Heater control panel illumination....or not!
Post 546058 by munster732 on 2012-11-08 18:38:36
I'm ironing out a few niggles with my new V40 diesel, I hate stuff not working or nor doing what it should.....think it might be a touch of car based OCD.
My heater panel has 3 knobs but only the centre one is illuminated at night. I have taken the plastic trim off the front, and removed the panel completely. If you take the knobs out of their housing you can see the bulbs behind them, they are discoloured and look to be burnt out.Does anyone know how to change these bulbs? Are they soldered onto the circuit board? If so, how do you get to them? Where can you buy them?
Post 546061 by foammanmark on 2012-11-08 18:43:21
[QUOTE=munster732;546058]I'm ironing out a few niggles with my new V40 diesel, I hate stuff not working or nor doing what it should.....think it might be a touch of car based OCD.
My heater panel has 3 knobs but only the centre one is illuminated at night. I have taken the plastic trim off the front, and removed the panel completely. If you take the knobs out of their housing you can see the bulbs behind them, they are discoloured and look to be burnt out.Does anyone know how to change these bulbs? Are they soldered onto the circuit board? If so, how do you get to them? Where can you buy them?[/QUOTE]
Can you get a picture up? I've done many bulbs in my V70's, but not in the heater control unit.
Post 546115 by volvokid on 2012-11-08 20:02:56
You need to take the whole panel out, very easy 4 screws I think. Take a flat head screw driver and you turn the bulbs out 90 degs or so then the will fall out. The bulbs get very hot and the blue rubber Johnny that's on them melts off so that your dash lights up white.
Post 546116 by foammanmark on 2012-11-08 20:09:43
[QUOTE=volvokid;546115]You need to take the whole panel out, very easy 4 screws I think. Take a flat head screw driver and you turn the bulbs out 90 degs or so then the will fall out. The bulbs get very hot and the blue rubber Johnny that's on them melts off so that your dash lights up white.[/QUOTE]
Are they the ones with the white base like in the stereos?
Post 546121 by munster732 on 2012-11-08 20:17:32
Will have another look this weekend, the bulbs are sat down underneath the housings that the rotary knobs sit in, will try and turn them and see if they drop out. Is it a Volvo dealer bulb or can they be bought from anywhere else?
Post 546130 by Haizum74 on 2012-11-08 20:27:18
[QUOTE=munster732;546121]Will have another look this weekend, the bulbs are sat down underneath the housings that the rotary knobs sit in, will try and turn them and see if they drop out. Is it a Volvo dealer bulb or can they be bought from anywhere else?[/QUOTE]
It will be easier to take the unit out and unscrew from the back end of it as they are very delicate (I crushed the middle one when sorting out my heater blower issue, luckily I had a spare) and they are inserted in towards the knobs and then turned 90 degrees on to the contacts. It takes a bit longer to get it out of the dash but once done its easy to fix. If you need any help give me a shout. Also you can get then from Rufe who is on here. I will find a link to his details and post it (or visit Ray Chapman in Malton ;-))
Post 546131 by foammanmark on 2012-11-08 20:29:50
If they are the same as what are in the p1 V70, then I've just replaced my whole unit so you could have the bulbs out of my old one. I think just one may have not been working though.
Post 546133 by munster732 on 2012-11-08 20:33:02
[QUOTE=Haizum74;546130]It will be easier to take the unit out and unscrew from the back end of it as they are very delicate (I crushed the middle one when sorting out my heater blower issue, luckily I had a spare) and they are inserted in towards the knobs and then turned 90 degrees on to the contacts. It takes a bit longer to get it out of the dash but once done its easy to fix. If you need any help give me a shout. Also you can get then from Rufe who is on here. I will find a link to his details and post it.[/QUOTE]
Cheers buddy, will call into Ray Chapman Volvo in Malton as im passing there tomorrow and get a few bulbs. It does look like a ball ache to get at them in the recesses, with my" touch of a baby elephant" I will probably crush a few so i may just buy 5 bulbs to be safe lol
Post 546139 by Haizum74 on 2012-11-08 20:42:57
[QUOTE=munster732;546133]Cheers buddy, will call into Ray Chapman Volvo in Malton as im passing there tomorrow and get a few bulbs. It does look like a ball ache to get at them in the recesses, with my" touch of a baby elephant" I will probably crush a few so i may just buy 5 bulbs to be safe lol[/QUOTE]
NP at all. Here is a link to getting the ACC unit out, takes about 10 minutes. The hardest part is removing the plugs at the back especially the larger one as it has a press down clip at the top and then pull to remove while pressing it down. I found using a small screwdriver horizontally across the top and pushing down while pulling works. You will see what I mean. LINK You don;t need to remove everything below the ACC either as it says in the thread link. It has two nodules on the top and bottom and you just need to lift the area below and above to get it out. Again its not difficult.
