Post 527583 by stribo on 2012-07-27 17:15:18
I've got a droning noise coming from what sounds like the front nearside wheel. I've given it a good push and pull, and there doesn't seem to be any play in it, however the wishbone is pretty shot, so was wondering if this would cause the noise, or if in fact it is the wheel bearing.
Post 527584 by M-R-P on 2012-07-27 17:18:02
Have you checked the other wheels?
The chassis on these cars are so rigid, they can transfer sound around.
Post 527593 by stribo on 2012-07-27 17:35:18
Checked both n/s wheels, will try the o/s ones.
Post 527599 by V70 Graham on 2012-07-27 17:40:53
[QUOTE=stribo;527583].....however the wishbone is pretty shot.....[/QUOTE]
Make sure you polybush the new ones :D
Post 527602 by stribo on 2012-07-27 17:43:19
[QUOTE=V70 Graham;527599]Make sure you polybush the new ones :D[/QUOTE]
Apparently you can't, as C70 has specific C70 wishbones i.e. not shared with 850/ V70 P1. :(
Post 527606 by V70 Graham on 2012-07-27 17:49:39
Found these.....
http://www.partsforvolvosonline.com/product_info.php?cPath=28_23_171&products_id=5832
States.....'For cars with single bolt lower arm fixing'.....guess that's not yours then :confused:
Post 527607 by oblark on 2012-07-27 17:53:56
[QUOTE=V70 Graham;527606]Found these.....
States.....'For cars with single bolt lower arm fixing'.....guess that's not yours then :confused:[/QUOTE]
http://www.vpcuk.org/forums/showthread.php?45809-Wishbone-lower-arm-bushes
