Saffy C70 T5 GT work in progress.
Post 527597 by V70 Graham on 2012-07-27 17:39:13
Deffo needed that top mount done mate, the induction kit looks good, sorry it wasn't in Orange :smile:
Post 527600 by stribo on 2012-07-27 17:41:38
It sounds awesome mate, nearly as good as the Cougar. ;)
Post 527603 by V70 Graham on 2012-07-27 17:44:24
[QUOTE=stribo;527600]It sounds awesome mate, nearly as good as the Cougar. ;)[/QUOTE]
Go wash your mouth out :nono:
Post 527605 by stribo on 2012-07-27 17:47:16
[QUOTE=V70 Graham;527603]Go wash your mouth out :nono:[/QUOTE]
I still love my Cougar, I've had it longer than I've known Rachel, but it's just not quick enough. :wallbash:
Post 527617 by Relfski on 2012-07-27 18:26:29
Have now officially had a play in the C70 :crazy: Had to prize the keys out of his hands and insurance had been valid for 5 minutes :smileypul
Post 529182 by M-R-P on 2012-08-07 10:19:37
Any more updates on the atacama funbus?
Will we be seeing it on Saturday?
Post 529183 by stribo on 2012-08-07 11:06:11
We were away last weekend, so I didn't get an opportunity to work on it, but it'll be there Saturday. :D
Post 529184 by M-R-P on 2012-08-07 11:11:05
Cool :)
Post 536813 by Kingsford G on 2012-09-14 22:08:03
You getting there.And put that ginger seats in it too lol
Post 536816 by stribo on 2012-09-14 22:11:56
[QUOTE=Kingsford G;536813]You getting there.And put that ginger seats in it too lol[/QUOTE]
Thanks mate, unfortunately they don't do those seats for the C70.
Post 536820 by Kingsford G on 2012-09-14 22:22:46
Joking abouts the seats but would look really nice tho.Have you done a remap yet?
Post 536822 by stribo on 2012-09-14 22:24:57
Not yet, got a BOV to fit first, thought it was a MBC but it turned out it wasn't, so I'll fit it in the interim, but I need the boost gauge working properly first.
Post 536835 by Kingsford G on 2012-09-14 22:48:36
Never had an MBC on suffy as don`t want it go bang if I get p1ssed off and floor it too early but had it on my t5,you do feel it.
Post 536878 by d2k on 2012-09-15 11:47:14
hi Stribo....
could the boost pipes proximity to the manifold be the problem, i know my boost pipe gets very soft when its warmed up by the engine & mine is possibly expanding slightly under pressure... but mine runs along the strut brace on the P2 pretty far away from hot components yet it still suffers....im looking for something to shield it.
yours is VERY close to heated components..???? just a thought. :B_thumb:, though while cold it shouldn't be an issue.
Post 536893 by t5 pete on 2012-09-15 13:31:36
First of remove the T peice and fit the gauge hose to the tree above the throttle body also 100% change the routing best place to have it run is from the vacume tree to the front pannel and all the way around behind the ecu box etc and through the fire wall, also what size pipe is it and is there any strength as a smaller harder pipe will just do the same job and work better
Post 536898 by stribo on 2012-09-15 14:26:37
It's 4mm pipe, but quite soft, I'll try and get some hard stuff. Anyone know the best place to get it? MRP has recommended somewhere, but it's shut this afternoon.
Post 536905 by Harvey on 2012-09-15 15:07:34
Hi just to say 1 bar is 14 psi, I thought most gauges we're in psi. As 2 bar (28 psi)max that is a lot of boost.
What boost is standard on your motor?.
Post 536906 by stribo on 2012-09-15 15:14:47
[QUOTE=Harvey;536905]Hi just to say 1 bar is 14 psi, I thought most gauges we're in psi. As 2 bar (28 psi)max that is a lot of boost.
What boost is standard on your motor?.[/QUOTE]
I'm not sure mate, but it's not showing 2 bar, but 0.2 bar. It's definitely boosting more than that.
Post 536907 by Harvey on 2012-09-15 15:38:28
[QUOTE=stribo;536906]I'm not sure mate, but it's not showing 2 bar, but 0.2 bar. It's definitely boosting more than that.[/QUOTE]
Sorry I did miss the .
Post 536912 by M-R-P on 2012-09-15 16:36:21
Steve, if you bring the saffy tomorrow, I'll have a play, I've got loads of pipe and cable ties (atacama ones too).
I'll get it sorted for ya.;)
Post 536913 by stribo on 2012-09-15 16:59:07
[QUOTE=M-R-P;536912]Steve, if you bring the saffy tomorrow, I'll have a play, I've got loads of pipe and cable ties (atacama ones too).
I'll get it sorted for ya.;)[/QUOTE]
Thanks mate, I'll bring it along. :)
Post 536930 by Shadow on 2012-09-15 20:12:27
if your looking for some good pipe then go to the scrappy and find a mk2/3 golf they have air actuated central lockin and look under the carpet there loads of thin bendy plastic pipe goin from the boot to each door. ihad the same problem with the boost guage in my 480 and it was the hose calapsing under vacuum when it got hot.
Post 536968 by Kingsford G on 2012-09-15 23:32:58
All u need is the right hose and do a propper job,fitted 2 so far no probs at all.Come to esse meet Stribo I`ll do for u.
Post 582422 by stribo on 2013-03-09 14:43:03
I never did an update on my boost gauge problem, it turns out there was a hole in the hose coming from the recirc valve, so once replaced by MRP it was all good.
Right to today, thanks to a tip off from Iancho, I bagged myself some projector headlights off Ebay last week, and set about fitting them today.
So off with old:
A comparison between the two:
And all fitted:
Very happy with them, and as a bonus they've been converted to HID. They came with LEDs in the sidelights, but they were the cheap Ebay ones that MRP's had problems with, and didn't work, so I've put normal bulbs in for now, but will be getting some better LEDs for them, and I've got some chrome indicator bulbs coming.
Post 582423 by V70 Graham on 2013-03-09 14:51:26
Very nice Steve, makes the car look a lot newer, can I ask if your happy with the HID's ? What temperature are the bulbs ?
Now PLEASE sort out that dirty, nasty number plate !
Post 582424 by Wobbly Dave on 2013-03-09 14:59:08
What bulbs are you using? I recommend getting some LED side lights - to make the colour match you dipped beam.
Post 582425 by stribo on 2013-03-09 15:01:12
[QUOTE=V70 Graham;582423]Very nice Steve, makes the car look a lot newer, can I ask if your happy with the HID's ? What temperature are the bulbs ?