Also, this is the type of bulb you need [ATTACH=CONFIG]17427[/ATTACH] NOT ACTUAL SIZE ;-)
Post 546141 by volvokid on 2012-11-08 20:44:02
They are really easy, just remove the whole unit. I took a picture of the bulb for you. :)
[ATTACH=CONFIG]17428[/ATTACH]
These are cheap in comparison to the head light control bulbs, they are a fortune lol
Post 546145 by Haizum74 on 2012-11-08 20:49:30
[QUOTE=volvokid;546141]They are really easy, just remove the whole unit. I took a picture of the bulb for you. :)
These are cheap in comparison to the head light control bulbs, they are a fortune lol[/QUOTE]
Those are the smaller ones that go in the console to the right where you turn the lights on, the centre console ones are bigger.
Post 546147 by Haizum74 on 2012-11-08 20:52:43
Those are the smaller ones that go in the head light control console, the ACC bulbs are bigger.
Post 546148 by munster732 on 2012-11-08 20:53:32
[QUOTE=Haizum74;546139]NP at all. Here is a link to getting the ACC unit out, takes about 10 minutes. The hardest part is removing the plugs at the back especially the larger one as it has a press down clip at the top and then pull to remove while pressing it down. I found using a small screwdriver horizontally across the top and pushing down while pulling works. You will see what I mean. LINK You don;t need to remove everything below the ACC either as it says in the thread link. It has two nodules on the top and bottom and you just need to lift the area below and above to get it out. Again its not difficult.
Also, this is the type of bulb you need [ATTACH=CONFIG]17427[/ATTACH] NOT ACTUAL SIZE ;-)[/QUOTE]
Yeah thanks, i had the unit out tonight, took the back cover off and thought "feck, that looks a complicated circuit board" so put it all back together again lol. So to change the bulbs you need to take the circuit board out ? I had a wiggle with it but it seemed quite firmly wedged in there and didnt want to break it. Feeling brave now so will sort this baby over the weekend. Gee, i love you guys :lovestory
Post 546150 by munster732 on 2012-11-08 20:57:54
Aw shoot, the headlight switch dont light up either, gonna be a bulb tastic weekend methinks
Post 546155 by Haizum74 on 2012-11-08 20:59:49
[QUOTE=munster732;546148]Yeah thanks, i had the unit out tonight, took the back cover off and thought "feck, that looks a complicated circuit board" so put it all back together again lol. So to change the bulbs you need to take the circuit board out ? I had a wiggle with it but it seemed quite firmly wedged in there and didnt want to break it. Feeling brave now so will sort this baby over the weekend. Gee, i love you guys :lovestory[/QUOTE]
Heh yeh I thought that too. It clips in to the white base at either side and there are two screws in the centre, take them out and then with a flat blade sd push in one of the sides where it clips so the sd is on the green bit and then gently push the white surround above it, outwards. I t will free it and out it pops. Putting it back on make sure the knobs line up with the variable resistors or it will look as though it wont go back on and also make sure the green plugs are facing you (took me five minutes to realise that and wondered why it didnt go in lol). It might be worthwhile checking the solder on the joints to the ACC speed control as these can dry and crack and then you can have a slow/fast blower when turned on. If its not then dont worry about it.
[QUOTE=munster732;546150]Aw shoot, the headlight switch dont light up either, gonna be a bulb tastic weekend methinks[/QUOTE]
Lol, so youre having the same problem as me. You need 3 of them.
£2.44 each from Rufe at FRF Volvo with VPCUK discount. They are the best price I could find.
Post 546160 by volvokid on 2012-11-08 21:02:38
I never did that, I just unscrewed them from the back .
Post 546163 by Haizum74 on 2012-11-08 21:05:24
[QUOTE=volvokid;546160]I never did that, I just unscrewed them from the back .[/QUOTE]
Yeh youre right, just tried it on a spare one I have. Im half thinking of the heater issue and half the bulbs. You can indeed unscrew them without taking the PCB out.
Post 546167 by volvokid on 2012-11-08 21:09:45
Cool, I remembered they where at least double that
Post 546265 by munster732 on 2012-11-09 11:12:31
Just been into local stealers...6 bulbs = £37.34!!!
On the phone to Rufe and £24 delivered so over 50% saved :-)
Post 546271 by volvokid on 2012-11-09 11:40:15
I never bother calling around nowadays FRF are the best.
Post 546292 by Haizum74 on 2012-11-09 13:05:09
Crikey £37 for 6 little bulbs. They should change the name to Dick Turpins, least he had the audacity to wear a mask. Good price from FRF then.
How much were the larger ones each?
Post 546293 by munster732 on 2012-11-09 13:18:26
[QUOTE=Haizum74;546292]Crikey £37 for 6 little bulbs. They should change the name to Dick Turpins, least he had the audacity to wear a mask. Good price from FRF then.
How much were the larger ones each?[/QUOTE]
Big ones were £6.87 + vat and £2.88 +vat for the small ones
Post 549580 by munster732 on 2012-11-22 20:53:15
It broke my heart but, £27 lighter in the wallet and the dash is lit up like a christmas tree...joy!
Post 549724 by Haizum74 on 2012-11-23 13:12:59
Well thats another job done then.
