Post 458741 by d2k on 2012-02-03 14:42:57
hi all........ need help urgently!!
just had my mechanic out today fixing my boot lid catch, & my ''check brake bulb'' warning..... boot is fixed but he CANNOT locate this stupid bulb warning.
all bulbs are functioning as they should..???, what can this be if not a bulb issue, im due for MOT next week & i want this silly little problem GONE!!, he says it wont fail but knowing my luck it will.:mad:
is there something else i should be looking at here....
good news is the car is ALL CLEAR on the OBD DTC check, i was expecting a few codes to pop up but she's completely clear
please help me get rid of this niggling problem...
Post 458747 by M-R-P on 2012-02-03 14:54:08
That pops up on mine sometimes, I just thump the rear light clusters a few times and it goes away. Ford electrica! D'oh!
Post 458749 by d2k on 2012-02-03 15:11:50
lol.... i tried the ''if in doubt give it a clout'' method, no change.
its gotta be one of the rear running lights b/c when the engine is running with NO lights on there's no warnings.
but
switch on running lights & i get ''parking bulb failure'' on the DIM
turn off running lights & warning vanishes
but, if i depress the brake pedal at any time with lights on or off & i get ''check brake light'' pop up on the DIM..????????????
is this warning an MOT fail.....
Post 458750 by Al115 on 2012-02-03 15:15:12
Could it be one of the LEDs in the high-level brake light? Rare but not impossible.
Post 458752 by d2k on 2012-02-03 15:18:12
[quote=Al115;458750]Could it be one of the LEDs in the high-level brake light? Rare but not impossible.[/quote]
the mechanic thought that but we checked & they all light up (as far as we can tell), dont suppose theirs anyway i can disable this warning function.. fuse maybe..??
Post 458764 by Al115 on 2012-02-03 16:03:31
[quote=d2k;458752]dont suppose theirs anyway i can disable this warning function.. fuse maybe..??[/quote]
Obviously not or it wouldn't be a Volvo!
Strange that it's logged no DTCs. Are you using a proper fault code reader for the newer cars - one that can read all the Volvo-specific DTCs, not a generic OBDII one?
Post 458841 by d2k on 2012-02-03 19:44:23
[quote=Al115;458764]Obviously not or it wouldn't be a Volvo!
Strange that it's logged no DTCs. Are you using a proper fault code reader for the newer cars - one that can read all the Volvo-specific DTCs, not a generic OBDII one?[/quote]
not sure what unit it was, it was massive ..held with two hands like a laptop without the lid... not like these code readers i see on ebay, he did say to me it was pretty likely it wouldn't read it
but
i had a little look at it when he was working on the car....it was 100% working after a few seconds a list popped up... all temps, oil / coolant / RPM /airflow all in realtime.... he said ''success'' so i knew it was working & had full access to all ECU's
he came over scrolled to ''CHECK DTC LIST'', the progress bar came up (held my breath) to my amazement it finished & confirmed no active codes.
im heading to volvo after the MOT for a software update (£60) i'll find out for sure then.
Post 459126 by d2k on 2012-02-04 16:04:22
right........ i went to the local motor store today & bought a new replacement bulb for everything in the rear clusters, loads of em.
the new ones were actually far brighter than the ones in there which game me hope...
turn on the lights.....''parking bulb failure'' !!WTF!!, every bulb has been changed.. only thing left is the high lvl bulb, or worst case hardware failure.
does anyone know if this bulb warning is an MOT fail even if all bulbs function..??
Post 459133 by M-R-P on 2012-02-04 16:18:03
It shouldn't be an mot fail as all the lights are working. Might be forth taking some boot lining out and having a look for a loose connection or frayed wire somewhere.
Post 459142 by Al115 on 2012-02-04 16:30:49
Check the wire in the hinge. I put a thread up about it a month ago or so.
Post 459169 by TheT6Kid on 2012-02-04 18:04:16
When you changed the bulbs did you take a look in the bulb holders and check for any corrosion (white furry terminals) if it wasn't making full contact this may casue you issues? I also think the number plate illumination bulbs are part of this circuit?
Post 459170 by TheT6Kid on 2012-02-04 18:06:08
If the bulb works it shouldn't fail the MOT.
Post 459185 by d2k on 2012-02-04 18:34:39
thanks all........
i changed the plate bulbs too.. they work well, checked the wiring for the boot b/c my mechanic fitted me a new boot catch the other day so the trim was stripped right back.
the metal contacts were actually white where they touch... i'll give them a clean with some wire wool.
seeing that warning triangle on my dash is starting to grate on me!!
see what they say on Monday.
Post 459188 by Wobbly Dave on 2012-02-04 18:35:47
Where did you get the pro scan from?
Post 459222 by Bigrobv70 on 2012-02-04 19:17:56
[quote=d2k;459185]
the metal contacts were actually white where they touch... i'll give them a clean with some wire wool.[/quote]
that corrosion will give the bulb contacts a high resistance
thats normally what a bulb warning system uses to check the lights
fair chance thats your problem
Rob
