Oil level rising up dipstick..???
Post 524404 by d2k on 2012-07-16 08:52:15
[COLOR=#000000][FONT=verdana]hi all...[/FONT][/COLOR] [COLOR=#000000][FONT=verdana]thought id just check my oil level out as it does eat a little now & then but to my amazement the level had gone up past the full line & there are streaks of oil running all the way up the dipstick...???[/FONT][/COLOR] [FONT=verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif][COLOR=#000000]is this injector related, & is it damaging the block..??[/COLOR][/FONT]
Post 524407 by M-R-P on 2012-07-16 09:05:29
Is your pcv blocked? Did you wipe the dipstick and re-dip? (it's too early for that to sound wrong lol)
Post 524413 by JUDGENINJA on 2012-07-16 09:24:21
Had you checked it warm or cold? Are you consistent when you check? I believe that if your engine is hot the levels will be higher than when stone cold. If you check directly after running the oil level will be intermittent.. Next question how high did it get?
Post 524426 by d2k on 2012-07-16 10:14:44
right....... im getting the same results hot or cold, with multiple re dips to be sure... its actually sitting about 2mm above the full mark & there's oil smears much higher up, once wiped they return like oil is sitting high up somewhere..?? no engine trobles though cars ticking along perfectly.... how would i check if my PCV system was blocked or blocking..?? is this detrimental if left unchecked.. thanks guys...
Post 524433 by M-R-P on 2012-07-16 10:24:22
If the pcv is blocked and left to get on with it, it can blow your RMS (rear main seal) - crank seal. That's a gearbox and flywheel off job. To check the pcv, go for a drive for 15-20 minutes, pull over and with the engine running, pull the dipstick out. If you get puffs of smoke, like a choo-choo train, then your pcv is blocked. With our cars, there's a 1st point of investigation to try before removing the whole pcv but I'll go into that later, if I need to. Let us know how you get on mate. (P.S. I'll reply to your PMs at some point lol, been a busy weekend)
Post 524437 by d2k on 2012-07-16 10:28:10
thanks again.......... ill get her warmed up see if she wants to puff smoke like Thomas the tank. no worries martin spk soon.
Post 524588 by d2k on 2012-07-16 17:39:49
right... just got my daughter from school... 20 mile round trip, got back, pulled out dipstick while engine was running...... no smoke at all..?? someone else mentioned it could be a sticking injector & the high oil lvl is actually fuel mixing with it... now that sounds real nasty for the engine..??
Post 524620 by M-R-P on 2012-07-16 18:25:37
does the dipstick/oil smell like creosote? if it is fuel mixing with the oil, I can't see it being good.
Post 524627 by oblark on 2012-07-16 18:34:29
[QUOTE=d2k;524588] someone else mentioned it could be a sticking injector & the high oil lvl is actually fuel mixing with it... now that sounds real nasty for the engine..??[/QUOTE] How would a sticking injector put fuel in the sump ?????????
Post 524634 by d2k on 2012-07-16 18:40:45
[QUOTE=martinrpeachey;524620]does the dipstick/oil smell like creosote? if it is fuel mixing with the oil, I can't see it being good.[/QUOTE] it certainly has a solventish smell about it..........
[COLOR=#3E3E3E]How would a sticking injector put fuel in the sump ?????????[/COLOR]
dont know.... im no mechanic cant afford a T5 meltdown, so i'll keep my eye on it.
Post 524645 by oblark on 2012-07-16 18:54:26
[QUOTE=d2k;524634] dont know.... im no mechanic [/QUOTE] You don`t have to be a rocket scientist to work it out :bounce: To get petrol in the sump you would have to lose all the piston rings which would mean you lose the compression on that cylinder. Try dropping the oil out and refilling with fresh oil to the max level and keep a eye on the level. :smile::smile::smile:
Post 524655 by M-R-P on 2012-07-16 19:09:09
Maybe put some flush through (add flush, run, drop oil, fill with cheap fresh oil, run for a bit, drop, fill with good oil) in case there was some sludge clogging something.
