item27c2f9c4e7#ht_2766wt_952
Post 457571 by M-R-P on 2012-01-31 21:48:52
That would work but would be hard work, this one would be nice 'n' easy ;)... http://www.ebay.co.uk/itm/HEAVY-DUTY-LAZY-TONG-HAND-RIVETER-RIVET-GUN-POP-RIVETER-/270669622993?pt=UK_Hand_Tools_Equipment&hash=item3f052aaed1
Post 457577 by daza-b on 2012-01-31 21:59:44
nice one bud, will just have to learn how to use it lol
Post 457584 by M-R-P on 2012-01-31 22:06:20
Really? I'll send you a vid if needed lol :) PM me your address and I'll get the rivets sent out. Might be best to drill one of the rivets out of the wing you have and measure the hole. Don't wanna buy a revet gun, only to find that you need 10mm or something :(
Post 457799 by foammanmark on 2012-02-01 18:58:09
[quote=martinrpeachey;457545]I can bung you a load of rivets and backing washers (just to make sure) any pop rivet gun will do. ;)[/quote] Thanks very much Martin, seeing as they're for my wing!!
Post 457801 by foammanmark on 2012-02-01 19:00:00
[quote=daza-b;457548]really appreciate that bud :) this one do? http://www.ebay.co.uk/itm/POP-RIVET-GUN-60-RIVETS-AND-NOZZLES-4-DIFFERENT-SIZE-RIVETS-INCLUDED-/170774873319?pt=UK_Hand_Tools_Equipment&hash=item27c2f9c4e7#ht_2766wt_952[/quote] Mate, I have a pop rivet gun that I bought to fit my mudflaps on the D5. Also, loads of different sized rivets.