Now PLEASE sort out that dirty, nasty number plate ![/QUOTE]
I haven't tried the HIDs in the dark yet so don't know what they're like. They're a bit blue, so I'm guessing 6000K. The number plate will be done soon. :P Oh and my headlights height adjust electrically :D
Post 582426 by stribo on 2013-03-09 15:03:20
[QUOTE=Wobbly Dave;582424]What bulbs are you using? I recommend getting some LED side lights - to make the colour match you dipped beam.[/QUOTE]
The sidelight bulbs I have put in for the moment are nicked out of the door marker lights, I'll be getting some LEDs when I can find some blueish ones.
Post 582428 by V70 Graham on 2013-03-09 15:31:16
[QUOTE=stribo;582425]I haven't tried the HIDs in the dark yet so don't know what they're like. They're a bit blue, so I'm guessing 6000K. The number plate will be done soon. :P Oh and my headlights height adjust electrically :D[/QUOTE]
How do yours adjust, did you swap the motors over ?
Post 582431 by stribo on 2013-03-09 15:54:01
Nope, had motors on them. :)
Post 582435 by Brett855tdi on 2013-03-09 16:14:23
[video=youtube;9mPtKgX370k]http://www.youtube.com/watch?v=9mPtKgX370k[/video](In Boris voice) Very Nice!
Post 582453 by M-R-P on 2013-03-09 17:04:54
Good job there Steve, I have some blue - ish LED sidelights going spare of you want them?
Post 582454 by T5frankie on 2013-03-09 17:08:32
nice mate, i think the yellowish sidelights look better as they match the cars paint
Post 582455 by stribo on 2013-03-09 17:08:35
[QUOTE=M-R-P;582453]Good job there Steve, I have some blue - ish LED sidelights going spare of you want them?[/QUOTE]
Thanks mate, Graham has some he's going to let me have.
Post 582466 by Brett855tdi on 2013-03-09 18:15:42
Are these light just down to finding a set going on the flea bay? i guess unless they are jap, aus or uk they will be the wrong ones?
Post 582471 by V70 Graham on 2013-03-09 18:26:08
[QUOTE=Brett855tdi;582466]Are these light just down to finding a set going on the flea bay? i guess unless they are jap, aus or uk they will be the wrong ones?[/QUOTE]
You can get them from PFV
Post 582547 by iancho on 2013-03-09 20:29:46
Glad your pleased with them Steve they were a steal at that price... Good job you told me you were after some at the RR day. They look a lot better mate! :B_thumb:
Post 582552 by oblark on 2013-03-09 20:38:58
Looking good :) are you still going to the pompey dyno ?
Post 582582 by stribo on 2013-03-09 21:04:43
[QUOTE=oblark;582552]Looking good :) are you still going to the pompey dyno ?[/QUOTE]
Hope to.
Post 582992 by stribo on 2013-03-10 22:26:38
Just taken a pic with the lights on in the dark, the headlights don't look quite as blue.
Post 582996 by M-R-P on 2013-03-10 22:30:40
You could always swap them round and use the HIDs for full beam and the normal bulbs for dipped (same fitment)
Post 582998 by stribo on 2013-03-10 22:34:36
[QUOTE=M-R-P;582996]You could always swap them round and use the HIDs for full beam and the normal bulbs for dipped (same fitment)[/QUOTE]
As discussed earlier in the thread, they take too long to warm up for full beam mate.
Post 583000 by stribo on 2013-03-10 22:36:26
[QUOTE=iancho;582547]Glad your pleased with them Steve they were a steal at that price... Good job you told me you were after some at the RR day. They look a lot better mate! :B_thumb:[/QUOTE]
I love them mate, thanks for letting me know about them. Just goes to show, it's always worth going to meets. :D
Post 583004 by M-R-P on 2013-03-10 22:44:02
[QUOTE=stribo;582998]As discussed earlier in the thread, they take too long to warm up for full beam mate.[/QUOTE]
Once they've been on for a while, they fire-up straight away after dipping them. And as for flashing people - through, mine start with a full light for about half a second, which seems to be enough.
Post 583034 by Kingsford G on 2013-03-10 23:50:37
Me want some nice lights cheap too
Post 583062 by V70 Graham on 2013-03-11 05:30:23
Looking good Steve, how do you find them when driving ?
Post 583067 by iancho on 2013-03-11 05:37:15
[QUOTE=stribo;583000]I love them mate, thanks for letting me know about them. Just goes to show, it's always worth going to meets. :D[/QUOTE]
Yeah it really does pay off Steve and the memories are even better! :)
Kingsford i will keep an eye out for you matey!
Post 583075 by stribo on 2013-03-11 06:55:35
[QUOTE=V70 Graham;583062]Looking good Steve, how do you find them when driving ?[/QUOTE]
Still haven't driven in the dark with them.
Post 583082 by M-R-P on 2013-03-11 08:05:16
[QUOTE=V70 Graham;583062]Looking good Steve, [COLOR="#B22222"]how do you find them[/COLOR] when driving ?[/QUOTE]
Round the front of the car - you can't miss them ;)
Post 583087 by V70 Graham on 2013-03-11 09:19:59
[QUOTE=M-R-P;583082]Round the front of the car - you can't miss them ;)[/QUOTE]
Clever b0ll0x !
Post 583149 by martybelfastt5 on 2013-03-11 14:41:53
looking good!
Post 583544 by stribo on 2013-03-12 19:23:13
Just a quick update to keep Graham happy, these arrived today.:D
Post 583545 by oblark on 2013-03-12 19:25:31
Aussie number plates :)
Post 583546 by V70 Graham on 2013-03-12 19:26:48
[QUOTE=stribo;583544]Just a quick update to keep Graham happy, these arrived today.:D
[/QUOTE]
There no good mate, they are upside down lol, now get 'em fitted for Saturday.
Post 583552 by stribo on 2013-03-12 19:34:07
Just a quick update to keep V70Graham happy, these arrived today:
Post 583695 by iancho on 2013-03-13 06:43:59
Looking good Steve, I love your username at the bottom! :B_thumb:
Post 583708 by M-R-P on 2013-03-13 08:24:51
'Bout time!
Post 583725 by stribo on 2013-03-13 10:05:49
[QUOTE=M-R-P;583708]'Bout time![/QUOTE]
:finger:
Post 584114 by Knight Rider on 2013-03-14 17:48:02
[QUOTE=stribo;583552]Just a quick update to keep V70Graham happy, these arrived today:
[/QUOTE]
Where did you get these done? as my plates are in an even worse state than your originals
Post 584176 by V70 Graham on 2013-03-14 19:44:44
[QUOTE=Knight Rider;584114]Where did you get these done? as my plates are in an even worse state than your originals[/QUOTE]
I think he got them from the same place I did, fast delivery too.....
http://www.ebay.co.uk/itm/300664495522
Post 584215 by stribo on 2013-03-14 20:09:34
That's the place, though mine were £15.95, looks like they've dropped there prices.:slap::slap:
Post 584225 by V70 Graham on 2013-03-14 20:23:06
[QUOTE=stribo;584215]That's the place, though mine were £15.95, looks like they've dropped there prices.:slap::slap:[/QUOTE]
There's always someone worse off than yourself.....I bought a set for the VAG as well as the Volvo, both @ £15.95 !
