Post 554569 by claymore on 2012-12-16 17:04:08
I don't know what the answer is, but JamesT5R used to be the same,
Post 554570 by merc85 on 2012-12-16 17:11:06
[QUOTE=claymore;554569]I don't know what the answer is, but JamesT5R used to be the same,[/QUOTE]
Cant even be a character of this particular engine, although cant remeber what it was like in my auto. As soon as it spark she starts straight away, Live with it or scrap it is my only choices by the looks of things :(
Post 554571 by t5 pete on 2012-12-16 17:16:06
Did it used to do the before you took the engine out merc? if so there is a good chance some thing has been knocked crushed etc i once had a car that i was breaking that had a front end knock which wouldnt start while messing about i found the front bit of the loom had been crushed which caused a few wires to short to each other smartend it up and the car ran fine untill it got broke into bits.
Post 554573 by Dangerous Dave on 2012-12-16 17:16:57
See what happens with the other ECU in it. Is the T5 ecu remapped?
Post 554575 by merc85 on 2012-12-16 17:24:03
The Ecu which she has, is and has always been fine in this car, my Gul's ecu is not mapped, The engine which is in this car is Not from this car, it was from my 855 t5 auto which i broke a few years ago, It had only done 125k so i Ported n Polished the Cylinder head and rebuilt the lump then fitted it along with a new gearbox to this car, This is when all the problems started. It is a electrical fault of some sort as there is NO spark when starting to crank from cold.
If a electrical tech bloke cant find the fault, ive got no chance. :(
When i put the engine in i did snagg the loom which runs across the front of the car, but it didnt come out of its casing or nowt. all looked good at the bottom of the ecu to.
Post 554576 by Jamest5r on 2012-12-16 17:29:44
Still does it sometimes but unlike Merc's mine start's 1st time everytime from cold its just throw's a wobbler when it's warm but im sure it's a fuel/mapping issue now.
However previously when i had the similar issue's i changed the auto loom for a manual one and seemed to work.
Merc, some car's are too good to break mate.
Post 554577 by merc85 on 2012-12-16 17:35:11
[QUOTE=Jamest5r;554576]Still does it sometimes but unlike Merc's mine start's 1st time everytime from cold its just throw's a wobbler when it's warm but im sure it's a fuel/mapping issue now.
Merc, some car's are too good to break mate.[/QUOTE]
This ones a Manual, with a manual loom but a Auto engine. When i fitted the Gearbox it was from a later car so had to wire the abs to the cv joint so i had a speedometer, This is the only wiring i did and surly that couldnt cause this issue??
The car really is clean and i get what you are saying. Just bugs the hell out of me, just worried one of these days she wont start.
Post 554581 by martybelfastt5 on 2012-12-16 18:56:48
mmmm cant help really other than tell you its looking fantastic!
Post 554593 by T5frankie on 2012-12-16 19:29:46
first dibs on the wheels lol
Post 554618 by merc85 on 2012-12-16 20:31:12
[QUOTE=t5frankie;554593]first dibs on the wheels lol[/QUOTE]
Depending on what car i get next i may keep them. if not they will be for sale
Post 554620 by LiamT4 on 2012-12-16 20:33:16
looks great on those comets.
Post 554658 by Kingsford G on 2012-12-16 22:18:38
Don`t know what to suggest but looks beautiful Gav.Do I take it Marks car developed the same problem too (((((?
Post 554664 by smithy on 2012-12-16 22:29:33
I would just reloom the whole car mate with a later loom from something like a p reg because the body on your car is great mate .
Post 554675 by merc85 on 2012-12-16 23:05:20
[QUOTE=Kingsford G;554658]Don`t know what to suggest but looks beautiful Gav.Do I take it Marks car developed the same problem too (((((?[/QUOTE]
no the s70 is fine
Post 554677 by merc85 on 2012-12-16 23:06:21
[QUOTE=smithy;554664]I would just reloom the whole car mate with a later loom from something like a p reg because the body on your car is great mate .[/QUOTE]
Its finding a Good loom and not fitting a bad one tho :(
Also the later looms are different, speedometer sensors is different also obd 2 not my obd1 so sockets wont be there, She will probably be broken.
Post 554685 by smithy on 2012-12-17 00:01:11
[QUOTE=merc85;554677]Its finding a Good loom and not fitting a bad one tho :(
Also the later looms are different, speedometer sensors is different also obd 2 not my obd1 so sockets wont be there, She will probably be broken.[/QUOTE]
I'm interested in the splitter mate if you do break her but ashame it would be though
Post 554688 by Nealevo on 2012-12-17 00:19:47
Gav, with the money you will be spending on a new car and getting it the way you want, you might just aswell try and solve these issues, it's far to good to break..... Have a time out, get Christmas out the way and start again, it's bound to be something stupidly simple, ask about for a loom, half a day in the cold changing it and you'll be back in love again. There are a lot of tremendous knowledgable people on the forums, I'm sure someone can help. Just my two pence worth!!
Red is best, we all know it, even the secret haters...
Post 554874 by Kingsford G on 2012-12-17 20:39:43
[QUOTE=Nealevo;554688]Gav, with the money you will be spending on a new car and getting it the way you want, you might just aswell try and solve these issues, it's far to good to break..... Have a time out, get Christmas out the way and start again, it's bound to be something stupidly simple, ask about for a loom, half a day in the cold changing it and you'll be back in love again. There are a lot of tremendous knowledgable people on the forums, I'm sure someone can help. Just my two pence worth!!
Red is best, we all know it, even the secret haters...[/QUOTE]
+1 on this one.
