LPG - cold air induction
Post 466225 by fassi1 on 2012-02-23 20:46:05
Hi everyone. Came to some sort of idea how to improve (lower) intake air temp. Having LPG fitted i think i could use its properties which is very low temp. to cool the air down. I thought about making up some sort of radiator out of 6mm copper tube with gas (very cold liquid in it) and let the air flow through that radiator. What do u reckon to this idea? I reckon that could keep the air cooler especially in the summer time.
Post 466228 by Volvostorm on 2012-02-23 20:50:20
Guess it could work, its only what your vaporiser does in the engine bay, I wouldn't like to try it. Get any leaks it would be nasty!
Post 466235 by fassi1 on 2012-02-23 21:08:02
No worries about the leaks, i'm LPG installer and copper tube is solid. Feed would be taken from before vaporiser which is 8mm flexi pipe, split in to 2no 6mm copper tubes, through custom radiator made out of those 2no 6mm copper tubes, back to 8mm flexi pipe and back to vaporiser.
Post 466244 by Volvostorm on 2012-02-23 21:16:13
Can't see why it shouldn't work. What LPG systems do you use?
Post 466254 by fassi1 on 2012-02-23 21:28:46
I use Stag system and can set up many others as long as i have right interface because there is so many different systems available. Always use wideband sensor so set up can be done precisely. What would be the best place for that LPG air cooler. I think before air filter.
Post 466265 by Volvostorm on 2012-02-23 21:41:34
Mine has a BRC system fitted. It will have a wideband, for mapping the ECU. I'd fit it after the filter, but before the MAF, then its going to suck the air through the cooler.
Post 466278 by fassi1 on 2012-02-23 22:01:44
Yeah will have to have a look and think about it as i have standard air box. Did u test ur LPG on the dyno? Any power loose?
Post 466287 by Volvostorm on 2012-02-23 22:07:52
No, which I was pleased about, I 245bhp on the last dyno session, thats with her smoking badly, it hit peak power before the change, and, it hit 245 on petrol before the kit was fitted. I think its going to need some playing with now, to cope with the extra power ;)
Post 466311 by fassi1 on 2012-02-23 22:29:16
U need solid gas pressure so the biggest possible vaporiser or 2 smaller ones. Mind that not every single vaporiser will be working with the turbo engines. My S60 2.4LPT gained about 50bhp after HLM remap and i was very pleased with max power loss 5bhp without retuning LPG system after remap was done. Now its all up and running sweet so interested if there is some improvement.
Post 466315 by Volvostorm on 2012-02-23 22:32:09
Yeah, I know, I'm not to worried, as long as the LPG can cope with everyday use, I'm happy :)
Post 466323 by Kingsford G on 2012-02-23 22:38:58
[quote=fassi1;466254]I use Stag system and can set up many others as long as i have right interface because there is so many different systems available. Always use wideband sensor so set up can be done precisely. What would be the best place for that LPG air cooler. I think before air filter.[/quote] How much would it cost all in have one installed and how much just the kit?I`m thinking of doing mine in the future the only downside its not an estate.
Post 466327 by Volvostorm on 2012-02-23 22:46:19
[quote=Kingsford G;466323]How much would it cost all in have one installed and how much just the kit?I`m thinking of doing mine in the future the only downside its not an estate.[/quote] Doesn't make any different being a saloon, I have a tank in my spare wheel well, so not to lose space, you could ave a cylinder tank across the back seats. There are many different types of tanks you can chose from
Post 466331 by fassi1 on 2012-02-23 22:49:11
[quote=Kingsford G;466323]How much would it cost all in have one installed and how much just the kit?I`m thinking of doing mine in the future the only downside its not an estate.[/quote] Are u talking about S60 2.4LPT? Need to know what car is it exactly, what bhp and if u planning any mods for power increase and what tank do u want (cylinder or toroidal).