Post 584227 by stribo on 2013-03-14 20:24:09
Bloody typical :lol:
Post 584241 by Kingsford G on 2013-03-14 20:45:03
[QUOTE=V70 Graham;584225]There's always someone worse off than yourself.....I bought a set for the VAG as well as the Volvo, both @ £15.95 ![/QUOTE]
Now u mentioned it I have an idea
Post 605250 by oblark on 2013-05-12 20:33:39
looking good :)
Post 605252 by Sharkey R on 2013-05-12 20:34:48
Looks awesome now she's slammed :)
Post 605254 by V70 Graham on 2013-05-12 20:39:28
She's looking good mate, remember to get that tracking done when you have time
Post 605263 by stribo on 2013-05-12 20:47:31
[QUOTE=V70 Graham;605254]She's looking good mate, remember to get that tracking done when you have time[/QUOTE]
Will be done after I finish work tomorrow. ;)
Post 605265 by WOODY T5 on 2013-05-12 20:49:04
setting nice mate well done wot kit is it
Post 605271 by Wobbly Dave on 2013-05-12 20:53:42
what's with the difference in coil thickness on the front?
Post 605361 by iancho on 2013-05-13 04:55:11
Sits nice now Steve and much better with the strut brace :)
Post 605382 by c70geoff on 2013-05-13 09:17:49
looks good but i'm with dave, what is with what looks like 2 spring sizes on front
Post 605406 by stribo on 2013-05-13 11:56:36
Don't know, that's how they came.
Post 605412 by c70geoff on 2013-05-13 12:37:34
what make are they fella?
Post 605413 by partsforvolvos.com on 2013-05-13 12:43:01
[QUOTE=Wobbly Dave;605271]what's with the difference in coil thickness on the front?[/QUOTE]
they have a helper spring to stop the possibility of the seat moving down i think - all ride height adjustable coilovers i have seen are like this. - the kw ones i fitted had it as well.
Post 605419 by stribo on 2013-05-13 13:16:11
[QUOTE=c70geoff;605412]what make are they fella?[/QUOTE]
They're Pro Sport Geoff.(and Dean)
Post 605554 by Jamest5r on 2013-05-13 20:08:42
Let me know how you get on with them please interested in the feed back
Post 605584 by stribo on 2013-05-13 20:50:19
Will do mate, just don't expect much in the way of ride comfort. ;)
Post 605588 by V70 Graham on 2013-05-13 21:04:42
[QUOTE=stribo;605584]Will do mate, just don't expect much in the way of ride comfort. ;)[/QUOTE]
Ya need to eat summat, get some flesh on ya butt cheeks lol
Post 605591 by Kingsford G on 2013-05-13 21:21:16
[QUOTE=V70 Graham;605588]Ya need to eat summat, get some flesh on ya butt cheeks lol[/QUOTE]
I need that upgrade too lol
Post 605595 by Jamest5r on 2013-05-13 21:24:32
Air suspension seat in the Truck so can live with a harsh ride every mow and then :)
Post 605596 by stribo on 2013-05-13 21:24:55
You've got enough for both of us.
Post 605603 by c70geoff on 2013-05-13 21:31:06
i may be buying these in the next few days
Post 605613 by stribo on 2013-05-13 21:40:28
[QUOTE=c70geoff;605603]i may be buying these in the next few days[/QUOTE]
It would be a good idea to get some new top mounts all round as well.
Post 607670 by stribo on 2013-05-18 21:24:31
A small addition sourced from D5Kerry.
Post 607677 by V70 Graham on 2013-05-18 21:31:59
Car is looking good Steve, nice badge btw
Post 607849 by iancho on 2013-05-19 06:56:22
Get them Pegs on Steve :smile:
Post 644151 by stribo on 2013-09-14 17:04:11
I bought a Ferrita exhaust, and downpipe for the C70 (more of which in a seperate thread) anyway the guy also had an eggcrate grille, which I got for a very good price, as most the fixing pins were broken, so I took them out of my old grille, gave it a clean up, and this is how it looks:
Post 644154 by Tomcat on 2013-09-14 17:09:22
Looking very nice!..
Post 644171 by V70 Graham on 2013-09-14 17:54:57
Grill suits it IMHO when's the exhaust going on then ?
Post 644172 by graemewelch on 2013-09-14 18:02:21
Very gay!!!
Post 644176 by tichai on 2013-09-14 18:14:17
That grille looks sooo much better than the original
Post 644177 by stribo on 2013-09-14 18:17:30
[QUOTE=graemewelch;644172]Very gay!!![/QUOTE]
If you're looking for a bite, you'll have to 'hop' onto a different thread. :P
Post 644180 by stribo on 2013-09-14 18:18:22
[QUOTE=V70 Graham;644171]Grill suits it IMHO when's the exhaust going on then ?[/QUOTE]
Not sure yet, I may have problems, will be putting up a seperate thread about it.
Post 644227 by merc85 on 2013-09-14 19:37:07
Looking ace buddy,and I love those headlights sooo much i may have to get a v70 lol ;)
Post 644235 by stribo on 2013-09-14 19:56:24
[QUOTE=merc85;644227]Looking ace buddy,and I love those headlights sooo much i may have to get a v70 lol ;)[/QUOTE]
Thanks mate, just don't go selling your 850 to get one.;)
Post 644244 by T5frankie on 2013-09-14 20:06:11
everyone has got them now mate, boring
Post 644258 by stribo on 2013-09-14 20:19:05
[QUOTE=T5frankie;644244]everyone has got them now mate, boring[/QUOTE]
Same as all Volvo estates. :P
Post 644259 by merc85 on 2013-09-14 20:20:38
[QUOTE=stribo;644258]Same as all Volvo estates. :P[/QUOTE]
Oi oi lol
Post 644260 by LiamT4 on 2013-09-14 20:20:41
Have you thought about getting an "R" front bumper? Looks good on the convertible that s70t5chris has.
Post 644261 by merc85 on 2013-09-14 20:23:03
[QUOTE=LiamT4;644260]Have you thought about getting an "R" front bumper? Looks good on the convertible that s70t5chris has.[/QUOTE]
Yeah i reckon they look good on the c70's :biggrin:
Post 644262 by merc85 on 2013-09-14 20:25:01
[QUOTE=stribo;644235]Thanks mate, just don't go selling your 850 to get one.;)[/QUOTE]
LOL i could just get a Black v70 and take the front off it and stick it on the 850 lol
Post 644275 by stribo on 2013-09-14 20:54:49
I'm not keen on the R bumpers on C70s, they're quite square, which doesn't match the curved lines of the car. Think they look great on the S/V70 though.
