Post 41322 by The Flying Banana on 2005-09-01 22:00:55
Evening all....someone on here must know!! I have teh original Volvo sound system ( loads 3 CDs in teh head unit ) but i hear people say it can have an amp connected to it...soes it need to be a Volvo amp ..is it standard line outs? Also it has some buttons on it ...one is ' Sound ' on the right hand side and others are under the rotary knobs for bass and treble...when you pull them out you can set the effect ? and the centre? but none of these do anything..i am presuming because i have no amp ?
Any ideas?
Post 41324 by grdunn on 2005-09-01 22:12:53
I think most 850's onwards have a seperate amp, usually under the front seat or in the boot. Some later cars have Dolby Prologic facility which means you have 3 speakers in the dashboard, left,right and centre.
Post 41362 by grumpybob on 2005-09-02 08:45:56
Hi
I have the standard single cd slot unit and not the 3 disc but priced the volvo amp out of curiosity - it was nearly £200 & vat IIRC. Needless to say I didn't bother. It uses a single plug to the head unit and not line outs.
I did see a convertor plug on e-bay a while ago to connect an aftermarket amp but not seen any since.
HTH.
Bob
Post 41430 by p fandango on 2005-09-02 15:40:23
you can always get an aftermarket amplifier with high-level input to link to the Volvo HU (use the speakers outputs off the radio instead of using RCA's)
Post 41471 by grumpybob on 2005-09-02 21:15:59
Here we go with the adapter for Volvo head unit to aftermarket amps.
http://www.soundlinx.co.uk/ProductFinder/default.asp
Product code = VOL01RCA
Just in case the link don't work.
Bob
Post 41475 by The Flying Banana on 2005-09-02 22:11:57
[QUOTE=grumpybob]Here we go with the adapter for Volvo head unit to aftermarket amps.
Bob[/QUOTE]
Bob..you are the man!!!!
I am off to Leven tomorrow to get one!!!!
Cheers
Scott
Post 41486 by grumpybob on 2005-09-02 23:17:41
No problem Buddy
Let us know how you get on with it.
