i think my wastegate is letting by..???
Post 540188 by d2k on 2012-10-06 09:43:57
since finding a crack in one of my boost pipes (IC - ETM) the car feels sooooo much better, ive actually seen 13psi since the fix. but..... it pulls like a freight train from 3k to 4k then the boost starts to drop off as i continue up the rev range..??, why can i not hold a continual boost..?? is it due to ME7 pulling back the boost as i hit 5k..... or is it the diaphragm in the actuator that's shot & letting air through the faster i go..?? i tried pulling on the arm.. i can move it but it don't feel 'loose' as such, what upgrade options do i have here while keeping the 16t... i know trying to add more boost will prompt engine management to pull it back without a remap... but surely i should be able to hold standard boost to the redline..?? :smile:
Post 540191 by M-R-P on 2012-10-06 09:49:21
Standard boost iirc is 10_11 psi. I would expect to see it peak at 13 and drop off to 11. Then after 5.5k rpm it will drop off further as the turbo runs out of puff. Are you using a proper bcs yet?
Post 540193 by d2k on 2012-10-06 09:51:12
[QUOTE=M-R-P;540191]Standard boost iirc is 10_11 psi. I would expect to see it peak at 13 and drop off to 11. Then after 5.5k rpm it will drop off further as the turbo runs out of puff. Are you using a proper bcs yet?[/QUOTE] ah...... so it is supposed to drop the boost off. the BCS is my next cheap mod, will that allow me to hold boost for longer..??
Post 540196 by d2k on 2012-10-06 09:55:46
[QUOTE=M-R-P;540191]Standard boost iirc is 10_11 psi. I would expect to see it peak at 13 and drop off to 11. Then after 5.5k rpm it will drop off further as the turbo runs out of puff. Are you using a proper bcs yet?[/QUOTE] opps....... i meant MBC, not BCS...... i dont really want an OEM BCS as i have to use the full travel of the throttle to get the car going...an MBC if used lightly should give a little more..?? the HD TCV im using allows me to spool a little quicker... im only a short guy & trying to get to WOT is quite hard without sliding down the chair to push the pedal...lol
Post 540199 by M-R-P on 2012-10-06 10:00:40
You still using that third party thing? The volvo bcs is pricey but there's always the mbc option. Thing is, the 16t just runs out of puff at high speeds, this is why I usually change gear before 5k revs.
Post 540201 by M-R-P on 2012-10-06 10:07:52
Hmmm... I almost never put my foot right down. It responds to the speed you plant your foot rather than the distance of travel from what I can work out.
Post 540202 by d2k on 2012-10-06 10:10:44
[QUOTE=M-R-P;540199]You still using that third party thing? The volvo bcs is pricey but there's always the mbc option. Thing is, the 16t just runs out of puff at high speeds, this is why I usually change gear before 5k revs.[/QUOTE] lol.... ive probably just reached that point then, the point all you guys reach where standard hardware just wont cut the mustard anymore. i was looking at 18psi TD04 actuators, but thats pointless without a remap me thinks..... i guess the map will have to be the next step up. HLM here i come!! :smile:
Post 540203 by d2k on 2012-10-06 10:13:46
[QUOTE=M-R-P;540201]Hmmm... I almost never put my foot right down. It responds to the speed you plant your foot rather than the distance of travel from what I can work out.[/QUOTE] lol..... yeah but your a HUGE bloke!!! your foot probably dwarfs the accelerator.. i might ask when remapping if i can have 100% acceleration with 70% throttle travel. (as long as they dont do a RICA & base my hole map off of the throttle position)
Post 540207 by M-R-P on 2012-10-06 10:20:09
Lol, I honestly never put my foot right down. borrow the other half's heels and have a go pmsl
Post 540208 by d2k on 2012-10-06 10:26:05
[QUOTE=M-R-P;540207]Lol, I honestly never put my foot right down. borrow the other half's heels and have a go pmsl[/QUOTE] lmao...... you git!!:smile: been speaking to the guy @ IPD about replacing all air / charge pipes on my car, 8 weeks time they'll have a full kit for the early T5s that replaces the lot... so much to do..... such little cash to do it!!
