Post 486202 by Mongo on 2012-04-14 11:12:42
Does anyone no if you can map out the lambda sensor with the turbo tuner?
i do know Adam does/did (hope he still does, i want it lol) a TT version where you can have the function to ignore any diagnostic faults & the ecu will purely run as mapped, think that should work
[quote=p fandango;486203]i do know Adam does/did (hope he still does, i want it lol) a TT version where you can have the function to ignore any diagnostic faults & the ecu will purely run as mapped, think that should work[/quote] Yea sounds right it keeps poping up im only running in gives a little missfire at around 3000 revs somtimes so wana get rid of it after the maps sorted.
[quote=Mongo;486202]Does anyone no if you can map out the lambda sensor with the turbo tuner?[/quote] Yes you can. Drop me an email when you are ready to do this.
[quote=turbo-tuner;486289]Yes you can. Drop me an email when you are ready to do this.[/quote] Is it somthing i can do after the map? Also if the disc is installed on jamsports pc will i still have access to do this. Thanks
no sign of those stickers for the race car Mr TT?? :wink:
