How to get my fuel economy to match my 2003 s60
Post 529136 by Ians on 2012-08-06 22:42:40
Hi it seems there are a lot of people out there who have gone from phase 2 volvo d5 to the newer phase 3 v70 obviously I am one of them. I would also like to get back to 50mpg motoring instead of 37-38. I have also spent hours looking for the answer on the web. I hope someone on here can enlighten people like me on what to do. The new car is better in every other department than the phase 2 model and suggesting I get one is not the answer im looking for lol. Fingers crossed someone as the answer and can give me my missing 70-100miles per tankful I am missing. I would like someone who as had the dpf removed and a re map to answer if that's possible but I cannot find the answer online Thanks in advance
Post 529138 by M-R-P on 2012-08-06 22:46:33
Doing the DPF and a remap will help but the big factor here is that a P2 is around 1550kg and P3 V70s are about 2000kg. I imagine the old D5 would return 35mpg with 300-400kg extra weight onboard.
Post 529144 by Ians on 2012-08-06 22:58:08
Hi Martinrpeachey thanks for that answer it makes sense was hoping that wasnt the case so you think that 37-38 is all I can expect. Is there any suggestion you could make to that would be cost effective ie remap or just live with it?
Post 529145 by M-R-P on 2012-08-06 23:06:06
Maybe look at your driving style? Most cars, petrol or deisel will go into top gear at 30-35 mph (just ton't try to go uphill or overtake lol), generally try to keep the car in as higher gear as possible with gentle presses on the throttle, keeping it nice and smooth. How often do you reset the mpg readout? Premium derv may help too. Just to make you feel better - I'm lucky to get 24mpg from mine during the week lol. (it is a T5 tho ;))
Post 529209 by Ians on 2012-08-07 15:35:22
Believe it or not thats how I try to drive and the mileage is reset probably round the 1000 mile mark. You pay highly for performance and at those figures for your T5 it would bankrupt me lol
Post 529210 by M-R-P on 2012-08-07 15:38:36
Lol, luckily we don't go far. On a run up the M-way, we get about 35mpg. If I hammer it I get about 9 pmsl.
Post 529217 by ExternalError on 2012-08-07 16:08:09
oh the single figure joys of a T5 I fear ever putting my mpg to instant, but as a friend of mine once said its smiles per gallon in a t5 not miles per gallon
Post 529323 by LiamT4 on 2012-08-07 21:06:48
[QUOTE=Ians;529136]Hi it seems there are a lot of people out there who have gone from phase 2 volvo d5 to the newer phase 3 v70 obviously I am one of them. I would also like to get back to 50mpg motoring instead of 37-38. I have also spent hours looking for the answer on the web. I hope someone on here can enlighten people like me on what to do. The new car is better in every other department than the phase 2 model and suggesting I get one is not the answer im looking for lol. Fingers crossed someone as the answer and can give me my missing 70-100miles per tankful I am missing. I would like someone who as had the dpf removed and a re map to answer if that's possible but I cannot find the answer online Thanks in advance[/QUOTE] How many miles has it done? If its pretty new it may get better the more miles it does. Make sure the tyre pressures are correct and lots of use of the air con will bring the mpg down and i think there are now remaps specifically for economy. [QUOTE=ExternalError;529217]oh the single figure joys of a T5 I fear ever putting my mpg to instant, but as a friend of mine once said its smiles per gallon in a t5 not miles per gallon[/QUOTE] My T4 had the decency of not being able to show single figure mpg, the readout couldn't show less than 11.1mpg. lol Unfortunatly my 540 isn't like that, nevermind though, its more fun when the cars doing 12mpg than it is at 30mpg!
Post 529343 by Ians on 2012-08-07 22:27:12
I use the air con more than I used to as I was told if you don't use it you lose. The mileage is 118 000 so I would think it wont get much better on the mileage front and I run the tyres at 34psi all round. Who do I use for an remap and any idea on price? Im based in Burnley.
Post 529351 by LiamT4 on 2012-08-07 22:43:55
[QUOTE=Ians;529343]I use the air con more than I used to as I was told if you don't use it you lose. The mileage is 118 000 so I would think it wont get much better on the mileage front and I run the tyres at 34psi all round. Who do I use for an remap and any idea on price? Im based in Burnley.[/QUOTE] Should be well run in by now then lol As long as you use the a/c once or twice a week for about 10mins, you should be fine. Its when you don't use it for ages that the seals dry out so the gas escapes. No need for it to be on all the time though. Can't help with the remap, not really got any experience with them on diesels. I'm sure someone will be able to help though.
