V40 outside air temp sensor
Post 545084 by munster732 on 2012-11-03 21:37:10
Does anyone know the location of the sensor that sends the signal to the dash board on phase 2 V40's? Just got 3 dashes where the temp should be displayed. Cheers Wayne
Post 545085 by t5 pete on 2012-11-03 21:44:28
google is your friend http://www.justanswer.com/volvo/3ybax-location-ambient-temperature-sensor.html number 1
Post 545086 by t5 pete on 2012-11-03 21:47:17
And matthew http://www.matthewsvolvosite.com/forums/viewtopic.php?f=8&t=21566
Post 545087 by M-R-P on 2012-11-03 21:51:24
I had this problem on my V70. As well as the blank reading, it would sometimes read silly temps like -45. This also stopped the air con working (bloody annoying just after I had a re-gas). Turned out to be the big connection on the drivers door switchpack had furry contacts for the outside temp sensor in the door mirror. Worth checking connections before spending money :D
Post 545090 by oblark on 2012-11-03 22:01:21
When my outside temp sensor went tits up it drained the battery in 24hrs
Post 545492 by munster732 on 2012-11-05 19:44:50
On further examination, it seems I am missing the sensor completely. Cue a call to Rufe and one is winging its way to Barnsley
Post 546048 by munster732 on 2012-11-08 18:27:46
Got new sensor today, had to replace the plug also as it was corroded due to being left in the open. Chopped one off at scrappy, wired it in and hey presto a fully working temp reading on the dash :-)
