Need help from someone with VIDA/VADIS URGENT
Post 492305 by mitchyboy01 on 2012-04-28 10:37:54
Hi guys, I need to re pin my ECU plug so it is compatible with the ECU I bought from Mo which is a later model year. I need the ECU plug wiring diagrams for the following 2 models: My car is a Phase 1.5 which originally came with the B4194T2. Mo's was a Phase 2 with the B4204T5. This is what Ashok wrote on a previous thread of mine ''The pin diagrams are in VADIS, so I presume they will be in VIDA too - its under the "Information Manager" and then in the "Signal Description-EMS2000" under "Ignition and Controls" or something like that I think. If someone can look that up in VIDA and get and post the pin diagrams for both the B4204T5 and B4194T2 engines, you will have all the info you need - there's a total of 90 pins on each plug, but not all are utilised. The information is in tabular form with Pin No / Terminal, Signal Type / Description and then it shows the values with the ignition on and with the engine running (at idle)'' Any help will be greatly appreciated as I'm stuck at the moment without them!
Post 492313 by robsv40 on 2012-04-28 11:40:00
You having another go at getting it all working then?
Post 492321 by mitchyboy01 on 2012-04-28 12:13:05
Yeah mate, If someone can supply me the diagrams for the different ECU's!
Post 492344 by robsv40 on 2012-04-28 14:24:39
I did have a vadis copy somewhere but God knows where its gone. I think it was downloaded on my old machine but I'll keep looking. May actually have been on cd thinking about it. I'll look later.
Post 492367 by fassi1 on 2012-04-28 16:02:00
[quote=mitchyboy01;492321]Yeah mate, If someone can supply me the diagrams for the different ECU's![/quote] Will hava a look.
Post 492374 by fassi1 on 2012-04-28 16:15:35
Is it up to 1999 or from 2000?
