Seized rear brake calipers !!!!!!!
Post 533566 by MoleT-5R on 2012-08-29 22:08:32
Both my 850's rear brake calipers have seized and I can not shift them at all, does any body out there, not to far from Welshpool have a pair that they could sell me reasonably cheap, desperate for them as I trying to get the car mot'd for Trax :help:
Post 533569 by t5 pete on 2012-08-29 22:14:19
Thats bad news if you carnt get hold of some you could strip them down and push the pots out then clean them with wire wool obviously if water has been getting in there, there will be pitting on the pot but should free them up for the time being
Post 533593 by glock19 on 2012-08-30 00:22:30
Are you positive it's not the handbrake being stuck ? They are inside the rotor drum and the brake shoes are proned to sticking
Post 533599 by MoleT-5R on 2012-08-30 05:01:07
[QUOTE=glock19;533593]Are you positive it's not the handbrake being stuck ? They are inside the rotor drum and the brake shoes are proned to sticking[/QUOTE] Hand brake shoes are out and binned, it's just both caliper pistons stuck in on the inside of the car, took one hell of a press on the pedal to move in and now can't push them back out
Post 533627 by JamesT5 on 2012-08-30 10:51:26
[QUOTE=moleadrian;533566]Both my 850's rear brake calipers have seized and I can not shift them at all, does any body out there, not to far from Welshpool have a pair that they could sell me reasonably cheap, desperate for them as I trying to get the car mot'd for Trax :help:[/QUOTE] Hi I had a stuck N/S front brake caliper on my P2 the other week, thankfully I had the RAC out as I have 'At Home' cover, he came out and got the caliper working again until I had it replaced. It's a pain in the neck isn't it! The RAC man took the caliper apart, used about half a bottle of penetrating fluid and eventually managed to shift it. Then he used some emery paper, cleaned up the metal rods, a few sprays of grease and then put it back together. Looked like a right fiddle though... Regards James
Post 533644 by bubba_1986 on 2012-08-30 13:04:32
Contact wobbly dave mate. He should have a set still off of a c70 we broke
