Volvo s60 dash clocks
Post 465339 by Tracey on 2012-02-21 11:50:12
Can I fit used clocks I have my machanic saying yes and others saying no has anyone here done this??
Post 465341 by M-R-P on 2012-02-21 11:53:32
Welcome to the forum. I can say from experience, no. Loads of people said yes, make sure the codes or year match, @rse! I tried 8 different DIMs and nothing worked. I even found a set of clocks with identical numbers and still nothing. My crystal ball says your DIM is failing? or has failed? 2000 to 2003 model?
Post 465343 by Tracey on 2012-02-21 12:11:15
Its 03 2.4 D5 What do I do then?
Post 465350 by M-R-P on 2012-02-21 12:53:41
Plan A: unplug the battery for 2 hours, remove the DIM, take it apart and take the PCB to a TV/mobile phone shop and get them to resolder the Motorolla chip (one of 3 big chips on the board). It'll cost you about 30-45 quid. Refit the DIM, plug the battery back in and hope for the best. Usually, if done right, it will last for the rest of the time you own the car. Plan B: (only when resoldering has failed a few times) Take it to Volvo, £732.50 later, a nice shiny new DIM, restyled and more reliable. Image If I can be of any help, just ask ;) Martin.
Post 465366 by hamish on 2012-02-21 15:04:34
[quote=martinrpeachey;465341]Welcome to the forum. I can say from experience, no. Loads of people said yes, make sure the codes or year match, @rse! I tried 8 different DIMs and nothing worked. I even found a set of clocks with identical numbers and still nothing. My crystal ball says your DIM is failing? or has failed? 2000 to 2003 model?[/quote] Ignore Martin's reply you CAN USE SECOND HAND clocks/DIMs but there are 3 conditions: 1) Must be the same fuel (Diesel and Petrol have different rev counters) 2) The donor vehicle must be newer than the recipent. (although my 2002 S60 DIM is currently working fine in a 2004 XC90 !!) 3) The 'new' DIM WILL need programming in once fitted using Autologic (Diagnstic Tool for Volvos that is more versatile than Vida) or Bring the whole car to me and we will run diagnostics, repair your DIM, reprogramme/upgrade DIM software for a fraction of the cost of a new DIM from Volvo. We can even loan you a car while yours is being repaired. This is a common complaint. We have 2 XC90s in our yard waiting for DIM Repairs. Regards, Hamish. www.hlmtuning.co.uk
Post 465367 by hamish on 2012-02-21 15:08:19
[quote=martinrpeachey;465350]Plan A: unplug the battery for 2 hours, remove the DIM, take it apart and take the PCB to a TV/mobile phone shop and get them to resolder the Motorolla chip (one of 3 big chips on the board). It'll cost you about 30-45 quid. Refit the DIM, plug the battery back in and hope for the best. Usually, if done right, it will last for the rest of the time you own the car. Plan B: (only when resoldering has failed a few times) Take it to Volvo, £732.50 later, a nice shiny new DIM, restyled and more reliable. Image If I can be of any help, just ask ;) Martin.[/quote] £800 that is an expensive repair !!! I think you'll find it was a case of trying to save money to spend money.
