Standard fuel pressure
Post 483664 by Mongo on 2012-04-09 13:46:01
As above does anybody no the standard fuel pressure off bost ive got to set me fpr to standard for running in.
Post 483665 by p fandango on 2012-04-09 13:46:36
3bar
Post 483788 by Mongo on 2012-04-09 16:01:22
3bar what on normal idle?
Post 483792 by claymore on 2012-04-09 16:04:26
mine runs at 25psi on tickover
Post 484096 by smithy on 2012-04-09 21:31:46
3 bar but if its a rising rate fpr the pressure will rise as you go up the revs so watch your afr meter .it it starts running rich then take the vac pipe off and the fpr will say at a constant pressure mate.i had mine set at 4 bar with 470cc injectors but i only had 4 pistons though.
Post 484187 by Mongo on 2012-04-09 22:46:50
I might just set it at 1.5 bar with vac on just to get me around whilst im running in cheers lads
Post 484683 by smithy on 2012-04-10 22:38:39
[quote=Mongo;484187]I might just set it at 1.5 bar with vac on just to get me around whilst im running in cheers lads[/quote] you would not open the injectors at that psi mate
Post 484752 by Niles on 2012-04-10 23:49:30
3 bar at idle.
