Post 547555 by merc85 on 2012-11-13 23:12:52
Well, tore into the old engine, and started to build the new lump up, inlet ports of the old lump had quite abit of engine oil in them, and to did the inlet manifold. Almost certainly down to Worn piston rings,
Still the new lump is now looking rather good.
[ATTACH=CONFIG]17515[/ATTACH]
[ATTACH=CONFIG]17516[/ATTACH]
Knackered so given it a rest for tonight, Will hopefully changing engines this wkend :)
Post 547557 by Kingsford G on 2012-11-13 23:27:57
Looking nice Gav.I can c alot of time spend on it, get it forged and k24 turbo to c what Rotch was trying to achiv.
Post 547587 by Dangerous Dave on 2012-11-14 12:04:30
Cool, hope it transfers over easily!
Mine was using a lot of oil, took the head off (damn headgasket again LOL) and when I undid the valve springs the valves dropped straight out, the valve stem seals were shot. New seals went on and no more oil usage :) (just more water usage, something badly wrong in the block somewhere)
Post 547593 by merc85 on 2012-11-14 14:26:58
I know what rotch was trying to achieve as i was the one who fitted the k24 to his car lol ;)
Post 547598 by Lsvolvo1 on 2012-11-14 15:47:08
Whats the cost of the rebuild on your engine? parts etc
Post 547612 by Kingsford G on 2012-11-14 17:24:29
[QUOTE=merc85;547593]I know what rotch was trying to achieve as i was the one who fitted the k24 to his car lol ;)[/QUOTE]
Let me c 300+ under the red bonnet Gav plz )
Post 547664 by merc85 on 2012-11-14 21:33:11
Well all the Loom has been disconnected from the engine and Gearbox, Fluids have been drained, Turbo Down pipe disconnected, fuel lines also disconnected already to unbolt the driveshafts and bottom arms disconnect the rack and drop the whole lot. Then transfer everything over to the new Subframe fit the new Gearbox, and exhaust manifold inc turbo and run her in on the whites on reduced boost and on the bcs for a while until all good.
Then Blue running 3.8 will be added and boost increase, (well thats the plan) lol Hopefully i wont have to many leaks to sort out. :)
[ATTACH=CONFIG]17518[/ATTACH]
[ATTACH=CONFIG]17519[/ATTACH]
Now with the injectors etc crank and cam sensors in place, and the top mount lol
Post 547665 by merc85 on 2012-11-14 21:38:07
Kingsford G, Considering it was dyno'd runing 17psi Compression of 9.5Bar, and a intake breathing in oil, Ran a 14.8 sec 1/4 @ 98mph all this at 270.8 bhp Flywheel 238 Bhp at the crank, Cant see that being a problem since having a Ported and polished Head, Reground Valves and Ported intake manifold, along with a slight raise in compression lol.
Post 547666 by T5frankie on 2012-11-14 21:48:01
[QUOTE=merc85;547665]Kingsford G, Considering it was dyno'd runing 17psi Compression of 9.5Bar, and a intake breathing in oil, Ran a 14.8 sec 1/4 @ 98mph all this at 270.8 bhp 238 Bhp at the flywheel, Cant see that being a problem since having a Ported and polished Head, Reground Valves and Ported intake manifold, along with a slight raise in compression lol.[/QUOTE]
if you have an 18/19t yeah
Post 547667 by merc85 on 2012-11-14 21:49:57
[QUOTE=t5frankie;547666]if you have an 18/19t yeah[/QUOTE]
As frankie said ;)
Post 547677 by merc85 on 2012-11-14 22:07:52
[QUOTE=Lsvolvo1;547598]Whats the cost of the rebuild on your engine? parts etc[/QUOTE]
I Have my Own Motor Factor's so obviously the parts are at cost, Also done the Head work Myself and Manifold aswell as the labour.
But parts wise around £200 inc fluids and filter's.
The only extra was the Head machining and fixing the Valve guide i stupidly b*** lol
Post 547685 by Kingsford G on 2012-11-14 22:32:33
As the car is in a great nik bodywise that new lump is just the ticket.Port polishing is one hellof a job u`ve been busier than I thought,well done mate.U must`ve got an R clutch too.If need a pair of hands fitting it just let me know as I can spend a sunday no probs also any tools needed too.
Post 547686 by T5frankie on 2012-11-14 22:33:25
dunno why you didnt do all this to the gull though mate?
Post 547701 by merc85 on 2012-11-14 23:35:55
[QUOTE=t5frankie;547686]dunno why you didnt do all this to the gull though mate?[/QUOTE]
Going to have my 5th child at any moment mate lol, Wife says the Gul has to go and Trust me id love to had done this to the Gul. Especially the 3" stainless exhaust aswel lol.
As you well know the 7 Seats come in handy. ;)
