Post 457490 by stribo on 2012-01-31 20:51:42
These arrived today:
Eibach lowering springs.:biggrin::biggrin:
The guy I bought them off Ebay from has been really helpful, and has said to give him a shout if I need any advice fitting them, just wondered if anyone had done a how to for fitting them?
Post 457492 by AndysR on 2012-01-31 20:53:34
Nice, Eibach? Get some shots of the finished product when your done :)
Post 457507 by M-R-P on 2012-01-31 21:01:36
It's not too hard mate, Haynes will show you how to change the shock, just change the spring instead ;)
Took under 20 mins to get the springs off mine (yours has 4-C doesn't it? may take a bit longer disconnecting a few more wires)
Post 457514 by rikcougar on 2012-01-31 21:04:05
Nice Steve, how much do they lower?
Post 457519 by stribo on 2012-01-31 21:06:29
Cool thanks, didn't even think to look for a Haynes manual :rolleyes: yeah, it's got 4C, I've been warn one plug is really hard to get out.
Post 457522 by stribo on 2012-01-31 21:07:41
[quote=rikcougar;457514]Nice Steve, how much do they lower?[/quote]
About 30mm I believe, still got some -40mm springs to fit to the Cougar, looks like I'm going to be busy. :bullwhip:
Post 457526 by M-R-P on 2012-01-31 21:09:29
[quote=stribo;457519]Cool thanks, didn't even think to look for a Haynes manual :rolleyes: yeah, it's got 4C, I've been warn one plug is really hard to get out.[/quote]
There's a great tool for disconnecting those pesky cables...
http://www.screwfix.com/p/cable-cutters-254mm/47997
Post 457528 by rikcougar on 2012-01-31 21:10:41
Mate, you don`t have enough time to keep on top of the Cougar, how are you going to manage two, Rachel will never see you
Post 457530 by stribo on 2012-01-31 21:11:37
[quote=martinrpeachey;457526]There's a great tool for disconnecting those pesky cables...
http://www.screwfix.com/p/cable-cutters-254mm/47997[/quote]
I'm hoping it won't come to that. :eek:
Post 457532 by stribo on 2012-01-31 21:12:25
[quote=rikcougar;457528]Mate, you don`t have enough time to keep on top of the Cougar, how are you going to manage two, Rachel will never see you[/quote]
I kept on top of 2 Cougars (just). Will be better once the weather gets a bit warmer.
Post 457616 by s_cowen on 2012-01-31 22:51:02
Nice! Got mine fitted a couple of moths back & it made a big differance really firmed the car up & stopped it rolling about through the twistys & the steering is alot sharper now. Make sure to get a before & after shot & get it posted.
Post 457635 by t5_monkey on 2012-01-31 23:26:36
Get it polybushed! and the IPD rear roll bar.
Post 457661 by stribo on 2012-02-01 07:11:58
[quote=t5_monkey;457635]Get it polybushed! and the IPD rear roll bar.[/quote]
Is the rear anti roll bar on the R the same as the other models?
