Post 481483 by T5Tom on 2012-04-04 15:53:43
Hi everyone, my lamda light is currently on but still seems to be running well although when changing up I get a slight chug low down. Feels like a fueling problem to me but im not sure? Is there anyone around the warrington area with a code reader that i could possibly meither for a reading, or could I be so cheeky to ask if someone could kindly lend me one if i cover postage costs? (im a trustworthy man dont worry although I might not look it lol) not exactly minted at the moment so i can't really afford to buy one unfortunately
Cheers
Tom
Post 481493 by Al115 on 2012-04-04 16:25:46
There is a shared Forum one somewhere. Search and ye shall find the thread.
Post 481584 by T5Tom on 2012-04-04 18:40:43
Thanks I shall have a look now :)
Post 481599 by T5Tom on 2012-04-04 19:06:33
Can't seem to find it, any idea where it could be posted pal?
Post 481640 by T5Tom on 2012-04-04 20:08:21
It won't let me post on that thread :(
Could i trouble someone to ask on my behalf pretty please??
Post 481644 by Pinup_gal on 2012-04-04 20:14:15
The thread needs moving give me a mo :)
Post 481646 by Pinup_gal on 2012-04-04 20:15:42
http://www.vpcuk.org/forums/showthread.php?t=24715
There ya go Tom sorry about that
Post 481655 by T5Tom on 2012-04-04 20:32:57
[quote=Pinup_gal;481646]http://www.vpcuk.org/forums/showthread.php?t=24715
There ya go Tom sorry about that[/quote]
Tar very muchly :)
Post 482145 by T4Rick on 2012-04-05 20:37:15
You can make your own code reader and read and erase codes dead easy
http://www.volvoforums.org.uk/showthread.php?t=83897
Post 482161 by T5Tom on 2012-04-05 20:51:10
[quote=850Rick;482145]You can make your own code reader and read and erase codes dead easy
http://www.volvoforums.org.uk/showthread.php?t=83897[/quote]
sounds easy enough cheers pal
Post 482183 by T4Rick on 2012-04-05 21:23:44
[quote=T5Tom;482161]sounds easy enough cheers pal[/quote]
i use it all the time lol
Post 482226 by Dan850r on 2012-04-05 23:04:30
Sounds a little bit like what mine is doing? Try your idle valve, and weirdly had an ac fault, temp repair on that and its alot better
Does it hold on to the revs when you change gear?
Post 482270 by T5Tom on 2012-04-06 06:08:27
[quote=Dan850r;482226]Sounds a little bit like what mine is doing? Try your idle valve, and weirdly had an ac fault, temp repair on that and its alot better
Does it hold on to the revs when you change gear?[/quote]
Yes it does slightly mate, if you sit at idle then rev the engine it seems to run away slightly also before going back to idle, is this what yours was doing?
Post 482314 by Dan850r on 2012-04-06 10:12:24
[quote=T5Tom;482270]Yes it does slightly mate, if you sit at idle then rev the engine it seems to run away slightly also before going back to idle, is this what yours was doing?[/quote]
Its more when you change between gears, i plugged the sensor back in for the aircon behind drivers head light ant it no longer does it, but its been unplugged for ovrr 18 months without issue which is weird.
Post 482330 by T5Tom on 2012-04-06 11:10:12
[quote=Dan850r;482314]Its more when you change between gears, i plugged the sensor back in for the aircon behind drivers head light ant it no longer does it, but its been unplugged for ovrr 18 months without issue which is weird.[/quote]
Sounds a bit coincidental to me, what would the air con have to do with the engine running over?
Post 482452 by Dan850r on 2012-04-06 17:15:44
I read somewhere that the ac pressure switch tells the ecu to add more fuel when it kicks in
Post 482478 by T5Tom on 2012-04-06 17:51:14
Ok so I got 1-2-1, 5-3-5, and 4-2-4
Any ideas lads? I'm not sure of the fault codes. Am I right in saying it will be the motronic 4.3 codes on the 1996 850 t5?
