Post 476372 by Mongo on 2012-03-21 19:56:31
Whats the easyist way to remove and refit a clutch on a 850 t5? Can i und all the bolts and pull it aside and and slightly drop the subframe? I dont wana drop hardly any fluid
[quote=Mongo;476372]Whats the easyist way to remove and refit a clutch on a 850 t5? Can i und all the bolts and pull it aside and and slightly drop the subframe? I dont wana drop hardly any fluid[/quote] to be honest mate, having done one of these not long ago, i only have 2 word GOOD and LUCK ;) lol
[quote=daza-b;476374]to be honest mate, having done one of these not long ago, i only have 2 word GOOD and LUCK ;) lol[/quote] Big girl. lol. You didnt have to sit under the car with the gearbox resting on your face. lol
[quote=smithson007;476377]Big girl. lol. You didnt have to sit under the car with the gearbox resting on your face. lol[/quote] lol stop moaning! lol
[quote=Mongo;476372]Whats the easyist way to remove and refit a clutch on a 850 t5? Can i und all the bolts and pull it aside and and slightly drop the subframe? I dont wana drop hardly any fluid[/quote] When me and daza did it we dropped the whole sub frame off and held the engine on a hoist. When we do mine were going to try just dropping box side of subframe down and leaving other side bolted in just loose. The box aint the easiest of things to get off and on in the space you have to work with. Youre going to loose a small bit of gearbox oil when youre moving it as itll come out of where the shafts were.
[quote=daza-b;476382]lol stop moaning! lol[/quote] You just got gased instead. lol. Were doing mine soon.
[quote=smithson007;476387]You just got gased instead. lol. Were doing mine soon.[/quote] yippie lol
I've done 4 Of these now, 3 times By leaving the nsf subframe haging and the other one disconecting the steering column. The late if think is probably better but both ways have there pro's and con's. 2 Were auto's (replacing Box) and 2 where manuals (Clutch change) Ultimatly i go with disconecting the column from inside of the driver's foot well then drop the whole subframe. just watch out for the Radiator a/c pipes etc etc. Allow a Weekend for it.
yeah just drop one side down although loosen the other side down as much as you can to give you room to wiggle the box out
[quote=t5frankie;476396]yeah just drop one side down although loosen the other side down as much as you can to give you room to wiggle the box out[/quote] LOL yeah just wiggle it out, it will practically fall out lol. not (unles of course the chassis rails are a little further apart than a 850.
[quote=merc85;476438]LOL yeah just wiggle it out, it will practically fall out lol. not (unles of course the chassis rails are a little further apart than a 850.[/quote] No theyre all a nightmare mate.
Cheers evryone got my forged engine in and runing but clutch wont engage to slot in gear because its a 6 paddle helix aparantly the driveplate is very similar both sides with no markings and ive done the most stupid and timeconsuming thing possible and put it in the wrong way.!!!!! School boy era could shoot myself
[quote=Mongo;476456]Cheers evryone got my forged engine in and runing but clutch wont engage to slot in gear because its a 6 paddle helix aparantly the driveplate is very similar both sides with no markings and ive done the most stupid and timeconsuming thing possible and put it in the wrong way.!!!!! School boy era could shoot myself[/quote] Mate doh i always joke about doing that very thing Damm i bet ur p***d
Yea im verry very p***d lol thing is im arguing with meself telling meself it must be right but it clearly aint cos it wont go down already broke my clutch master cylinder push rod because i stamped on the clutch in a tantrum. Oh well
Took the clutch out today and guess what it was in correctly!! No its a mission fault finding this. Im going to re-connect the slave cylinder and test the rod is functioning proply i have a spare n/a 850 slave lying sbout ill try that if not. Any thoughts on anything else? Its had a new clutch master abd bin rebled a few times.
