V 70 R awd 1999 ets fault
Post 505155 by MoleT-5R on 2012-05-30 19:04:32
Unfortunately the good old V70 is throwing a bit of a wobbly of late, it broke down yesterday with a lack of throttle response and threw up an E.T.S warning lamp on the dash. After a while the car could be restarted and the throttle had returned to normal, so the car was driven home and then I read the fault codes (p422 p1600 p1608) and reset them. The car ran fine and then went to work in the morning, no problems. Yet on the way home and oddly enough, coming around exactly the same corner the same thing happened and after a while it would run again and got home. Read the codes again, only (p1600) this time. Any idea's anyone, would most gratefully be received, many thanks Adrian
Post 505163 by deathrider311271 on 2012-05-30 19:26:52
P1600 Throttle unit internal Fault Faulty signal your accelerator pedal is knackered mate, does your car have a yellow sticker ETM? i have an accelerator pedal for this car if interested. £180 from Volvo make me an offer Simon
Post 505175 by MoleT-5R on 2012-05-30 19:45:53
[quote=deathrider311271;505163]P1600 Throttle unit internal Fault Faulty signal your accelerator pedal is knackered mate, does your car have a yellow sticker ETM? i have an accelerator pedal for this car if interested. £180 from Volvo make me an offer Simon[/quote] its a funny thing this yellow-sticker thing!!!, I've read a bit on here about this sticker lark and was wondering whether this would probably be the problem? where is the yellow sticker / etm ? do you mean the throttle pedal?
Post 505185 by deathrider311271 on 2012-05-30 19:58:47
[quote=moleadrian;505175]its a funny thing this yellow-sticker thing!!!, I've read a bit on here about this sticker lark and was wondering whether this would probably be the problem? where is the yellow sticker / etm ? do you mean the throttle pedal?[/quote] Your ETM is situated under your inlet manifold, its a rectangle box you can just about see the sticker without removing anything. Mine was originally a white sticker one, i replaced it with a yellow sticker one from the same year car, no software required. If your going down the second hand route pm me and i will give you the full low down on how to do it for penuts Simon
Post 505198 by bubba_1986 on 2012-05-30 20:15:22
I have a yellow stickers etm for sale if it turns out you have a white stickered one
Post 505203 by deathrider311271 on 2012-05-30 20:17:41
[quote=bubba_1986;505198]I have a yellow stickers etm for sale if it turns out you have a white stickered one[/quote] how much you looking at for it? if this chap isnt interested i maybe dependant on price off course lol
Post 505208 by bubba_1986 on 2012-05-30 20:26:36
50 excluding delivery mate. Located in telford as at wobblydaves house Wouldn't be that much to post
Post 505215 by MoleT-5R on 2012-05-30 20:33:34
[quote=bubba_1986;505208]50 excluding delivery mate. Located in telford as at wobblydaves house Wouldn't be that much to post[/quote] could I pick it up tomorrow, late afternoon/early evening?
Post 505219 by bubba_1986 on 2012-05-30 20:37:56
[quote=moleadrian;505215]could I pick it up tomorrow, late afternoon/early evening?[/quote] Well i'll have to call him and and ask, His wife is due to have a baby tomorrow, thought not a def. I stay in glasgow see, me and dave bought car together to break and parts are at his
Post 505225 by bubba_1986 on 2012-05-30 20:41:28
Yes thats fine mate, ill pm you his address
Post 505246 by Wobbly Dave on 2012-05-30 21:06:49
any time tomorrow is fine - just ring me before you set off to make sure (I'm sending u my mobile).
Post 505760 by MoleT-5R on 2012-05-31 22:34:39
thanks dave for the part, hopefully this will sort the problem out, will just now have to find away to get it re-flashed. if any-one has idea's of cheap ways of doing this i would be most grateful
Post 505763 by deathrider311271 on 2012-05-31 22:39:09
[quote=moleadrian;505760]thanks dave for the part, hopefully this will sort the problem out, will just now have to find away to get it re-flashed. if any-one has idea's of cheap ways of doing this i would be most grateful[/quote] why do you need it reflashing??????? not required
Post 505824 by MoleT-5R on 2012-06-01 04:49:59
[quote=deathrider311271;505763]why do you need it reflashing??????? not required[/quote] thats sounds to be music to my ears, its just what i had heard of a few sources that it would need it, on this all singing and dancing, electrictronical, swedish techno barge....lol:band:
Post 506075 by deathrider311271 on 2012-06-01 19:25:04
[quote=moleadrian;505824]thats sounds to be music to my ears, its just what i had heard of a few sources that it would need it, on this all singing and dancing, electrictronical, swedish techno barge....lol:band:[/quote] procedure for fitting a second hand ETM: 1 disconect battery (make sure you have radio code) 2 remove pipe to ETM 3 If you have standard air filter box remove it 4 remove 4 bolts holding ETM in place very fidly this bit 5 Remove old gasket 6 now reverse above 7 connect battery 8 switch ignition to the on position but not started, leave it in this position for 20 mins 9 switch off and remove keys lock the car and leave locked for 5 mins 10 open car and go for a decent drive gently using the whole rev range to begin with. 11 now have proper fun job done
Post 508801 by MoleT-5R on 2012-06-07 00:47:42
[quote=deathrider311271;506075]procedure for fitting a second hand ETM: 1 disconect battery (make sure you have radio code) 2 remove pipe to ETM 3 If you have standard air filter box remove it 4 remove 4 bolts holding ETM in place very fidly this bit 5 Remove old gasket 6 now reverse above 7 connect battery 8 switch ignition to the on position but not started, leave it in this position for 20 mins 9 switch off and remove keys lock the car and leave locked for 5 mins 10 open car and go for a decent drive gently using the whole rev range to begin with. 11 now have proper fun job done[/quote] Many thanks job done with yours and wobley dave's help ( and as you said no need to re-flash) back on the road again and not a fault code in-sight Thanks Again, yet another forum success story....lol
Post 508803 by Dangerous Dave on 2012-06-07 00:58:19
Good job, nice one.
Post 508975 by deathrider311271 on 2012-06-07 19:30:19
Good too hear its all worked out for you and at a fraction of the cost of Volvo Simon
Post 508980 by bubba_1986 on 2012-06-07 19:42:22
Glad me and dave could help mate
Post 509343 by Wobbly Dave on 2012-06-08 21:13:48
I was certain that a reflash would have been needed but I am pleased it all turn out well
Post 509352 by deathrider311271 on 2012-06-08 21:35:59
[quote=Wobbly Dave;509343]I was certain that a reflash would have been needed but I am pleased it all turn out well[/quote] when they changed from magnetti marelli system to the bosch system it needs reflashing. If you hadnt guessed i have looked into this a lot lol Simon
Post 509361 by Wobbly Dave on 2012-06-08 22:18:01
I feel for you.
Post 509363 by bubba_1986 on 2012-06-08 22:24:12
Bad luck mate, try volvo, mines was 176 back in 2007. I know we just sold one to other member, these things happen to best of us
Post 509424 by MoleT-5R on 2012-06-09 01:59:09
[quote=Wobbly Dave;509343]I was certain that a reflash would have been needed but I am pleased it all turn out well[/quote] Reading between the lines and threads, it would seem that the information you got for is correct, but at the same time the unit you sold me has been fitted to a car and programmed to work, so when swapped it continues to work. Where as I understand a brand new one has got to be programmed to work, so it seems that if you use second hand units the problem can be bypassed, well in this problem at least.
