94 reg 850 n/a gearbox wine
Post 558253 by brett5 on 2013-01-02 12:54:49
just wondering if anyone has had this problem before? my mates 94 reg 850 manual has a noise coming from the gearbox when driving, its not a clunking its like a bearing noise and the sound seems to be coming from the box and not the wheel bearing
Post 558269 by oblark on 2013-01-02 13:44:44
Check the gearbox oil level, If it whines in all gears it`s more and likely a dif brg.
Post 558278 by brett5 on 2013-01-02 14:28:11
it does wine in all gears and oil been changed
Post 558280 by oblark on 2013-01-02 14:31:55
I`d put some thicker oil in it :smile:
Post 558281 by brett5 on 2013-01-02 14:33:58
we put thicker oil in and addative
Post 558282 by WOODY T5 on 2013-01-02 14:44:25
New box time then;-)
Post 558283 by brett5 on 2013-01-02 14:46:16
yeah im in the process at this very moment
Post 558289 by Dangerous Dave on 2013-01-02 15:33:17
Does it do it at idle?
Post 558292 by Nealevo on 2013-01-02 15:43:32
[QUOTE=brett5;558283]yeah im in the process at this very moment[/QUOTE]
Brett if you can wait a week or so i have a 2.5 NA manual box coming in a complete car i will be breaking, i only want the gearstick and little things so the gearbox will be available and it will be cheap....ish!!
Post 558294 by oblark on 2013-01-02 15:48:29
[QUOTE=Nealevo;558292]Brett if you can wait a week or so i have a 2.5 NA manual box coming in a complete car i will be breaking, i only want the gearstick and little things so the gearbox will be available and it will be cheap....ish!![/QUOTE]
first dibs on the cam shafts :smile:
Post 558295 by p fandango on 2013-01-02 15:51:17
[QUOTE=oblark;558294]first dibs on the cam shafts :smile:[/QUOTE]
hope its not a 10valve lol. If it is a 10v & Brett doesn't want the gearbox i know someone who might be interested
Post 558296 by oblark on 2013-01-02 15:53:20
[QUOTE=p fandango;558295]hope its not a 10valve lol. If it is a 10v & Brett doesn't want the gearbox i know someone who might be interested[/QUOTE]
I thought the 2.0ltr was the only came as a 10v
Post 558297 by p fandango on 2013-01-02 15:55:55
[QUOTE=oblark;558296]I thought the 2.0ltr was the only came as a 10v[/QUOTE]
nope LINK
Post 558298 by brett5 on 2013-01-02 15:59:38
hiya no we have a gearbox so we are changing it
Post 558299 by oblark on 2013-01-02 16:00:42
[QUOTE=p fandango;558297]nope LINK[/QUOTE]
Learn something new everyday :smile:
Post 558300 by smithy on 2013-01-02 16:25:25
Are you sure it's not the clutch bearing
Post 558302 by oblark on 2013-01-02 16:30:28
[QUOTE=smithy;558300]Are you sure it's not the clutch bearing[/QUOTE]
Wont the clutch brg make a noise when the clutch is depressed :smile:
Post 558306 by brett5 on 2013-01-02 16:47:05
noise does not got when clutch is depressed and doesnt make a sound while not moving
Post 558311 by oblark on 2013-01-02 16:51:18
I still think it`s a dif brg, either turn the radio up :smile: or change the box if one turns up :smile:
Post 558314 by merc85 on 2013-01-02 16:53:43
I had a whine from the n/s of my t5, Lucky enough it went as soon as the wife got out LMFAO :rally_dri
Post 558365 by T5frankie on 2013-01-02 19:44:18
i have a nice 2.0 20v box on my s70r :wave23d:
Post 558386 by merc85 on 2013-01-02 20:24:30
[QUOTE=t5frankie;558365]i have a nice 2.0 20v box on my s70r :wave23d:[/QUOTE]
should get a quicker 1/4 time with that box then bud.
Post 558389 by T5frankie on 2013-01-02 20:26:02
[QUOTE=merc85;558386]should get a quicker 1/4 time with that box then bud.[/QUOTE]
so far 0.1 second slower
Post 558400 by p fandango on 2013-01-02 20:34:36
i'm going for longer ratios, less gearchanges
Post 558405 by WOODY T5 on 2013-01-02 20:48:31
[QUOTE=p fandango;558400]i'm going for longer ratios, less gearchanges[/QUOTE]think that`s wot i got without knowing
Post 558424 by merc85 on 2013-01-02 21:27:02
[QUOTE=t5frankie;558389]so far 0.1 second slower[/QUOTE]
be quicker with a diff mate
Post 558428 by smithy on 2013-01-02 21:47:52
Your car was not running right and no one got a good time that day so no comparison really .the car was very quick of the mark and don of kalmor union pulled a 14.2 with less power tan with the same box lol.
