Passenger seat won't tip forward.
Post 527546 by stribo on 2012-07-27 13:14:49
As title, I'm guessing the cable's snapped/ come adrift, is this easy to access, and can I get just the cable if it has snapped?
Post 527548 by M-R-P on 2012-07-27 13:32:28
Local scrappy does seats for about 35 quid... http://vehicles.pickapart.uk.com/breaking-vehicles/vehicle-details/volvo/c70/petrol/manual/40078
Post 527576 by stribo on 2012-07-27 17:00:21
The thing is mate, the seat's in really good condition, so would prefer to fix it if possible.
Post 527578 by M-R-P on 2012-07-27 17:06:23
Understandibly, I've seen it my self. you could use the second hand seat for parts. If you need it, the car will be there for about a week. Just gimme a shout and I'll go get it. It probably won't be electrically operated but like I said, use it for parts ;)
Post 527582 by stribo on 2012-07-27 17:12:08
Thanks Martin, I'll try and take mine out tomorrow, to see what the problem is, and let you know. :B_thumb:
Post 527585 by M-R-P on 2012-07-27 17:19:07
I remember Wobbly Dave saying the cable lets - go and needs replacing. Might be worth contacting him?
Post 527589 by bubba_1986 on 2012-07-27 17:27:29
You can buy the cables again from volvo. Contact wobbly as he has two c70 seats behind his shed, came out of c70 we bought and broke. Think mechanisms were good
Post 527591 by stribo on 2012-07-27 17:31:38
[QUOTE=bubba_1986;527589]You can buy the cables again from volvo. Contact wobbly as he has two c70 seats behind his shed, came out of c70 we bought and broke. Think mechanisms were good[/QUOTE] Do you know what's involved in changing the cables?
Post 527831 by Wobbly Dave on 2012-07-29 00:46:18
Yes - you need to take the seat out - unravel the seat cover clip at the bottom of the vertical seat portion (near the hinge) & then spend a while freeing up the old cable & replacing it. I have photos on here from when I did it. Alternatively you can arrange to come here & I will help you with it. Release cables are available still I believe from Volvo.
Post 527838 by stribo on 2012-07-29 06:32:36
[QUOTE=Wobbly Dave;527831]Yes - you need to take the seat out - unravel the seat cover clip at the bottom of the vertical seat portion (near the hinge) & then spend a while freeing up the old cable & replacing it. I have photos on here from when I did it. Alternatively you can arrange to come here & I will help you with it. Release cables are available still I believe from Volvo.[/QUOTE] Thanks for the offer Dave, I'll have a crack at it myself first, if that doesn't work, I may well take you up on it. How long does the battery have to be disconnected before I can unplug the seat?
Post 538872 by peterk007 on 2012-09-29 13:23:24
Hi I've just this moment replaced my passenger seat tilt cable. It was easy to do once I removed the seat from the car. I took it into the house and all I did was unscrew the torx screw that is under the side lever you lift to tilt the seat forward,removed the plastic parts which just popped off after some careful levering. Put my hands under the seat back and popped off the long plastic thing which clips the both parts together, to keep the leather on seat back taut. Sat the seat with head rest on the floor,peeled the leather back as far as it would go to let me see the tilt cable in plea e. only one wire was snapped at the metal S shaped part but just removed the whole thing and replaced with new cable I picked up from taggarts Volvo in Glasgow. Parts had to be ordered from Sweden and as I had to get 2 they were under £20 for both. Replaced my seat back into the car and it's now working perfectly. Was a bit dubious at attempting this myself,but it went very well indeed.!!
Post 538882 by stribo on 2012-09-29 15:28:46
I really must get round to doing this.
Post 542443 by adrianpigott on 2012-10-16 21:49:04
It's an easy fix, has happened to me.
