Post 521265 by Vinny on 2012-07-06 17:31:07
Tried to install a bosst gauge today and got tangeled up with the mass of wires pipes and other stuff in the engine bay.
Unfortunately i wasnt too careful and pulled the Solenoid valve's tubes out of their places, and cant remember which goes where.
Managed to find out where 2 of them go but not the last one.
1 - goes to the turbo
2- goes to the wastegate actuator
3 - ???
If hose #1 is coming straight from the turbo can i install the boost gauge using that hose?
thank you guys
Post 521267 by oblark on 2012-07-06 17:47:50
[quote=Vinny;521265]Tried to install a bosst gauge today and got tangeled up with the mass of wires pipes and other stuff in the engine bay.
3 - ???
thank you guys[/quote]
Hi, the boost gauge should be plumbed into the inlet manifold, as for the BCS pipework see attached diagram.
Post 521276 by Vinny on 2012-07-06 18:38:07
Thanks oblark. but that diagram doesnt help me b\c the hose that i cant figure where to connect is the one going down from the solenoid in the picture, so cant tell where it goes.
Post 521280 by oblark on 2012-07-06 18:47:52
[quote=Vinny;521276]Thanks oblark. but that diagram doesnt help me b\c the hose that i cant figure where to connect is the one going down from the solenoid in the picture, so cant tell where it goes.[/quote]
That hose should go to the inlet pipework between the MAF and the turbo.
Post 521296 by Vinny on 2012-07-06 19:52:57
Ive got it all connected properly!
Thank you very much.
still got much to learn about my (not so) little volvo. :)
