tyres filled with nitrogen
Post 459071 by graemewelch on 2012-02-04 12:34:43
any one filled theres with the above. im thinking about doing mine. what the advantages of it. it wont cost me. i build and service cryogenic vessels for a living so i have unlimbited amout of nitrogen gas and liquid
Post 459076 by T5RPete on 2012-02-04 12:48:43
I know they use it in the Nissan GTR cos Nitrogen doesn't expand or contract with heat like air does. Something like that anyway. Would you notice a difference in normal everyday driving? I doubt it...
Post 459077 by jayeastanglia on 2012-02-04 12:49:57
nitrogen molecules are bigger than normal air so the therory is the notrogen doesnt escape through the rubber as quickly as normal air so tyre pressure stays constant also its not meant to expand as much when a tyre heats up..
Post 459099 by martybelfastt5 on 2012-02-04 14:40:54
barryloney has this done on his 93 if im not mistaken,
Post 459107 by Wobbly Dave on 2012-02-04 14:52:59
[quote=jayeastanglia;459077]nitrogen molecules are bigger than normal air so the therory is the notrogen doesnt escape through the rubber as quickly as normal air so tyre pressure stays constant also its not meant to expand as much when a tyre heats up..[/quote] ahem, Normal air is 80% nitrogen - so that's a load of bumkum. The only reason for filling tyres with compressed nitrogen is to remove the water vapour. That's why they do it on aircraft - as the water would condense & freeze at 30,000 ft (as it is 50 below outside). The rapid defrosting & expansion could lead fatigue damage the rubber/tyre structure & could lead to a catastrophic failure when the tyre suddenly warms up on contact with the runway. I fail to see how that might apply to a road car. It is used in F1 but these are also extreme conditions.
Post 459110 by claymore on 2012-02-04 14:59:39
[quote=Wobbly Dave;459107]ahem, Normal air is 80% nitrogen - so that's a load of bumkum. The only reason for filling tyres with compressed nitrogen is to remove the water vapour. That's why they do it on aircraft - as the water would condense & freeze at 30,000 ft (as it is 50 below outside). The rapid defrosting & expansion could lead fatigue damage the rubber/tyre structure & could lead to a catastrophic failure when the tyre suddenly warms up on contact with the runway. I fail to see how that might apply to a road car. It is used in F1 but these are also extreme conditions.[/quote] http://www.popularmechanics.com/cars/how-to/repair-questions/4302788
Post 459116 by Wobbly Dave on 2012-02-04 15:10:07
Perhaps the effusion of Nitrogen is slightly less than compressed air. But unless it is free - I will stick with compressed air http://www.getnitrogen.org/pdf/graham.pdf Unless the nitrogen is properly scrubbed to remove the water vapour advantages will be negliable. What Jay said is still wrong - there is no such thing as an air molecule. Air is a mixture of gases & water vapour - it is not a compound in its own right.
Post 459120 by graemewelch on 2012-02-04 15:36:54
Post 459140 by Santa on 2012-02-04 16:28:24
[quote=graemewelch;459120]any one filled theres with the above. im thinking about doing mine. what the advantages of it. it wont cost me. i build and service cryogenic vessels for a living so i have unlimbited amout of nitrogen gas and liquid[/quote] I used to have it done, the advantage was the pressure stayed pretty much consistent no matter how hot or cold until I have the tyres changed.
Post 459152 by graemewelch on 2012-02-04 17:10:38
did you notice any difference when driving. ill prob wait till i fit my summer tyres
Post 459177 by Wobbly Dave on 2012-02-04 18:18:43
this is a duplicate thread.
Post 459232 by jayeastanglia on 2012-02-04 19:39:12
was just going by the ****s at crap fit try and con us into getting it in the tyres at work.. sorry for anyone working in our local one but they are really useless
Post 459249 by Santa on 2012-02-04 20:04:08
That it is. Probably needs merging............I will see if I cba :-)