Post 529362 by M-R-P on 2012-08-07 23:04:01
Have you pulled the negative off the battery for a few hours? this resets the ecu and makes the car much more efficient from the off. Then, for the next 500 miles, it's up to you - fast or frugal... There's only ever one answer when I do this to mine... :)
Post 529374 by Ians on 2012-08-07 23:37:40
Never heard of this one does it do anything else as im always a bit worried messing with batteries on modern cars lol but I do believe you know your stuff could you tell me a bit more.
Post 529378 by M-R-P on 2012-08-07 23:46:19
Err, All I know is that pulling the battery blanks the ecu's memory. Everything it's learned about the driving style it's been subjected to will be lost and it reverts to a base map. as you drive it, it learns what you're demands are (sudden acceloration or granny driving etc) and adjusts fueling and timing to suit. The later P3 stuff may be different but with mine, I pull the battery before I go on a long drive and it saves me a fiver ;) Or I can pull it and drive like a nutter for a few weeks and the car becomes really aggressive and uses loads of fuel :o You're clearly not the 1st owner, perhaps the previous owner was a bit "lively" on the go pedal?
Post 529459 by foammanmark on 2012-08-08 17:58:35
[QUOTE=Ians;529343]I use the air con more than I used to as I was told if you don't use it you lose. The mileage is 118 000 so I would think it wont get much better on the mileage front and I run the tyres at 34psi all round. Who do I use for an remap and any idea on price? Im based in Burnley.[/QUOTE] I'd ask Adam at Readview Volvo in Huncoat about the map. He sorts my T5's out through HLM and sends the ECU down to them so you don't have to go yourself. Not sure about if he could help with the diesel though. If you want his number, let me know. Are you a Claret by the way?
Post 529461 by foammanmark on 2012-08-08 18:04:59
HLM have diesel mapping listed on their website, so Adam should be your man on this, unless you fancy a trip down there yourself.
Post 529500 by Germarchip on 2012-08-08 20:08:32
I do about 3000mls per month & if i keep below 70 & drive like a granny I can just squeeze it to 40 mpg (she is auto)
Post 529520 by Ians on 2012-08-08 21:01:50
[QUOTE=foammanmark;529459]I'd ask Adam at Readview Volvo in Huncoat about the map. He sorts my T5's out through HLM and sends the ECU down to them so you don't have to go yourself. Not sure about if he could help with the diesel though. If you want his number, let me know. Are you a Claret by the way?[/QUOTE] I deal with Adam at readview all the time I think he is a top bloke. I like to see Burnley do well but wouldn't call myself a fan lol
Post 529524 by foammanmark on 2012-08-08 21:13:12
Nice one- I'll no doubt see you there at some stage as my 3 Volvos all go to him. I'd suggest asking him about the HLM map for your car. My T5 ECU was back in about 3 days but he had a spare ECU for my car.
Post 529526 by foammanmark on 2012-08-08 21:16:28
[QUOTE=Germarchip;529500]I do about 3000mls per month & if i keep below 70 & drive like a granny I can just squeeze it to 40 mpg (she is auto)[/QUOTE] I did similar with my 6 speed manual D5 and got 43.8mpg after not resetting the OBC for 6 months. Sold that car and now enjoy mid to high 20's from my T5's and R. I do 2-2,500/month in them.
Post 529577 by Blackdog on 2012-08-09 00:04:40
I run a 60 plate D5 V70 geartronic. OBC is showing 43.4. That's based on mixed driving and a 30 mile run into Cambridge City centre every day. Oh and its been polestar remapped.
Post 529709 by foammanmark on 2012-08-09 18:41:01
[QUOTE=BLACKDOG;529577]I run a 60 plate D5 V70 geartronic. OBC is showing 43.4. That's based on mixed driving and a 30 mile run into Cambridge City centre every day. Oh and its been polestar remapped.[/QUOTE] That sounds pretty good to me. Mine was just a 163 6 speed manual to give me the 43.8mpg.
Post 529712 by foammanmark on 2012-08-09 18:44:13
[QUOTE=Ians;529520]I deal with Adam at readview all the time I think he is a top bloke. I like to see Burnley do well but wouldn't call myself a fan lol[/QUOTE] Sorry, I asked about you being a Claret cos my lad and me are. Just managed to get season tickets again but it's only the second season that I've bought them. You will see that I'm from Great Harwood, which is nowhere near Blackburn! Being born there is bad enough, so I don't like my address being Great Harwood, Blackburn.
Post 529717 by jimka on 2012-08-09 19:03:57
Polestar remap and Shell diesel ulitmate have given me an increase of 3mpg from 35mpg (based on tank to tank fills) on my commute. Mine is a 08 C70 D5 geartronic. The ultimate makes a big difference to engine noise reducing engine chatter esp on start up. I also threw in a tank fuel of BG244 which was noticeable and well recommended. Driving like a baby and long trips 40-46mpg - but where's the fun in that...?
