White plastic clip thing in bellhousing
Post 477703 by Mongo on 2012-03-25 23:23:25
As above. The other day i removed my gearbox and a white plastic like clip/object fell out the bellhousing. Anybody no what it is/where its from?
Post 477707 by smithson007 on 2012-03-25 23:27:39
Cant think what it would be mate. Have you got the clutch working right yet?
Post 477715 by jayeastanglia on 2012-03-25 23:52:24
could it be a bush from clutch fork??
Post 477719 by Dangerous Dave on 2012-03-26 00:08:09
Any chance of a picture of it?
Post 477739 by Mongo on 2012-03-26 08:57:02
Clutch is back out now for the moment till i sort this problem out. Ill get a pic ina bit
Post 477773 by Mongo on 2012-03-26 11:11:35
This is it Image Image Hopfully this is the problem (big ask tho)
Post 477779 by 960kg on 2012-03-26 11:54:00
[quote=Mongo;477773]This is it Image Image Hopfully this is the problem (big ask tho)[/quote] I have found this for you. But the angle of your photo doesn`t give much away except that it looks as though it may clip over onto the slave cylinder rod!!! I hope this is it! Image
Post 477785 by Mongo on 2012-03-26 12:12:59
[quote=960kg;477779]I have found this for you. But the angle of your photo doesn`t give much away except that it looks as though it may clip over onto the slave cylinder rod!!! I hope this is it! Image[/quote] Thanks ive just bin out and it sits on the fork and the pivot bar inside the bellhousing.