Post 644288 by rikcougar on 2013-09-14 21:15:28
Just read through all this Steve
Car looks bloody spiffing old chap
Have to tag along to a meet next year and catch up
Post 644292 by stribo on 2013-09-14 21:19:13
Thanks Rik, after the Cougar, it was never going to stay standard for long. Be good to catch up with you sometime, there's always the Christmas do, once it's sorted. ;)
Post 644299 by oblark on 2013-09-14 21:21:42
[QUOTE=stribo;644275]I'm not keen on the R bumpers on C70s, they're quite square, which doesn't match the curved lines of the car. Think they look great on the S/V70 though.[/QUOTE]
What about this one then :)
http://carsfolia.com/icim/volvo-c70-t5/volvo-c70-t5-10.jpg
Post 644303 by stribo on 2013-09-14 21:23:16
Oh yes, I like that. :D
Post 644312 by merc85 on 2013-09-14 21:37:15
They all looks miles better than the standard bumper, I really like the R bumper on that saffy :)
Post 644344 by Wobbly Dave on 2013-09-14 22:42:10
[QUOTE=oblark;644299]What about this one then :)
http://carsfolia.com/icim/volvo-c70-t5/volvo-c70-t5-10.jpg[/QUOTE]
Now that I like & I think it goes.
Shame you can't tell who sells it.
eggy grill looks good Steve.
Post 644345 by stribo on 2013-09-14 22:45:44
[QUOTE=Wobbly Dave;644344]Now that I like & I think it goes.
Shame you can't tell.
EG grill looks good Steve.[/QUOTE]
Thanks Dave, doesn't make the car any quicker, hopefully the exhaust and DP will.:D
Post 644346 by graemewelch on 2013-09-14 22:55:32
[QUOTE=stribo;644345]Thanks Dave, doesn't make the car any quicker, hopefully the exhaust and DP will.:D[/QUOTE]
car might be quicker but the driver will prob be just as slow :funkybana
Post 644360 by stribo on 2013-09-15 07:31:20
Nothing slow about this driver mate, just ask Frankie.;)
Post 644503 by AndysR on 2013-09-15 18:33:50
Never been a fan of the R bumper on the C70 simply for the same reasons Stribo mentions earlier and that first one looks simply shocking! Leave it as it is they look good with the standard set up, grille looks excellent and modernises the front end nicely :)
Post 644548 by stribo on 2013-09-15 20:39:41
[QUOTE=AndysR;644503]Never been a fan of the R bumper on the C70 simply for the same reasons Stribo mentions earlier and that first one looks simply shocking! Leave it as it is they look good with the standard set up, grille looks excellent and modernises the front end nicely :)[/QUOTE]
Thanks mate, I have plans for my front bumper, but it's quite a way down the list at the moment.;)
Post 646125 by stribo on 2013-09-22 20:33:46
So another week, another mod. Today was exhaust day, although not the downpipe, as that's a bit more involved. Took a couple of hours altogether, getting the old one out was the hard part, as it's one piece, and runs over the rear suspension, so I had to cut the rear hangers off, then undid the bottom shock mount, and dropped the suspension as far as possible, and I just managed to wriggle it out. Fitting the replacement Ferrita was a piece of cake, as it comes in 2 pieces, and is split above the suspension, so I could fit the front half from the front, then slide the rear part on from the rear of the car.
Comparison pics:
A couple of pics of it fitted:
It has more of a rumble at low revs, then as the revs rise the induction noise takes over, should sound even better once the DP with sports cat is fitted.
Post 646126 by graemewelch on 2013-09-22 20:37:44
wait till the down pipe is one. the note will change again. what you doing with old exhaust. is it for sale or can it be loaned out
Post 646130 by stribo on 2013-09-22 20:47:15
[QUOTE=graemewelch;646126]wait till the down pipe is one. the note will change again. what you doing with old exhaust. is it for sale or can it be loaned out[/QUOTE]
How about a part exchange for a S60R DP with 200 cell cat? ;)
Post 646133 by graemewelch on 2013-09-22 20:51:21
got to love a trier. i can do you a good price on a down pipe. pm me and try me you might be suprised
Post 646231 by iancho on 2013-09-23 06:38:08
The whole car is looking sweet Steve, nice work matey :)
Post 647612 by V70 Graham on 2013-09-28 08:42:05
Good work, as always Steve.
Post 647931 by stribo on 2013-09-28 21:17:31
What with C70Geoff going for a C70 R with his front bumper, I thought I'd try the same thing, but inside, so today I fitted this:
Not as obvious as Geoffs, but a start.
Post 647933 by c70geoff on 2013-09-28 21:21:26
very swish my friend looking for a set myself
dial dials look sweet
this is turning into a mod off lol
any issues with any of the dials?
Post 647934 by stribo on 2013-09-28 21:22:57
[QUOTE=c70geoff;647933]very swish my friend looking for a set myself
any issues with any of the dials?[/QUOTE]
Certainly is mate, still got a set of Pegs to go on yet. ;)
Post 647935 by c70geoff on 2013-09-28 21:24:35
ooooo nice
i'm looking for rear bumper mud flaps but have been told they are very very rare
Post 647938 by stribo on 2013-09-28 21:29:38
[QUOTE=c70geoff;647935]ooooo nice
i'm looking for rear bumper mud flaps but have been told they are very very rare[/QUOTE]
Yeah good luck finding them, they do look good though.
Post 647939 by c70geoff on 2013-09-28 21:30:36
oooooo they do look luverly
Post 647941 by Biff on 2013-09-28 21:34:49
The dials are a straight swop Geoff, really easy to do.
Looking well Steve but I'm a bit biased on the colour. Lol
Post 647947 by stribo on 2013-09-28 21:42:13
[QUOTE=Biff;647941]The dials are a straight swop Geoff, really easy to do.
Looking well Steve but I'm a bit biased on the colour. Lol[/QUOTE]
I took mine apart and swapped dial faces and needle over, that way I still have the correct mileage. A suggestion from MRP, and recommended by S70T5Chris.
Post 647954 by Biff on 2013-09-28 21:50:44
[QUOTE=stribo;647947]I took mine apart and swapped dial faces and needle over, that way I still have the correct mileage. A suggestion from MRP, and recommended by S70T5Chris.[/QUOTE]
I had to do that as the replacement clocks I got off kg were standard grey t5 clocks. I buggered up on my temp gauge though, although it reads correct it rests at 20 to when the ignition is off. :(
Recomend sticking some LEDs in too, mine look lovely at night.
Post 647960 by stribo on 2013-09-28 21:59:13
That's the only problem with the dials, you can't see what colour they are at night, because they're backlit. The S60R dials still look blue at night, because they're shiny, and frontlit.
