Post 495933 by bones717lee on 2012-05-08 14:51:02
hello everyone. is the standard bov on the turbo housing? im going to fit a bailey dv26 and think i need to blank off the original one.
im also thinking of fitting a manual boost controller but not sure how far i can go before the fuel cut kicks in. thanks for any help.
the car is a c70 t5 on a 98
Post 495936 by M-R-P on 2012-05-08 15:01:02
Is it ME7? (I think 98 is pre ME7)
If it is (no throttle cable) then MBC won't give you much, if any increase.
As for the BOV (recirc in this cace) yes, it's on the turbo - 3 10mm bolts holding it on.
Post 495967 by T5frankie on 2012-05-08 15:54:08
[quote=martinrpeachey;495936]Is it ME7? (I think 98 is pre ME7)
As for the BOV (recirc in this cace) yes, it's on the turbo - 3 10mm bolts holding it on.[/quote]
why wont the mbc give you much? it wil give you a guaranteed 25 bhp for one thing lol
Post 495994 by p fandango on 2012-05-08 17:04:05
[quote=t5frankie;495967]why wont the mbc give you much? it wil give you a guaranteed 25 bhp for one thing lol[/quote]
i think he means on a ME7, you can't turn them up much over the stock pressure without it throwing a fit
Post 496047 by T5frankie on 2012-05-08 18:36:35
[quote=p fandango;495994]i think he means on a ME7, you can't turn them up much over the stock pressure without it throwing a fit[/quote]
not what he says.
his car is a 98
Post 496058 by bones717lee on 2012-05-08 18:49:08
it isnt an me7. i was hoping to get the boost closer to 1 bar, it runs at 0,5/0.6 bar now.
Post 496062 by T5frankie on 2012-05-08 18:51:04
you should be able to run 1 bar with a boost controller on a standard ecu, if you cant something else is wrong, get a hlm remap for £150 then it will run 1.1 bar, stick an mbc on after for 1.3 bar (good times) lol
Post 496069 by bones717lee on 2012-05-08 18:58:25
sounds good. i will get a remap when i can afford it (just spent a fortune getting it through an mot) do you think it will run 1 bar without the fuel cut kicking in?
Post 496073 by bones717lee on 2012-05-08 19:04:38
hlm are a bit far away from me, im up north.
Post 496080 by kfc on 2012-05-08 19:13:52
Hlm can do the ecu upgrade by post they send you one and you send yours back, i think. give em a call. they dont bite!!
Post 496082 by T5frankie on 2012-05-08 19:15:04
[quote=bones717lee;496069]sounds good. i will get a remap when i can afford it (just spent a fortune getting it through an mot) do you think it will run 1 bar without the fuel cut kicking in?[/quote]
its around a bar when you'll get ignition cut, and hlm will post one an ecu out already done
Post 496089 by bones717lee on 2012-05-08 19:25:31
that sounds good and a good price too, will look into it. thanks
Post 496184 by dionbullock on 2012-05-08 21:33:24
my 1998 S reg T5 is an ME7... so youll need to make sure what engine version it is first :)
Post 496296 by M-R-P on 2012-05-09 01:28:43
[quote=t5frankie;496047]not what he says.
his car is a 98[/quote]
Read the rest of the post mate...
I just go on what I know - which is bringing an ME7 back to life, rather than killing various engines, gearboxes and suspension components.
Put an MBC on a ME7 engine and it'll throw a hissy-fit AFAIK - from what I've read about MY engine, ME7 don't like MBCs without a remap and even then you're pushing you're luck.
That's what I know, or think I know. Obviously, I don't have the experience of some members.
Post 496332 by bones717lee on 2012-05-09 09:22:18
[quote=dionbullock;496184]my 1998 S reg T5 is an ME7... so youll need to make sure what engine version it is first :)[/quote]
its a 98 on an R and isnt an me7, it has a throttle cable.
Post 496346 by M-R-P on 2012-05-09 10:17:51
In that case, blank the recirc, fit the baily and throw a MBC on it and enjoy :D
Post 496380 by 960kg on 2012-05-09 12:52:29
I understand where Bones is coming from as my `97 V70 would not respond to the MBC i had, there was nowt wrong with it as i had it fitted on other motors, but the boost was only between 5 & 9 would not even reach 10psi.
My HLM304 was by post and i bought a new TCV instead of using the MBC now i am a solid 18psi
Map was £262 then £100 refunded upon return of old ECU. £12 was postage one way of course.
Post 496401 by bones717lee on 2012-05-09 14:05:37
[quote=martinrpeachey;496346]In that case, blank the recirc, fit the baily and throw a MBC on it and enjoy :D[/quote]
thats the plan :)
Post 496403 by bones717lee on 2012-05-09 14:09:19
[quote=bones717lee;496401]thats the plan :)[/quote]
just bought an mbc so will see what happens when i fit it :)
Post 496440 by T5frankie on 2012-05-09 16:03:38
[quote=bones717lee;496403]just bought an mbc so will see what happens when i fit it :)[/quote]
i hope its a ball and spring one
Post 496447 by M-R-P on 2012-05-09 16:18:48
As above,
None of that cheap fleabay stuff.
Post 496469 by bones717lee on 2012-05-09 17:13:48
[quote=t5frankie;496440]i hope its a ball and spring one[/quote]
yeah it is, i think i read about them on here so made sure i got ball and spring one.
Post 497254 by bones717lee on 2012-05-11 12:39:02
got the mbc fitted today and with one turn its now running 0.9 and peaks at 1.0 bar with no issues. so much better :) next step remap and custom exhaust :) or yeah and a bailey dv.
