Post 495052 by Mongo on 2012-05-06 14:39:16
Is there any good rear caliper upgrade for the t5 both my rears have snapped nipples ive got 4 pots on the front could do 4 pots on the back but any easier bolt on calipers for the back on standard discs?
s60r, dunno if the discs are the same size but plenty of people have done it
Are they a direct fit then?
no but you can get adaptors to bolt them on
[quote=p fandango;495136]no but you can get adaptors to bolt them on[/quote] Where from mate ipd?
whats the point since its only 25% of the braking that goes to the rears?
25% that could be the difference between life and death lol
[quote=Mongo;495182]Where from mate ipd?[/quote] used to be www.yother.com but for some reason the sites not working, whether he's moved sites or stopped i don't know
[quote=Mongo;495052]Is there any good rear caliper upgrade for the t5 both my rears have snapped nipples ive got 4 pots on the front could do 4 pots on the back but any easier bolt on calipers for the back on standard discs?[/quote]hi mate can get u some made ring me
This may help http://volvospeed.com/vs_forum/topic/118814-bbk-calipers-what-will-fit/
[quote=t5frankie;495184]whats the point since its only 25% of the braking that goes to the rears?[/quote] Frankie has a point here, you would not want the rear end braking to hard as this could altering the front rear bias could lead to to some serious rear end step out when you may least want it, if you upgrade the rears then install a bias valve so you can adjust the balance to the fronts:yikes:
Ive found some brand new original t5 calipers for sale £140 so might go with them looking at a few hundred quid for the bigger rear callipers dont think ill bother. Thanks for the help evry1