Post 465368 by M-R-P on 2012-02-21 15:13:44
dam dam dam dam dam dam dam dam dam dam dam dam dam dam dam dam !!!!!!!!!!!!!!!!!!!!!!!!!! Reprogramming? All the research I did on the subject pointed to the DIMs being a "flash once" and couldn't be reprogrammed! :( dam dam grrrr grrrr735quidgrrrr dam :(
Post 465380 by Nathlm on 2012-02-21 15:43:05
[quote=martinrpeachey;465368]dam dam dam dam dam dam dam dam dam dam dam dam dam dam dam dam !!!!!!!!!!!!!!!!!!!!!!!!!! Reprogramming? All the research I did on the subject pointed to the DIMs being a "flash once" and couldn't be reprogrammed! :( dam dam grrrr grrrr735quidgrrrr dam :([/quote] Would I be rubbing salt into the wound if I told you how much we charge for a DIM repair? £350 all in *natrunsandhide*
Post 465386 by M-R-P on 2012-02-21 16:26:10
[quote=Nathlm;465380]Would I be rubbing salt into the wound if I told you how much we charge for a DIM repair? £350 all in *natrunsandhide*[/quote] Oh marvelous! Mind, it's about 120 quid for the petrol to get to you so I'm only 250 quid short :( Hey-ho, lives and learns, where were you guys when I started this thread... http://www.vpcuk.org/forums/showthread.php?t=37519 :)
Post 465441 by Nathlm on 2012-02-21 19:52:48
[quote=martinrpeachey;465386]Oh marvelous! Mind, it's about 120 quid for the petrol to get to you so I'm only 250 quid short :( Hey-ho, lives and learns, where were you guys when I started this thread... http://www.vpcuk.org/forums/showthread.php?t=37519 :)[/quote] Opps sorry didn't see that thread :( xx
Post 465646 by Tracey on 2012-02-22 10:04:45
Great info thanks
Post 465651 by local-looney on 2012-02-22 10:22:21
K[quote=martinrpeachey;465368]dam dam dam dam dam dam dam dam dam dam dam dam dam dam dam dam !!!!!!!!!!!!!!!!!!!!!!!!!! Reprogramming? All the research I did on the subject pointed to the DIMs being a "flash once" and couldn't be reprogrammed! :( dam dam grrrr grrrr735quidgrrrr dam :([/quote] Martin,been doin some digging...bba reman fix em for 99+vat,carriage and etm's for 180 all in!!!! Or shouldn't I tell u this!!
Post 465657 by M-R-P on 2012-02-22 10:34:51
[quote=850-shane;465651]K Martin,been doin some digging...bba reman fix em for 99+vat,carriage and etm's for 180 all in!!!! Or shouldn't I tell u this!![/quote] BBa reman, dashclusters uk, there's a few of them. What most of them do is replace some capacitors on the power section of the board and re-solder the chips. £99 to £180 for that when all that's needed is the Motorolla chip resoldered? 40 quid from a tv repair shop is a better option in my opinion. And stop worrying about your ETM ;) I had almost calmed down from spending 732 quid in september, now it's aaallll flooding back - hurrumph!
Post 465669 by local-looney on 2012-02-22 11:38:26
[quote=martinrpeachey;465657]BBa reman, dashclusters uk, there's a few of them. What most of them do is replace some capacitors on the power section of the board and re-solder the chips. £99 to £180 for that when all that's needed is the Motorolla chip resoldered? 40 quid from a tv repair shop is a better option in my opinion. And stop worrying about your ETM ;) I had almost calmed down from spending 732 quid in september, now it's aaallll flooding back - hurrumph![/quote] Better to have the knowledge than the ignorance!!!!! And I had almost got over the etm issue.......until I opened the bonnet and saw the ticking timebomb with the words magne.......no,that's enough!!
Post 465670 by M-R-P on 2012-02-22 11:49:29
Really? you gotta magnetti? chances are it's been fixed already. stop worrying, it would have gone ages ago and been fixed already ;) here's how to tell... look at the etm, what colour is the sticker that you can see behind the dipstick?
Post 465675 by Yosser on 2012-02-22 12:06:06
FWIW I've just had my DIM repaired for £60 inc postage - sent it Monday, got it back today ;)
Post 465676 by M-R-P on 2012-02-22 12:17:58
All I can do is repectfully say "well done". Talk about can of worms! D'oh. In my defence, I'd grown so sick of fixing my old one, when it nearly caught fire on the M3, I was happy to pay the price of a new one, just to get it done! And for those who haven't seen it... [ame]http://www.youtube.com/watch?v=c_7ZrfqB3zs[/ame] This made me feel better ;)
Post 465707 by Tracey on 2012-02-22 15:12:14
[quote=Yosser;465675]FWIW I've just had my DIM repaired for £60 inc postage - sent it Monday, got it back today ;)[/quote] Do tell!
Post 465715 by Yosser on 2012-02-22 16:06:19
http://www.volvoforums.org.uk/showthread.php?t=143579 or http://www.ebay.co.uk/itm/Volvo-Instrument-Cluster-Repair-Service-Cheapest-Ebay-/120864013065 Same guy.