Post 647972 by Biff on 2013-09-28 22:10:27
[QUOTE=stribo;647960]That's the only problem with the dials, you can't see what colour they are at night, because they're backlit. The S60R dials still look blue at night, because they're shiny, and frontlit.[/QUOTE]
Mine are backlit a very subtle ice blue which contrasts well with the orange needles. Worked out about £6 for the LEDs too.
Post 647981 by stribo on 2013-09-28 22:23:19
[QUOTE=Biff;647972]Mine are backlit a very subtle ice blue which contrasts well with the orange needles. Worked out about £6 for the LEDs too.[/QUOTE]
I had el glow ones in the Cougar in blue:
The problem with that is you have to change all the other dash bulbs/LEDs.
Post 647984 by Biff on 2013-09-28 22:29:40
[QUOTE=stribo;647981]I had el glow ones in the Cougar in blue:
The problem with that is you have to change all the other dash bulbs/LEDs.[/QUOTE]
They do look really well, that couger on the face is awesome!
I was lucky with mine, it doesn't look out of place with the switches.
Post 657350 by stribo on 2013-10-31 19:43:06
New turbo came today:
They'll be no stopping me now, should get low 14's now I've got a 12T ;)
Post 657352 by V70 Graham on 2013-10-31 19:45:09
It's no good to you on the kitchen table mate.
Post 657354 by stribo on 2013-10-31 19:46:30
That's why it's on the coffee table. ;)
Post 657370 by smithy on 2013-10-31 20:50:08
[QUOTE=stribo;657354]That's why it's on the coffee table. ;)[/QUOTE]
A 12t ermmmm I think you mean an 18t
Post 657371 by V70 Graham on 2013-10-31 20:53:58
[QUOTE=smithy;657370]A 12t ermmmm I think you mean an 18t[/QUOTE]
No he doesn't.....he really has just bought a 12t
Post 657372 by stribo on 2013-10-31 21:00:28
Yep, it's definitely a 12T.
Post 657373 by smithy on 2013-10-31 21:02:58
Why buy a turbo off an lpt 2.5 is the question then
Post 657374 by stribo on 2013-10-31 21:04:32
Because it has an angle flange to suit my DP.
Post 657377 by smithy on 2013-10-31 21:14:48
[QUOTE=stribo;657374]Because it has an angle flange to suit my DP.[/QUOTE]
Ok but the turbo is a lot small than yours or are you going to fit your 16t compressor housing on the angled flange exhaust housing .
Post 657378 by V70 Graham on 2013-10-31 21:22:28
[QUOTE=smithy;657377]Ok but the turbo is a lot small than yours or are you going to fit your 16t compressor housing on the angled flange exhaust housing .[/QUOTE]
I think that's his plan, then whack on the dp......he should be up somewhere near your 140bhp then lol
Post 657382 by stribo on 2013-10-31 21:39:21
Yep, just swapping flanges over.
Post 657385 by Kingsford G on 2013-10-31 21:41:29
So u gonna make it as fast as the R?
Post 657388 by stribo on 2013-10-31 21:43:08
I'm trying, but I keep making the R faster too.
Post 657632 by iancho on 2013-11-02 04:23:29
I like the way your thinking Steve! :B_thumb:
Post 657662 by Biff on 2013-11-02 09:55:01
Tidy dude, should be rocking the quarter next year.
Fair few people building sleepers for next year.
I will be spectating. Lol
Post 679580 by stribo on 2014-01-11 17:25:02
As the weather was being kind today, I thought I'd do some work on the car. It didn't go well, I planned on fitting a RIP kit I got, but it's for a ME7, I thought I'd be able to use the existing hose that fits on the throttle body, but it angles upwards, so is no good. Back to the drawing board.
The coilovers have been noisy ever since I fitted them, there's a 'twanging' sound when the wheels are turned left, or right, so I thought I'd see if I could find the problem. Having stripped one side out, the only thing I could see that could be causing the noise, is where the assister spring and main spring meet each other, they must twang as they run over each other, so no joy there either.
To cheer myself up from having a wasted afternoon, and because the front tyres are almost down to their limit, I fitted then Pegs that have been cluttering up my garage (along with the tyres). So off I go to the tyre place to get the new tyres I already have fitted, whilst queuing I suddenly realise I can't remember putting the locking wheel bolt key back in the car. :slap: I get home, and can't find it anywhere even though I remember taking it off the last wheel I put on, I can't remember seeing it after that. Dementia is obviously taking a hold. :(
Anyway even though they're quite tatty at the moment (they're being refurbed in the spring) they don't look too bad. :D
Oh and the front brake pads haven't got much meat left on them, so I'll be ordering some Ferodo DS2500s.
Post 679592 by V70 Graham on 2014-01-11 17:36:10
Shame the day didn't go quite how you wanted.....but the wheels look good.
Post 679597 by Jamest5r on 2014-01-11 17:41:07
The pegs look great on that, first bit of sunshine in 6 weeks and everybody's out with their cars lol
Post 679600 by merc85 on 2014-01-11 17:42:57
Wheels looking smart, i had a nightmare with my locking wheel nut key it got sooo worn, ive gone back to normal bolts now.
Post 679606 by stribo on 2014-01-11 17:54:10
[QUOTE=merc85;679600]Wheels looking smart, i had a nightmare with my locking wheel nut key it got sooo worn, ive gone back to normal bolts now.[/QUOTE]
Had the same problem with the R, mine works fine, if I can find it.
Post 679622 by Biff on 2014-01-11 18:11:59
Big fan of my ferrodo's Steve, I do recommend!
Wheels look tidy mate, I keep looking at mine & wanting a change. :)
Post 679625 by stribo on 2014-01-11 18:15:16
[QUOTE=Biff;679622]Big fan of my ferrodo's Steve, I do recommend!
Wheels look tidy mate, I keep looking at mine & wanting a change. :)[/QUOTE]
Yeah, I've heard good things about the Ferodos, and they've got to be better than whatever pads are in there, as they've only lasted 18 months and let me down badly at Silverstone. Rnash has some nice Nebs for sale at the moment. ;)
Post 679641 by oblark on 2014-01-11 18:44:27
[QUOTE=stribo;679625]Yeah, I've heard good things about the Ferodos, and they've got to be better than whatever pads are in there, as they've only lasted 18 months and let me down badly at Silverstone. Rnash has some nice Nebs for sale at the moment. ;)[/QUOTE]
I`ve found that the Ferodes take a few miles of braking to get the pads up to temp, when the pads are cold the brakes are ££££
Post 679669 by stribo on 2014-01-11 19:45:13
[QUOTE=oblark;679641]I`ve found that the Ferodes take a few miles of braking to get the pads up to temp, when the pads are cold the brakes are ££££[/QUOTE]
I've used EBC Red Stuff previously, and they're pretty much the same.
