960 throttle body
Post 470970 by Mongo on 2012-03-06 07:59:46
As above what 3" hose do you use off the t/b because i need the take off for the vac pump. Cheers
Post 471030 by Mongo on 2012-03-06 13:08:57
Bump
Post 471082 by p fandango on 2012-03-06 16:28:16
i made a new pipe, had a 19mm air compressor fitting welded into the pipe for the "idle control valve" Image
Post 471139 by Mongo on 2012-03-06 19:15:53
Thanks mate ill look for one lol (icv)
Post 471140 by Mongo on 2012-03-06 19:17:08
[quote=p fandango;471082]i made a new pipe, had a 19mm air compressor fitting welded into the pipe for the "idle control valve" Image[/quote] Whats your bottom ic bend isit two 90s together?
Post 471148 by p fandango on 2012-03-06 19:26:38
[quote=Mongo;471140]Whats your bottom ic bend isit two 90s together?[/quote] a 90 & a 45, here's a pic before the T-piece was added Image Image
Post 471151 by JT on 2012-03-06 19:29:04
i used one of these: Image
Post 471152 by JT on 2012-03-06 19:30:12
[quote=p fandango;471082]i made a new pipe, had a 19mm air compressor fitting welded into the pipe for the "idle control valve" Image[/quote] those were the days........radiator at the front!! :uglyhamme
Post 471155 by p fandango on 2012-03-06 19:32:21
[quote=johnnytempest;471152]those were the days........radiator at the front!! :uglyhamme[/quote] never even noticed, fans already been binned tho lol
Post 471225 by Volvostorm on 2012-03-06 21:40:51
This is my solution to the problem Image