Post 558430 by smithy on 2013-01-02 21:49:50
[QUOTE=WOODY T5;558405]think that`s wot i got without knowing[/QUOTE]
The is no way you could get into 4th gear 3/4 of the strip with a standard box mate
Post 558435 by smithy on 2013-01-02 22:04:25
[QUOTE=oblark;558302]Wont the clutch brg make a noise when the clutch is depressed :smile:[/QUOTE]
The clutch can be noisy when the clutch is not pressed but can go quiet when using the clutch .just putting the idea out there because ive has a few n/a boxes and never had one go or become noisy and I raced them silly in the day lol.
Post 558445 by T5frankie on 2013-01-02 22:24:44
[QUOTE=smithy;558430]The is no way you could get into 4th gear 3/4 of the strip with a standard box mate[/QUOTE]
yes you can, cos he is doing alot more mph 3/4 up the strip
Post 558447 by T5frankie on 2013-01-02 22:25:17
[QUOTE=merc85;558424]be quicker with a diff mate[/QUOTE]
it wouldnt actually i was getting my best starts with one wheel drive lol
Post 558450 by smithy on 2013-01-02 22:29:12
[QUOTE=t5frankie;558445]yes you can, cos he is doing alot more mph 3/4 up the strip[/QUOTE]
That is my point mate he would have to have shorter gears to put the car in 4th that early to still power like he does because you could not do that with a t5 box because you are going into 4th just by the finish line
Post 558452 by WOODY T5 on 2013-01-02 22:33:01
[QUOTE=smithy;558450]That is my point mate he would have to have shorter gears to put the car in 4th that early to still power like he does because you could not do that with a t5 box because you are going into 4th just by the finish line[/QUOTE]It must be a t5 one as it hit 163 @6200revs in top on the private road p.s revs to7k
Post 558456 by smithy on 2013-01-02 22:37:24
[QUOTE=WOODY T5;558452]It must be a t5 one as it hit 163 @6200revs in top on the private road p.s revs to7k[/QUOTE]
I would like to check the number on the box mate because peeps with a similar setup to you cannot get into 4th were you do mate.but don't get me wrong your car is very quick and you are the bench mark for everyone to beat .
Post 558457 by p fandango on 2013-01-02 22:38:17
yep, thats a standard M56H with the normal T-5's 4.00 FDR. With your limiter at 7k it'll do 185mph (checked all with a gear-ratio calculator)
Post 558461 by WOODY T5 on 2013-01-02 22:42:22
[QUOTE=smithy;558456]I would like to check the number on the box mate because peeps with a similar setup to you cannot get into 4th were you do mate.but don't get me wrong your car is very quick and you are the bench mark for everyone to beat .[/QUOTE]
Must have more power then it says mate
Post 558463 by smithy on 2013-01-02 22:46:32
[QUOTE=WOODY T5;558461]Must have more power then it says mate[/QUOTE]
The power you are getting is what you would expect for that turbo and the other mods you have but I still think its not a t5 box mate.i cannot wait for the new season to see you get into 12s but I will find out if the is a number on the box that identifys what box is what out of interest that's all.
Post 558470 by p fandango on 2013-01-02 22:53:22
[QUOTE=smithy;558463]The power you are getting is what you would expect for that turbo and the other mods you have but I still think its not a t5 box mate.i cannot wait for the new season to see you get into 12s but I will find out if the is a number on the box that identifys what box is what out of interest that's all.[/QUOTE]
http://www.apexgarage.com/tech/gear_ratios.shtml
tyre diameter = 24.858267716535433
FDR = 4.00
5th = 0.70
@6200 = 164mph, 1mph different from what he said he's getting
edit = just to rub it in. My box has a FDR of 3.57 & a 5th of 0.65 :)
Post 558475 by p fandango on 2013-01-02 23:04:22
[QUOTE=smithy;558463]I will find out if the is a number on the box that identifys what box is what out of interest that's all.[/QUOTE]
there is a small white rectangular sticker on the box which in the top right corner has the FDR printed onto it, unfortunately being open to the elements most of the stickers either come off or the info comes off
Post 558500 by smithy on 2013-01-02 23:26:11
The must be something stamped in the casting too but it wouldn't surprise me if it was just a sticker though
Post 558519 by merc85 on 2013-01-03 00:13:49
[QUOTE=t5frankie;558447]it wouldnt actually i was getting my best starts with one wheel drive lol[/QUOTE]
We will have to agree to disagree then bud this time round lol ;)