Post 679672 by LiamT4 on 2014-01-11 19:51:10
[QUOTE=stribo;679669]I've used EBC Red Stuff previously, and they're pretty much the same.[/QUOTE]
I found the ferodo's much worse than the red stuff when cold. In fact when I had ds25s on, many years ago (so maybe they are better now), and my mate was borrowing the car, I actually warned him to be careful when they were cold.
They were good once warmed up though.
Post 679676 by munster732 on 2014-01-11 19:56:00
Did you really just say that, with some delicious new 18 in wheels fitted?
Please say I misunderstood fer fecks sake Gav!!!
Post 679692 by Biff on 2014-01-11 20:27:43
They do need warming up but it really doesn't take much to get some heat in them. ;)
As for the nebs, I'm going to be boring & stick to 17's as I can't be trusted with big wheels & skinny tyres! Lol
Post 679705 by stribo on 2014-01-11 20:51:37
[QUOTE=Biff;679692]They do need warming up but it really doesn't take much to get some heat in them. ;)
As for the nebs, I'm going to be boring & stick to 17's as I can't be trusted with big wheels & skinny tyres! Lol[/QUOTE]
Do what I've done then, big wheels with wide tyres (235/35/18) :D
Post 679746 by Wobbly Dave on 2014-01-11 23:54:56
Not a massive fan of pegs on the C70 for the same reason that I am not keen on the R bumper. That said they don't look that bad.
As far as the ME7 RIP kit goes - you can cut & shut the tube....
[ATTACH=CONFIG]23492[/ATTACH]
Post 679764 by stribo on 2014-01-12 07:28:43
[QUOTE=Wobbly Dave;679746]Not a massive fan of pegs on the C70 for the same reason that I am not keen on the R bumper. That said they don't look that bad.
[ATTACH=CONFIG]23492[/ATTACH][/QUOTE]
The problem with that is there's no port for the ICV pipe.
Post 679787 by Wobbly Dave on 2014-01-12 11:06:32
The thing that is blanked off in the picture above?
Post 679788 by T5frankie on 2014-01-12 11:09:38
[QUOTE=stribo;679705]Do what I've done then, big wheels with wide tyres (235/35/18) :D[/QUOTE]
good luck with tight turns then lol my 225's rub alot on full lock
Post 679792 by stribo on 2014-01-12 11:30:35
[QUOTE=T5frankie;679788]good luck with tight turns then lol my 225's rub alot on full lock[/QUOTE]
Yeah, they'll rub a bit, but will probably fit spacers.
Post 679793 by T5frankie on 2014-01-12 11:35:57
[QUOTE=stribo;679792]Yeah, they'll rub a bit, but will probably fit spacers.[/QUOTE]
the tyres are just too big mate, i has to fit 215 35 19's in the end, are yours 18's then?
Post 679802 by stribo on 2014-01-12 11:54:46
Yeah, 235/35/18
Post 679803 by stribo on 2014-01-12 11:57:05
[QUOTE=Wobbly Dave;679787]The thing that is blanked off in the picture above?[/QUOTE]
Ah, I thought that was part you cut off, I'll have to have a look when I change the intercooler.
Post 679845 by stribo on 2014-01-12 16:37:32
Got the new tyres fitted today:
The ride isn't bad as I expected considering they only a 35 profile, but they don't fill the arches as much now. :(
On the plus side they should help acceleration. ;)
Post 679847 by oblark on 2014-01-12 16:40:58
Could they lift the car any higher ???? :)
Post 679853 by graemewelch on 2014-01-12 16:51:26
[QUOTE=stribo;679764]The problem with that is there's no port for the ICV pipe.[/QUOTE]
i drew up the hose and ive got quotes to get it made. just never got around to it. tomany other things on the go
Post 679868 by stribo on 2014-01-12 17:15:54
What I need is the hose with the smaller one attached, as in the photo.:
http://www.partsforvolvosonline.com/popup_large_image.php?pID=8204
Post 679872 by WOODY T5 on 2014-01-12 17:20:53
Looks very nice mate keep up the great work p.s wot tyre make did u go for!
Post 679875 by stribo on 2014-01-12 17:25:45
[QUOTE=WOODY T5;679872]Looks very nice mate keep up the great work p.s wot tyre make did u go for![/QUOTE]
They're Contis mate, got the bargain of the century off a mate of Graeme Welchs, all 4 for £200, the bloke at the tyre place said they charge £212 for 1. :D
Post 679892 by graemewelch on 2014-01-12 17:47:46
i was going to get these hoses made up. ive got quotes for all the tooling. just never got them made due to not having funds available
URL=http://s1240.photobucket.com/user/gwexhausts/media/20140112_164918_zps1a04831f.jpg.html]
[/URL]
Post 680025 by AAnickmac on 2014-01-12 23:56:28
its looking realy good with those wheels. i need to see what your exhaust sounds like before i decide what to do with mine. got any vids or sound clips?
Post 680041 by stribo on 2014-01-13 07:06:22
[QUOTE=AAnickmac;680025]its looking realy good with those wheels. i need to see what your exhaust sounds like before i decide what to do with mine. got any vids or sound clips?[/QUOTE]
I haven't, but I can make a vid for you.
Post 680046 by iancho on 2014-01-13 07:59:27
Looks much better with the 18's on now Steve, I'm really enjoying catching up on this thread mate. Well done it's a good read! :smile:
Post 689746 by stribo on 2014-02-16 11:50:09
Got a spare few minutes this morning so fitted the gearknob I got from Siamblue. The old one put up a bit of a fight, and I couldn't pull it off, so I twisted it until the locating tab broke, then it popped off quite easily. Luckily the new one is held on with grub screws. :)
Just going to see if I can find a black gaiter now.
Post 689747 by V70 Graham on 2014-02-16 11:55:03
Nice Knob, nob.
Post 689748 by graemewelch on 2014-02-16 11:59:07
Just going to see if I can find a black gaiter now.[/QUOTE]
get some black dye. Thatll sort it
Post 689753 by oblark on 2014-02-16 13:46:56
[QUOTE=stribo;689746]Got a spare few minutes this morning so fitted the gearknob I got from Siamblue. The old one put up a bit of a fight, and I couldn't pull it off, so I twisted it until the locating tab broke, then it popped off quite easily. Luckily the new one is held on with grub screws. :)
Whats that worth...........1-2 bhp :)
Post 689755 by stribo on 2014-02-16 14:07:08
[QUOTE=graemewelch;689748]Just going to see if I can find a black gaiter now.[/QUOTE]
get some black dye. Thatll sort it[/QUOTE]
Which would be best, as I don't think it's proper leather, so I guess leather dyd wouldn't work.
