How to open up the ECU cover??
Post 462588 by daza-b on 2012-02-13 14:26:03
Hiya guys how the heck do you open up the ecu cover on a P1 V70? doing my nut in now lol and getting to the part where im gonna end up snapping it, thanks in advance :)
Post 462589 by Wobbly Dave on 2012-02-13 14:28:53
Use a long thin flat screwdriver to lift/prize off the metal clips under the lip formed at the top of the large black box. One is by the inner wing & the other opposite the PAS pump wheel.
Post 462590 by Kingsford G on 2012-02-13 14:31:24
[quote=Wobbly Dave;462589]Use a long thin flat screwdriver to lift/prize of the metal clips under the lip formed at the top of the large black box. One is by the inner wing & the other opposite the PAS pump wheel.[/quote] Yep,do the inner one first and hold it up and then the outer one.
Post 462591 by Wobbly Dave on 2012-02-13 14:39:44
Forgot to say - you will also need to remove the plastic cooler hose from the front of the lid.
Post 462595 by daza-b on 2012-02-13 14:57:44
[quote=Wobbly Dave;462589]Use a long thin flat screwdriver to lift/prize off the metal clips under the lip formed at the top of the large black box. One is by the inner wing & the other opposite the PAS pump wheel.[/quote] what about that stupid black metal strap that goes around it?
Post 462597 by M-R-P on 2012-02-13 15:07:31
Angle grinder - Pedro style ;)
Post 462598 by daza-b on 2012-02-13 15:08:54
[quote=martinrpeachey;462597]Angle grinder - Pedro style ;)[/quote] lol did that last time, but need to learn to take them out without smashing the box to bits like last time lol
Post 462600 by Wobbly Dave on 2012-02-13 15:29:11
Take a metal punch & a hammer - and tap the little black screw anti-clockwise. You should then be able to unscrew it, remove the clamp (I don't have one anymore).
Post 462606 by daza-b on 2012-02-13 15:49:45
[quote=Wobbly Dave;462600]Take a metal punch & a hammer - and tap the little black screw anti-clockwise. You should then be able to unscrew it, remove the clamp (I don't have one anymore).[/quote] cheers done the job :) going to be leaving it off from now on lol
Post 462607 by Wobbly Dave on 2012-02-13 16:00:35
You can put it back if you wish or replace the security bolt with a regular nut?
Post 462609 by daza-b on 2012-02-13 16:07:02
[quote=Wobbly Dave;462607]You can put it back if you wish or replace the security bolt with a regular nut?[/quote] not sure yet, im in more of a predicament as some of the wiring may be slightly different than the t5, which makes my life 10 times harder lol
Post 462615 by p fandango on 2012-02-13 16:14:26
[quote=martinrpeachey;462597]Angle grinder - Pedro style ;)[/quote] BT didn't have the strap, so had to make do with binning the box lol
Post 462648 by Jamest5r on 2012-02-13 17:50:18
[quote=daza-b;462609]not sure yet, im in more of a predicament as some of the wiring may be slightly different than the t5, which makes my life 10 times harder lol[/quote] You can swop the engine loom as a whole mate it splits under the ecu box, not too bad a job but inlet mani has to come off to get to the starter and knock, took me about 3hrs all in.
Post 462712 by daza-b on 2012-02-13 19:07:02
[quote=Jamest5r;462648]You can swop the engine loom as a whole mate it splits under the ecu box, not too bad a job but inlet mani has to come off to get to the starter and knock, took me about 3hrs all in.[/quote] yea i found that bit lol, main thing thats puzzling me is that there is a couple of fuses in different places if that makes sense and i wont have a plug for the boost control solenoid, other than that i think its all straight forward :)
