gearbox
Post 495419 by oblark on 2012-05-07 15:40:05
Hi, Is the M56H gearbox a 850 or V70 box ?
Post 495431 by dalhousie2008 on 2012-05-07 15:49:27
I think it fits both, but really early ones 94 models have different speedo drive
Post 495432 by p fandango on 2012-05-07 15:49:55
it was used in both. 850's/early S/V70's have an external clutch slave cylinder, ME7 (1999-) then changed to an internal. Early 850 versions also had a speed sensor on the gearbox, while 1995/6- changed to getting the speed from the ABS
Post 495434 by T5frankie on 2012-05-07 15:50:41
[quote=p fandango;495432]it was used in both. 850's/early S/V70's have an external clutch slave cylinder, ME7 (1999-) then changed to an internal. Early 850 versions also had a speed sensor on the gearbox, while 1995/6- changed to getting the speed from the ABS[/quote] my 97 is an internal slave
Post 495447 by oblark on 2012-05-07 16:01:17
My 96 850 has a internal clutch slave and a M56H, on the V5 it was registered in Aug 96
