Post 477991 by wacky racer on 2012-03-26 20:12:06
Anyone know how the V50 exterior door mouldings come off. Double side tape, clips or both? Also where can I buy some from apart from main dealer? Thanks.
You can get the clips off the bay. Have you got a pic of the door card? I'll probably be able o tell you how to get it off ;)
[quote=wacky racer;477991]Anyone know how the V50 exterior door mouldings come off. Double side tape, clips or both? Also where can I buy some from apart from main dealer? Thanks.[/quote] The exterior trim in the middle of the door is held by two strips of 6mm double sided tape and just locating spigots in the centre of it. The exterior bottom trim has one bolt each end and two plastics clips in it`s length.
Yeah I found it out about the double sided tape this morning. thanks anyway. Was looking to maybe spray my door mouldings to Match the car but now i know their stuck on I'm not so sure. They never stick as good when you clean them up and re-stick them after painting. I looked at getting some new primed ones that are ready for painting but can only seem to be able to get the from the dealer. At aprox £70 plus VAT per moulding!!!!