Post 466333 by Kingsford G on 2012-02-23 22:51:19
[quote=Pault5estate;466327]Doesn't make any different being a saloon, I have a tank in my spare wheel well, so not to lose space, you could ave a cylinder tank across the back seats. There are many different types of tanks you can chose from[/quote] Space is the problem `cos I want it in the spare wheel and spare wheel gonna take space in the boot.Knowing my mrss laggage everytime we go to belgium.Also just found these if that is true http://www.ebay.co.uk/itm/290604545434?ru=http%3A%2F%2Fwww.ebay.co.uk%3A80%2Fsch%2Fi.html%3F_nkw%3D290604545434%26_sacat%3D0%26_odkw%3D290604545434%2BItem%2Bspecifics%26_osacat%3D0%26_trksid%3Dp3286.c0.m270.l1313%26_fvi%3D1&_rdc=1
Post 466335 by Kingsford G on 2012-02-23 22:53:16
[quote=fassi1;466331]Are u talking about S60 2.4LPT? Need to know what car is it exactly, what bhp and if u planning any mods for power increase and what tank do u want (cylinder or toroidal).[/quote] S70R at the mo 260bhp I am planning more mods but I think 300bhp `ll do me.Cylinder tank in the spare wheel space.Cheers.
Post 466336 by fassi1 on 2012-02-23 22:55:26
Dont need any of those LPG spark plugs. Standard or iridium good quality spark plugs recommended for ur engine, thats all u need. U better need good quality kit especially injectors.
Post 466338 by fassi1 on 2012-02-23 23:01:49
[quote=Kingsford G;466335]S70R at the mo 260bhp I am planning more mods but I think 300bhp `ll do me.Cylinder tank in the spare wheel space.Cheers.[/quote] U need 2 vaporisers and big injectors. Will give u the prices 2morrow.
Post 466339 by Volvostorm on 2012-02-23 23:03:33
[quote=Kingsford G;466333]Space is the problem `cos I want it in the spare wheel and spare wheel gonna take space in the boot.Knowing my mrss laggage everytime we go to belgium.Also just found these if that is true http://www.ebay.co.uk/itm/290604545434?ru=http%3A%2F%2Fwww.ebay.co.uk%3A80%2Fsch%2Fi.html%3F_nkw%3D290604545434%26_sacat%3D0%26_odkw%3D290604545434%2BItem%2Bspecifics%26_osacat%3D0%26_trksid%3Dp3286.c0.m270.l1313%26_fvi%3D1&_rdc=1[/quote] I don't carry a spare, just a can of tyre foam, saying that, if I was going abroad, I would carry it. As said, you don't need those plugs, I just use stock Volvo plugs.
Post 466392 by fassi1 on 2012-02-24 05:40:27
[quote=Kingsford G;466335]S70R at the mo 260bhp I am planning more mods but I think 300bhp `ll do me.Cylinder tank in the spare wheel space.Cheers.[/quote] Installed with 2 years warranty and certificate £1200 (kit with 2 reducers).
Post 466554 by Volvostorm on 2012-02-24 19:27:06
Not a bad price that, I paid £1500 to have mine done.
Post 466556 by Kingsford G on 2012-02-24 19:32:50
[quote=fassi1;466392]Installed with 2 years warranty and certificate £1200 (kit with 2 reducers).[/quote] Sounds good mate.Not too far to go ether.I`ll let u know when I`ve got the money.
Post 466592 by fassi1 on 2012-02-24 20:52:03
Just to let u know guys, i don't use the cheapest stuff. There is so many poor quality kits especially injectors. Once car is converted u can do drag racing, track days, running full boost and do whatever u would normally do running on the petrol. Getting back to my cooler, why do u Pault5estate think that placing it after filter will be better than just before filter? I agree that it should be before MAF.
Post 466595 by Volvostorm on 2012-02-24 20:59:31
I feel/think it would be better because your going to have vacuum from the engine, which will draw the air through the cooler.
