Post 459181 by KARL on 2012-02-04 18:33:24
My trusty 1995 855 T5 !
Tried to start her this morning in the cold weather were experiancing.She tried to fire, but then went into a fast/er idle ! So I Quited doing anymore !
I took of the cam cover off, as I thought it was a belt !
All belts are fine though.
Cranked her again and she started, but ran for 5 sec`s at 800 RPM, I reckon at full Throttle!
Fuel pump maybe !!!
Can I ask you guys to help, as you always have, on VPCUK.
She an old bird of a motor, but good.Got it, as to preserve my 1998 V70R AWD
Regards
Karl
Post 459235 by jayeastanglia on 2012-02-04 19:43:14
dizzy cap may be damp inside or plugs old and knackered..
Post 459384 by KARL on 2012-02-04 23:31:03
Plugs were good but oil was low !
Batt has some kick, but must take cap of as you mentioned !
Will try tomorrow now.
Cheers sir
Karl
Post 459386 by Niles on 2012-02-04 23:43:21
check the operation of the little link arm between the throttle body and the cables drum linkage.
Post 459402 by KARL on 2012-02-05 00:58:16
[quote=Niles;459386]check the operation of the little link arm between the throttle body and the cables drum linkage.[/quote]
Thats all fine.Watching it work with covers of if I understand you !
Many Thanks. I will be back on it tomorrow !
Cheers Again.
Post 459710 by stevie69 on 2012-02-05 21:10:15
fuel pump relay.mine done it the other day.underneath the fuses.the one in the middle.bridge it with a bit wire...
Post 464323 by KARL on 2012-02-18 18:05:47
Chucked some more oil in, cranked her with king lead off for a bit.
Checked all leads, dizzy cap, maf leads !
Connected it all back, then cranked here again.After sometime it started !
Went for a drive, but when you hit the throttle, there is a half second delay (maybe less ) before it revs, from a tick over state ?
Gets better once warm !
Could this be something failing soon ?
Cheers
Post 464383 by woz on 2012-02-18 19:22:49
Is she old enough to have the original Volvo RIP fitted as standard?
They were allegedly prone to icing which would give simiar symptoms, but surely not on start up.??
Gotta love these old birds.
Went to Ikea today in my ' 96 855 - an oven, hob, sink, some units and Mrs Woz all jam packed in and she still pulled like a train. (Had to go back for the three worktops though or make Mrs W walk home :>(
btw the car is the old bird not Mrs W who may be reading this. Obviously!
Woz
Post 464384 by woz on 2012-02-18 19:25:05
It "could " be a MAF sensor - try disconnecting it see if tmakes any difference. when mine went it just would not go above 3000 rpm or light throttle making driving not as much fun as usual.
Ran better with the thing disconnected until the new one arrived.
W
Post 464587 by manback on 2012-02-19 12:43:15
i had a non turbo 850 with similar problems. never did find out if it was the oil breathers blocked up somwhere or EGR system? not sure that exists on the t5's