[QUOTE=oblark;689753]Whats that worth...........1-2 bhp :)[/QUOTE]
That's going to speed up my gear changes by 0.00000000000000000000000001 seconds. ;)
Post 689817 by AndysR on 2014-02-16 18:47:11
Gear knob looks good and I don't think it looks that out of place against the gaiter tbh.. :)
Post 695569 by stribo on 2014-03-16 20:56:28
So the latest mod was supposed to be just a do88 intercooler, but because of the rad springing a leak when the new intercooler was fitted, I bought a do88 rad as well.
After everything was stripped out:
Needless to say the old radiator put up a fight when I was trying to remove it, and the captive threaded bosses came away from the front cross member, so it all had to be cut off, but the new one went on easily with new stainless nuts and bolts:
Next up was the intercooler and air con radiator/condensor:
Again, not simple, as with the new radiator, and intercooler, therewasn't enough clearance for the air con rad, so after a little surgery, I had enough clearance:
Next up a bit of surgery to the front panel, from this:
To this:
Also relocated the horns:
Got it all back together, and once the starting problem was sorted, bled the cooling system, and topped up with oil. So with all the shiny shiny I've fitted, it looks like this:
Yep, you can't see any of it :slap: but hopefully with the other mods in the pipeline, it'll help, and to be fair, anyone who'e fitted a set of forged rods or pistons, or other internals can't see them anyway, just knowing they're there is what matters, along with how they perform.
Next up, RIP kit. :D
Post 695574 by Jim S70R on 2014-03-16 21:05:17
Nicely done, great work!!
Post 695603 by Kingsford G on 2014-03-16 22:24:08
Well done mate,good mods there.
Post 695645 by artfulflounder on 2014-03-17 07:16:21
Great work.....those bits look very high quality.
Post 695655 by V70 Graham on 2014-03-17 08:32:57
Nice work, glad it all worked out ok.
Post 695668 by munster732 on 2014-03-17 09:53:46
Will be doin the intercooler fit this weekend, the TNS one is even thicker than the Do88 one so to save hassle and time we will prob remove the air con rad. I know it will all fit but it's a ball ache as there is less room than on an 850 and there is problems with headlamp wiper/fan shroud clearance I'm told with the TNS.
Post 695677 by stribo on 2014-03-17 10:22:13
[QUOTE=munster732;695668]Will be doin the intercooler fit this weekend, the TNS one is even thicker than the Do88 one so to save hassle and time we will prob remove the air con rad. I know it will all fit but it's a ball ache as there is less room than on an 850 and there is problems with headlamp wiper/fan shroud clearance I'm told with the TNS.[/QUOTE]
Not seen the TNS one, but the do88 one does foul the front panel, so a couple of the strenghtening spars needed removing from the top, and I trimmed up the sides of the intercooler so I could keep my headlight wipers.
Post 695679 by jamesy12345 on 2014-03-17 10:44:02
I was wondering about mine, looks like I'll need to cut it back also to avoid the wipers. Well done for getting it all in!
Post 695681 by partsforvolvos.com on 2014-03-17 10:49:30
good work steve.
Post 695959 by iancho on 2014-03-18 07:26:24
Nice work Steve, it's coming along nicely bud :)
Post 696028 by Wobbly Dave on 2014-03-18 17:02:11
I'd like to say nice work but then you'll beat me & I will be sad :cry:
Post 696070 by stribo on 2014-03-18 19:50:57
[QUOTE=Wobbly Dave;696028]I'd like to say nice work but then you'll beat me & I will be sad :cry:[/QUOTE]
Me, beat you? That's the plan. ;) Needs more work yet though.
Post 696075 by WOODY T5 on 2014-03-18 20:07:45
Some nice work there steve moving along nicely all these mods going on best start looking for ways too in to the 12s I thinks :)
Post 696097 by stribo on 2014-03-18 20:36:54
[QUOTE=WOODY T5;696075]Some nice work there steve moving along nicely all these mods going on best start looking for ways too in to the 12s I thinks :)[/QUOTE]
At the moment I'll be happy with low 14's, once the 18t, jap manifold, and ferrita downpipe with sports cat goes on I'll be hoping for late 13's, you've nothing to worry about for a while yet mate. ;)
Post 696098 by theflyingbrick on 2014-03-18 20:42:05
just been catching up on this thread,youve done well mate I look forward to seeing this running (behind me) down the strip :eclipsee_
Post 696102 by stribo on 2014-03-18 20:48:31
[QUOTE=theflyingbrick;696098]just been catching up on this thread,youve done well mate I look forward to seeing this running (behind me) down the strip :eclipsee_[/QUOTE]
Haha, you going to North Weald on the 8th June, should have the turbo done by then. I'll only be behind you if you choose to reverse down the strip. ;)
Post 696111 by theflyingbrick on 2014-03-18 21:33:34
[QUOTE=stribo;696102]Haha, you going to North Weald on the 8th June, should have the turbo done by then. I'll only be behind you if you choose to reverse down the strip. ;)[/QUOTE]
yeah I reckon I should have her finished by then but im gonna take my time with porting and polishing the head though.......oh ive said too much ;)
Post 696116 by stribo on 2014-03-18 21:43:20
[QUOTE=theflyingbrick;696111]yeah I reckon I should have her finished by then but im gonna take my time with porting and polishing the head though.......oh ive said too much ;)[/QUOTE]
Game on then mate. ;)
Post 696236 by rikcougar on 2014-03-19 13:02:46
Coming together nicely Steve, good work :B_thumb:
Post 699092 by stribo on 2014-03-29 21:05:19
Gave the car an oil change today, ready for tomorrows trip to Avon, and a little something extra:
Post 699094 by AcidicDavey on 2014-03-29 21:07:50
Put that power steering cap on right!
...my ocd is killing me!
Took me a while to figure what the little extra was, thick or what lol
Post 699096 by graemewelch on 2014-03-29 21:12:04
You got any pics. Im starting my head tomora.
Post 699097 by WOODY T5 on 2014-03-29 21:13:46
[QUOTE=stribo;699092]Gave the car an oil change today, ready for tomorrows trip to Avon, and a little something extra:
[/QUOTE]i like the way it looks standard mate lol
Post 699101 by stribo on 2014-03-29 21:19:20
[QUOTE=AcidicDavey;699094]Put that power steering cap on right!
Took me a while to figure what the little extra was, thick or what lol[/QUOTE]
[QUOTE=WOODY T5;699097]i like the way it looks standard mate lol[/QUOTE]
What I didn't realise when I ordered it was that it's just a cover that goes over the standard cap, I still think it looks good though. :D
Post 699107 by AcidicDavey on 2014-03-29 21:26:11
[QUOTE=stribo;699101]What I didn't realise when I ordered it was that it's just a cover that goes over the standard cap, I still think it looks good though. :D[/QUOTE]
Would be nice if they printed the logo on it straight too, mine is wonky! Can't quite tell from the photo but your's seems to be too? But no, a nice looking thing anyway.
