Remote close windows?
Post 501954 by KevWak on 2012-05-22 13:16:52
Hi all, My car - 58reg S40 2.0D Sport R Design. Don't know if Volvo's have this feature but... Is it possible to close the windows from outside the car with the FOB? My friends Vectra's windows close when the lock button is pressed twice. Does the Volvo have a similar feature? Cheers Kev
Post 501960 by Haizum74 on 2012-05-22 13:47:14
[quote=KevWak;501954]Hi all, My car - 58reg S40 2.0D Sport R Design. Don't know if Volvo's have this feature but... Is it possible to close the windows from outside the car with the FOB? My friends Vectra's windows close when the lock button is pressed twice. Does the Volvo have a similar feature? Cheers Kev[/quote] Have you had a trawl through the manual, if the feature is there it will say how to activate it.
Post 501966 by t5_monkey on 2012-05-22 14:05:30
I don't think there is... it's a PITA I always take the key out and realise a window is still down!
Post 502214 by scoobysn7x on 2012-05-23 01:17:46
My 2005 S40 has the auto close windows you just press and hold the Lock button on the fob and it will auto close the window & sunroof (really useful as I normally forget to close something), it also does the auto open windows & sunroof (no idea why this would be useful) you just press and hold the open button on the fob, girlfriends C30 does the same, not sure if its standard or not mines an T5 SE & the girlfirends is a R design.
Post 502220 by KevWak on 2012-05-23 06:32:31
Brilliant. I'll have a go of this today. I'm sure other owners will find this info useful too. Thanks. I'll report back later if it works or not. Cheers.
Post 502284 by t5_monkey on 2012-05-23 15:26:37
[quote=scoobysn7x;502214]My 2005 S40 has the auto close windows you just press and hold the Lock button on the fob and it will auto close the window & sunroof (really useful as I normally forget to close something), it also does the auto open windows & sunroof (no idea why this would be useful) you just press and hold the open button on the fob, girlfriends C30 does the same, not sure if its standard or not mines an T5 SE & the girlfirends is a R design.[/quote] ooh will try that on mine!!
Post 502288 by KevWak on 2012-05-23 15:52:55
It worked it worked!!!!! Woohoo
