Post 490702 by d2k on 2012-04-24 10:34:53
hi there... quick query, would a set of 06 (facelift) rear clusters fit into my 02 S60..?? thanks.
Should do, double check the plugs tho.
cheers martin.......:funkybana if the plugs differ, i'll just chop the old ones off the donor car.
Should be ok to do that, there's no multiplexing in the clusters, just make sure you know which wire does what before you go cutting things ;)
lol.... yeah thats a point, i was stupidly thinking the wire colour coding on the 02 will be the same as 06.... there's no way it'll be that simple ill post the wiring up here once i get the clusters....