Post 529731 by Blackdog on 2012-08-09 19:43:41
TBH the 43.6 from the OBC aint that far off on the tanks eithr. Looking at 625+ from this tank and that includes playing when I can. I find if the mpg starts to drop then a motorway cruise to do a cat regen helps.
Post 529805 by Blackdog on 2012-08-10 08:51:09
Filled up this morning. Last two tanks 126L in total 1169 miles 42.12 mpg
Post 529985 by Ians on 2012-08-11 02:23:40
No offence taken hope you have a good season if that's your blue r I'm sure I have seen you about [QUOTE=foammanmark;529712]Sorry, I asked about you being a Claret cos my lad and me are. Just managed to get season tickets again but it's only the second season that I've bought them. You will see that I'm from Great Harwood, which is nowhere near Blackburn! Being born there is bad enough, so I don't like my address being Great Harwood, Blackburn.[/QUOTE]
Post 530222 by JamesT5 on 2012-08-12 19:00:14
[QUOTE=Ians;529136]Hi it seems there are a lot of people out there who have gone from phase 2 volvo d5 to the newer phase 3 v70 obviously I am one of them. I would also like to get back to 50mpg motoring instead of 37-38. I have also spent hours looking for the answer on the web. I hope someone on here can enlighten people like me on what to do. The new car is better in every other department than the phase 2 model and suggesting I get one is not the answer im looking for lol. Fingers crossed someone as the answer and can give me my missing 70-100miles per tankful I am missing. I would like someone who as had the dpf removed and a re map to answer if that's possible but I cannot find the answer online Thanks in advance[/QUOTE] Get out and push. Ok, sorry that wasn't very helpful was it. :D I imagine as the P3 is a much bigger car, getting a higher MPG could be very difficult.
Post 530321 by Germarchip on 2012-08-13 08:56:50
[QUOTE=BLACKDOG;529577]I run a 60 plate D5 V70 geartronic. OBC is showing 43.4. That's based on mixed driving and a 30 mile run into Cambridge City centre every day. Oh and its been polestar remapped.[/QUOTE] Would a re map make a big difference to improve mpg?
Post 537399 by Ians on 2012-09-19 11:55:45
just thought i would try to get a conclusion from this post as anybody who as gone the polestar route or had there ecu remapped found it improved mpg significantly. Or as anybody taken the dpf off at these specailist places. I have tried all what as been suggested in the posts including taking battery terminal off but still only get 38-39 Help please.
Post 537434 by T5R+ on 2012-09-19 17:53:32
Ians - sorry the Phase 3 V70 D5 2007 thro 2009 in EuIV format with either the 2.4D or D5 engine is never going to give you the economy you seek through driving style alone. Sceptical about ECU enhancement for this particular model with respect to improved economy. The latest V70 D5 (both the 205 and 215) is supposed to be EuV/VI compliant and is much more fuel efficient in part I suspect to the dual turbo set-up. Also believe that Volvo knew the early P3's liked a drink which was putting buyers off and worked hard to make the latest cars more efficient. [LIST] [*]I managed to get to 48MPG regularly in a P3 V70 D5 (185bhp) 6-speed manual crusing at 60mph but struggled to break 50MPG [*]A P2 V70 D5 Manual EuIV regularly saw 52-55MPG. [*]A gently driven V70 P2 EuIII Manual will see 67MPG (clears a 1000miles to the tankful) if you are patient. [/LIST] Will be interesting to see if anyone has removed DPFs (MOT Time?) or swapped out injectors or ???
Post 537919 by Hoppsym on 2012-09-23 08:22:17
I've recently purchased a 07 s60 d5 and round the doors mines reading 38.9 doing normal driving (not driving like a granny ) and getting about 220/250 on £40 of fuel, don't know what it's like on a run as not really been anywhere far yet, when the wife drives it it reads 34/36 ad she has a constant lead foot haha, I also find it has a different engine tone to my previous 05 s60 d5 does anyone know why?, my old 05 d5 was the best thing Ive ever had on economy especially after coming from a 11mpg 4.4 v8 range rover what used to use £150 a week for the school run and around town. I'm off to my sons football match which is a 17 mile round trip 8 miles will be motorway so will see what it reads at a steady speed.
Post 538005 by kez694 on 2012-09-23 18:07:37
i hope he wins football lol
Post 539082 by Hoppsym on 2012-09-30 19:07:38
Well didn't end up using my car but just been on a little run 25 miles on motorway was sitting between 80/90 average speed was 82 mph mpg was 51.2
