Window Opening on Its own
Post 481675 by Santa on 2012-04-04 20:51:45
I was weirdly freaked out earlier when I came home to find the front passenger side window down on the S60R. At first I thought the worst and expected glass everywhere but instead I was greeted by a very wet interior. Has a window opening on its own happened to any of you other P2 owners? Cheers :-)
Post 481680 by local-looney on 2012-04-04 20:55:18
not mine........(oops,thats done it)!!!!!
Post 481681 by Al115 on 2012-04-04 20:55:18
I had windows not closing properly once on the M because they'd lost their auto-up setting. But if it was closed to start with and opened itself... that's a new one to me.
Post 481687 by Al115 on 2012-04-04 21:00:09
I wrote you a haiku - The windows were closed But later they were open The question is, why? Hope this helps.
Post 481691 by Jamest5r on 2012-04-04 21:04:19
I reckon the Mrs done it out of spite cos you aint bought her a Volvo yet :)
Post 481696 by foammanmark on 2012-04-04 21:06:02
My p2 doesn't do it, but I know on most Audis/VWs, if you hold the unlock button down on the remote, it will open the front windows, and you press the lock button and hold to close them. Now with yours being an R, maybe that's something your car has?
Post 481715 by M-R-P on 2012-04-04 21:35:24
Not had it on mine (yet)
Post 481719 by foammanmark on 2012-04-04 21:37:47
[quote=martinrpeachey;481715]Not had it on mine (yet)[/quote] I have that sometimes when you try and close the drivers door window, and it goes part way up, stops and drops again.
Post 481721 by Santa on 2012-04-04 21:40:55
[quote=foammanmark;481696]My p2 doesn't do it, but I know on most Audis/VWs, if you hold the unlock button down on the remote, it will open the front windows, and you press the lock button and hold to close them. Now with yours being an R, maybe that's something your car has?[/quote] Nope no lazy unlocking....though I'd have both front windows open then?
Post 481801 by t5 stealth on 2012-04-04 23:53:48
[quote=foammanmark;481719]I have that sometimes when you try and close the drivers door window, and it goes part way up, stops and drops again.[/quote] thats cos the window is a bit tight in the runner, it thinks theres an obstruction so it drops the window..its a safety thing so kids /dogs etc dont get caught in it.
Post 481802 by t5 stealth on 2012-04-04 23:57:21
[quote=Santa;481675]I was weirdly freaked out earlier when I came home to find the front passenger side window down on the S60R. At first I thought the worst and expected glass everywhere but instead I was greeted by a very wet interior. Has a window opening on its own happened to any of you other P2 owners? Cheers :-)[/quote] there is a window reset method,cant remember how you do it but its something like this, ignition on, do up front windows,hold buttons up for about 8 seconds, then turn of ignition,remove key, lock car with remote,then unlock,then lock,then unlock. while your in the car. cant remember exactly but something along those lines. that resets the window module. this may sort the problem.
Post 481826 by Santa on 2012-04-05 07:02:11
[quote=t5 stealth;481802]there is a window reset method,cant remember how you do it but its something like this, ignition on, do up front windows,hold buttons up for about 8 seconds, then turn of ignition,remove key, lock car with remote,then unlock,then lock,then unlock. while your in the car. cant remember exactly but something along those lines. that resets the window module. this may sort the problem.[/quote] Cool :-) I'll give that a go when I get home. Hopefully I can get the car dried out properly the weekend.
Post 481843 by siggi on 2012-04-05 08:58:56
It's Karma :-)
Post 482072 by The Flying Moose on 2012-04-05 18:02:23
Im affraid to sign its a sure fire sign that the car has reached the end of its useable life. Ill give you scrap value plus a little extra so £200... ;)
Post 482073 by Santa on 2012-04-05 18:02:34
[quote=siggi;481843]It's Karma :-)[/quote] For keeping the forum running with the funds out my own pocket and not banning people that are clearly extracting the urine? Glad I didn't try and avoid ebay fees as all being equal the car would have fallen apart :-p
Post 482077 by Santa on 2012-04-05 18:03:40
[quote=The Flying Moose;482072]Im affraid to sign its a sure fire sign that the car has reached the end of its useable life. Ill give you scrap value plus a little extra so £200... ;)[/quote] I'll try the above advice first before giving up lol.......would save me removing the pond though
Post 482295 by siggi on 2012-04-06 09:20:09
Now don't be so touchy .. That's just my GSOH :-)
Post 482757 by Santa on 2012-04-07 09:06:20
[quote=siggi;482295]Now don't be so touchy .. That's just my GSOH :-)[/quote] So was mine :-p
Post 482826 by d2k on 2012-04-07 13:54:33
this happened to me the other day, came home from a week at a caravan... unloaded & locked the car... came out in the morning & the drivers window was fully open..?? then driving home from work last night parked the car, closed the window as i went to take out the key it opened on its own to the halfway point, done it back up & it came down again.... upon pulling the window to the 2nd click on the console it went up & stayed up.. its quite worrying though, i dont want windows opening on their own
Post 483656 by LeeT5 on 2012-04-09 13:40:31
The fault will be your drivers door switch pack. Out it for a new one, problem solved.
Post 483831 by t5 stealth on 2012-04-09 17:24:34
[quote=LeeT5;483656]The fault will be your drivers door switch pack. Out it for a new one, problem solved.[/quote] i dont know what year yours is santa but if you change the switch pack then it will need to be re-programmed by volvo........ from 02 onwards i think.
Post 483832 by d2k on 2012-04-09 17:26:15
[quote=t5 stealth;483831]i dont know what year yours is santa but if you change the switch pack then it will need to be re-programmed by volvo........ from 02 onwards i think.[/quote] this........ mine are linked to 'CEM' is it..?? along with rear view mirror...
Post 483845 by Santa on 2012-04-09 17:43:06
[quote=t5 stealth;483831]i dont know what year yours is santa but if you change the switch pack then it will need to be re-programmed by volvo........ from 02 onwards i think.[/quote] 04 and yeah I thought that would be the case :-)
Post 603521 by Harvey on 2013-05-06 23:31:07
I came back to my motor and found both front windows down,I have had the drivers side one touch close stop working as it should,it would auto open ok but when one touch close was used it would close but then auto open again. I put my code reader on and it says DDM-0022 upper hall sensor 1 or 2 faulty signal on drivers door not set, reinitialize the drivers door mechanism Auto close now working.
