D5 Fuel Filter replacement.
Post 539513 by y2blade on 2012-10-03 12:03:23
I'm finally going to get round to fitting my new fuel filter tonight. it is the Metal Canister type (it looks like a big spin-on oil filter) up in front of the O/S rear wheel. Anything I need to be aware of before I whip the old one off and throw the new one on? Am I going to get covered in stinky fuel?
Post 539514 by p fandango on 2012-10-03 12:06:05
yes it is, i think your meant to have less than 1/4 tank of fuel when you change it (or something along those lines)
Post 539516 by y2blade on 2012-10-03 12:16:19
[QUOTE=p fandango;539514]yes it is i think your meant to have less than 1/4 tank of fuel when you change it (or something along those lines)[/QUOTE] Yes "what" is? Will the fuel just pour out if over 1/4 tank then?
Post 539517 by p fandango on 2012-10-03 12:22:00
[QUOTE=y2blade;539516]Yes "what" is?[/quote] the metal canistor under the sill you describe is the fuel filter
i have no idea, not tried for obvious reasons
Post 539518 by y2blade on 2012-10-03 12:27:54
[QUOTE=p fandango;539517]the metal canistor under the sill you describe is the fuel filter i have no idea, not tried for obvious reasons[/QUOTE] Thanks. I know it's the fuel filter, it's been sat on a shelf in the garage (in it's box) for a while :D Have you ever changed the fuel filter on a S60/V70 D5?
Post 539519 by p fandango on 2012-10-03 12:31:17
[QUOTE=y2blade;539518]I know it's the fuel filter, it's been sat on a shelf in the garage (in it's box) for a while :D[/quote] sounds like my oil filter lol
yeh i did my own, took longer to take out of the box than it did to change it lol. I didn't have much fuel in the tank, but once i took the filter off it didn't flow out anyway (think it must have a valve on it)
Post 539521 by y2blade on 2012-10-03 12:34:36
Excellent, I might leave it until there is less in the tank then, only filled her up last week... I didn't realize fuel level would matter. Doh!!!!! Cheers for the info buddy.
Post 539532 by p fandango on 2012-10-03 12:59:57
[QUOTE=y2blade;539521]Excellent, I might leave it until there is less in the tank then, only filled her up last week... I didn't realize fuel level would matter. Doh!!!!! Cheers for the info buddy.[/QUOTE] no problem sir, haven't got my heinz manual to hand but sure it said 1/4tank or less. Really is easy to do, i didn't even jack her up & the old filter unscrewed by hand so really does only take minutes
Post 539535 by M-R-P on 2012-10-03 13:27:44
When I did mine (petrol but the same afaik) there was a dribble from the pipe but it's an airtight system that's pumped from the top so it won't just empty all over the drive. Have a drip tray under it tho because creosote or whatever it is you guys use as fuel is a pig to get out of tarmac. The clips holding the hose on can be a pig to get off too. there's a grey square on each side of the connection that you have to squeeze - in to remove. undo the bolt holding the canister, drop the canister, remove the fuel tank end first and plug it straight into the new one. allow the old canister to drain into the drip tray and remove the other pipe. then just plug the engine - end into the new canister and bolt it back up. Job done :)
Post 539538 by p fandango on 2012-10-03 13:35:42
[QUOTE=M-R-P;539535]When I did mine (petrol but the same afaik) there was a dribble from the pipe but it's an airtight system that's pumped from the top so it won't just empty all over the drive. Have a drip tray under it tho because creosote or whatever it is you guys use as fuel is a pig to get out of tarmac. The clips holding the hose on can be a pig to get off too. there's a grey square on each side of the connection that you have to squeeze - in to remove. undo the bolt holding the canister, drop the canister, remove the fuel tank end first and plug it straight into the new one. allow the old canister to drain into the drip tray and remove the other pipe. then just plug the engine - end into the new canister and bolt it back up. Job done :)[/QUOTE] us Massey Ferguson guys use a different filter, it just screws into the housing like a normal oil filter. No pipes to undo or any of that messy business lol
Post 539576 by M-R-P on 2012-10-03 17:25:26
Aaah, fair enough I'll shut up then lol.
Post 539598 by Redbrick on 2012-10-03 19:22:08
Place container underneath fuel filter - loosen screwed valve at bottom and allow to drain. Once it's empty attempt to get old one off - use an oil filter removal tool cause that sucker will be welded on.
Post 539599 by p fandango on 2012-10-03 19:23:31
[QUOTE=Redbrick;539598]Once it's empty attempt to get old one off - use an oil filter removal tool cause that sucker will be welded on.[/QUOTE] mine came off by hand
Post 539733 by y2blade on 2012-10-04 10:03:56
Well that was a piece of cake :) filter spun off, dropped about half a cup of fuel onto the cardboard I'd placed under the car (none on the garage floor)....filled the new filter with diesel and spun it on. fired the car up and let it run for a bit...all good :) lovely job. cheers chaps.
Post 539736 by p fandango on 2012-10-04 10:09:53
surprisingly easy isn't it, did yours come off by hand?
Post 539743 by y2blade on 2012-10-04 10:27:37
Yep very easy. tbh I didn't try it by hand I just used the filter socket/tool, it wasn't hard to undo though.
