Headlight bulbs
Post 493784 by KevWak on 2012-05-02 08:13:56
Hi all, I've decided to upgrade my headlight and sidelight bulbs. I have the dull yellowish bulbs and fancy upgrading to some crisp white lights. But which to go for? After a little research I think I need H7 bulbs for the headlighs but how do I know if I need Halogens or Xenons? And as for sidelight bulbs, are LED's the way to go? And which ones do you recommend I go for? Thanks guys/girls Kev
Post 493786 by M-R-P on 2012-05-02 08:20:06
Now, presuming you have a P2... I used Ring Xenonmax bulbs for dipped beam. Fleabay 100W Power White (actually blue but show white when on) HB3 for full beam sidelight bulbs came with the 4 quid main beams, again blue when off and white when on. Fleabay 100W power White (actually blue but white when on) H1. Everything shows as a bright white, I just have to change the 100W ones for the MOT :)
Post 493788 by Harvey on 2012-05-02 08:35:04
Hi have a look at this link http://www.vpcuk.org/forums/showthread.php?p=490980#post490980
Post 493789 by d2k on 2012-05-02 08:44:46
[quote=martinrpeachey;493786]Now, presuming you have a P2... I used Ring Xenonmax bulbs for dipped beam. Fleabay 100W Power White (actually blue but show white when on) HB3 for full beam sidelight bulbs came with the 4 quid main beams, again blue when off and white when on. Fleabay 100W power White (actually blue but white when on) H1. Everything shows as a bright white, I just have to change the 100W ones for the MOT :)[/quote] i think you'll have to change them all for MOT mate, mine failed a few months back under new regulations that you cannot display bulbs that have 'blue' glass.... i was told to remove them even though they were 100% white light, road legal 55w ones. silly init.....:eek:
Post 493811 by M-R-P on 2012-05-02 10:25:04
[quote=d2k;493789]i think you'll have to change them all for MOT mate, mine failed a few months back under new regulations that you cannot display bulbs that have 'blue' glass.... i was told to remove them even though they were 100% white light, road legal 55w ones. silly init.....:eek:[/quote] All the blue ones are 100W and would have to be changed for the MOT any way ;) the dipped beam ones, although much brighter, are the correct 55W and clear :)
Post 493812 by KevWak on 2012-05-02 10:38:20
I have a 58 plate S40 with projector dipped lights. I don't really want 100w bulbs. I've heard these can damage the projector lense with the heat. Though I don't know how true this is. I've heard the OSRAM 55w Night Breakers are very good, but I don't know if I need Halogen or Xenon? Cheers
