Wishbone/lower arm bushes.
Post 527506 by stribo on 2012-07-27 09:19:58
Does the C70 use the same wishbones as the 850 and S70, as I'm looking to rebush them, and powerflex don't list the C70. :(
Post 527507 by oblark on 2012-07-27 09:21:38
I think they are the same, give me a few mins and I will check :smile:
Post 527511 by M-R-P on 2012-07-27 09:29:22
I'm pretty sure they're the same. Well worth the effort (driving the old ones out with a bench vice is effort, trust me ;))
Post 527513 by oblark on 2012-07-27 09:33:39
Just checked your wishbone part number on partsforvolvosonline and yours are different part number to the 850/V70 so I would say you can`t get poly bushes for yours. It mite be worth looking into swapping the wishbones for 850/V70 ones :smile:
Post 527514 by stribo on 2012-07-27 09:33:58
[QUOTE=martinrpeachey;527511]I'm pretty sure they're the same. Well worth the effort (driving the old ones out with a bench vice is effort, trust me ;))[/QUOTE] I'm I going to have the same sort of problem getting the old top mount bush out, as I don't have a vice.
Post 527528 by partsforvolvos.com on 2012-07-27 10:59:55
The 98-05 C70 uses lower arms with bushes the same design as the diesel and awd R / police variants which is the type with the bar through and 2 eylets holding the arm on. it would not be possible to change them for the other type as the subframe would be different. as far as i am aware, unfortunately nobody makes poly bushes for this design. I am trying to source some standard type replacement bushes for the eyelet design at present to add them to our catalogue which is something that is not readily available.
Post 527529 by partsforvolvos.com on 2012-07-27 11:01:33
[QUOTE=stribo;527514]I'm I going to have the same sort of problem getting the old top mount bush out, as I don't have a vice.[/QUOTE] i believe the best way is to melt it - powerflex normally recommend me this method
Post 527533 by oblark on 2012-07-27 11:26:59
[QUOTE=partsforvolvos.com;527528]The 98-05 C70 uses lower arms with bushes the same design as the diesel and awd R / police variants which is the type with the bar through and 2 eylets holding the arm on. it would not be possible to change them for the other type as the subframe would be different.[/QUOTE] Learn something new everyday.:smile::smile::smile:
Post 527534 by M-R-P on 2012-07-27 11:32:23
Nowt ya can't do with a blowtorch... Image Image Image
Post 527610 by stribo on 2012-07-27 18:02:38
[QUOTE=stribo;527514]I'm I going to have the same sort of problem getting the old top mount bush out, as I don't have a vice.[/QUOTE] [QUOTE=partsforvolvos.com;527529]i believe the best way is to melt it - powerflex normally recommend me this method[/QUOTE] It actually wasn't too difficult, just used a flat bladed screwdriver, and a lump hammer to break up a section, then it popped out.
