Quick vac question
Post 471310 by Mongo on 2012-03-06 23:14:20
http://www.vpcuk.org/forums/attachment.php?attachmentid=11763&stc=1&d=1320771474 The vac line that rins from intake manifold to fan sensor thingy. Do i need this white soucer part or will a simple vac hose do the job?
Post 471313 by Kingsford G on 2012-03-06 23:15:33
[quote=Mongo;471310]http://www.vpcuk.org/forums/attachment.php?attachmentid=11763&stc=1&d=1320771474 The vac line that rins from intake manifold to fan sensor thingy. Do i need this white soucer part or will a simple vac hose do the job?[/quote] It is a valve and has it own porpose as far as I know.
Post 471314 by Volvostorm on 2012-03-06 23:15:44
Its a flame trap I would use it
Post 471345 by AndysR on 2012-03-06 23:39:30
If I am looking at the right part, the one clipped to the fan shroud, then that is a one way valve for the brake servo vac supply. Yes you need that ;)