Post 699108 by stribo on 2014-03-29 21:28:31
Yeah, it's slightly wonky, but I'm trying not to think about it, I may not sleep. ;)
Post 699111 by AcidicDavey on 2014-03-29 21:30:49
....I've got a sudden urge to go outside and scratch the logo off, not good....
*need help, need help!
Post 699114 by WOODY T5 on 2014-03-29 21:35:42
[QUOTE=stribo;699101]What I didn't realise when I ordered it was that it's just a cover that goes over the standard cap, I still think it looks good though. :D[/QUOTE]yeah me too got one on my motor think That's why it goes so good
Post 699587 by c70geoff on 2014-03-31 09:38:17
Starting to think u gonna win this mod off
Post 699592 by stribo on 2014-03-31 10:20:30
[QUOTE=c70geoff;699587]Starting to think u gonna win this mod off[/QUOTE]
Best pull your finger out mate.;)
Post 699594 by c70geoff on 2014-03-31 10:22:38
Well that I am but just been deciding what livery to paint the trucks
Post 699596 by stribo on 2014-03-31 10:26:48
[QUOTE=c70geoff;699594]Well that I am but just been deciding what livery to paint the trucks[/QUOTE]
Well, that's an easy one.;)
Post 699603 by c70geoff on 2014-03-31 11:30:19
Oh I know just bought 10 litres of gay gold
Post 715837 by stribo on 2014-05-31 15:54:06
Quick update, changed my steering wheel today, from this:
to this:
:D
Post 715847 by AndysR on 2014-05-31 16:08:35
Looks smart, didn't realise or forgot that you had R clocks fitted :)
Post 715894 by V70 Graham on 2014-05-31 17:31:14
Steering wheel and 'R' clocks....should be easily another 0.05 sec off next Sunday.
Post 715896 by stribo on 2014-05-31 17:37:34
[QUOTE=V70 Graham;715894]Steering wheel and 'R' clocks....should be easily another 0.05 sec off next Sunday.[/QUOTE]
I want .06 secs off in the R, then I'll be in the 13s. :D
Post 715899 by Kingsford G on 2014-05-31 17:47:36
[QUOTE=stribo;715896]I want .06 secs off in the R, then I'll be in the 13s. :D[/QUOTE]
No you won`t,Rachel will
Post 715903 by stribo on 2014-05-31 18:06:26
[QUOTE=Kingsford G;715899]No you won`t,Rachel will[/QUOTE]
:finger:
Hopefully we'll both be. ;)
Post 715913 by Jamest5r on 2014-05-31 18:44:39
So do I :)
Post 715981 by Kingsford G on 2014-05-31 21:47:50
[QUOTE=stribo;715903]:finger:
Hopefully we'll both be. ;)[/QUOTE]
I'll b very impressed if the ginger does high 13s,lets hope all that hard work pays.
Post 715996 by stribo on 2014-05-31 22:07:09
[QUOTE=Kingsford G;715981]I'll b very impressed if the ginger does high 13s,lets hope all that hard work pays.[/QUOTE]
I wasn't talking about the C70, but the R. The C70 needs a bit of work yet. ;)
Post 716036 by WOODY T5 on 2014-05-31 23:09:18
[QUOTE=Kingsford G;715981]I'll b very impressed if the ginger does high 13s,lets hope all that hard work pays.[/QUOTE]yeah u and me both lol lol
Post 732555 by stribo on 2014-08-31 09:24:42
Well, after waiting for all the bits to come together, yesterday was turbo change time, first off, it was time to get rid of the old exhaust manifold in favour of a Jap ME7 one (japanifold):
then on with the 18t :D:
Next up was the ferrita downpipe with 200 cell sports cat:
Luckily I also had a GWE intake pipe, as the old one was shot, though fitting the GWE one was a right PITA, obviously no R&D went into it:
So, how does it sound? how does it go? No idea, was planning on firing it up this morning and giving it a shake down, but Rachel's been running a temperature since Thursday afternoon, and unable to keep food down, so I've had to drop her off at the hospital this morning.:(
Hopefully it'll all be up and running properly in time for Trax. Talking of which, fitted DS2500 pads and braided hoses to the front a few weeks ago, just have the rear hoses and handbrake shoes to do.
Post 732561 by V70 Graham on 2014-08-31 10:53:23
Who's been a busy boy then.
Glad to see it all coming together mate.
Post 804181 by stribo on 2016-08-16 18:57:58
Wow, can't believe it's been nearly 2 years since I updated this thread. Anyway, after a long time bouncing around on cheap Pro sport coilovers, I've taken the plunge, and bought a set of BCs.
Can't wait to get them fitted, I'll report back once they're on. :D
Post 804192 by martybelfastt5 on 2016-08-16 21:37:11
very nice!
Post 809885 by Doingitsideways on 2017-02-21 23:15:51
Thought you were dead!!
Looking good there :)
What's the plan with that saffy R?
Post 809897 by stribo on 2017-02-22 12:31:07
[QUOTE=Doingitsideways;809885]Thought you were dead!!
What's the plan with that saffy R?[/QUOTE]
News of my demise is somewhat premature. ;)
I'm getting it back up to scratch, got a steering rack, rear exhaust section, and front shocks to fit, and go from there. :D
Post 809900 by Tee5alive on 2017-02-22 14:28:31
She looks great mate always liked that Saffron such a unique colour!
Nice wheels too CANISTO are 'the dogs dangly bits' much better looking than ANY of the other Volvo wheels which look and feel heavy.
Have to get 2 of mine welded now as a small hairline crack appeared leading to slow punctures :((( I MUST get a boost gauge for the C70 and make time to do improvements on her. Going for a remap and uprated injectors (orange) funny enough! Also may go for the larger CHRA upgrade with the turbo. as I fitted to the 'tank' V70. Took out the blown one and fitted a larger compressor assembly that's guaranteed
trouble is having a girlfriend now that gets expensive so the options.......keep the car OR dump the gf...................NO CONTEST hahahaha
Post 809904 by stribo on 2017-02-22 15:24:35
Luckily I don't have that problem, as my wife is into cars too, in my signature pic, she's in the S60R, and she beat me, but it was damp, and she had AWD lol.
Yeah, I like the Canistos, just unsure whether to leave them on the V70R, or get another set of Comets for it, probably stick with the Canistos for now. If you're going for uprated injectors, you'll want blues, though you should have them already, oranges were used on the early T5s, and LPT cars.
Post 810215 by v70 jay on 2017-03-03 19:13:51
Hi mate.
Have you had a chance to drive it on the new coilovers yet? Wondering how they feel?
And how good were the pro sports?
