V40 rear suspension bush's ???
Post 559139 by teddy241091 on 2013-01-05 10:48:45
When looking through forum found that the rear suspension bush's have tendency or going an i think mine are as im starting to see alot more camber on my rear wheel an very wobly back end also been told back end sits lower than it should but not sure about that as both v40's ive owned have been like that an so is my stepdads one Bassicly im looking to replace the worn bush's but dont have funds for all rear ones at the moment so if any one could send me a link to the most common worn ones or diagram would be great thanks
Post 559174 by Al115 on 2013-01-05 12:08:39
Common fault on the 40s. Quite an annoying job to replace them from what I remember. Are you planning to do it yourself or get a garage to do the work?
Post 559337 by teddy241091 on 2013-01-05 19:24:37
Doing them myself lol an any worse than doing trailing arm bush's on a bmw salloon?
Post 559455 by Al115 on 2013-01-05 22:38:33
I seem to remember my indy swearing about them but can't remember why. I'll ask.
Post 565656 by partsforvolvos.com on 2013-01-24 13:01:09
camber is likely to be play in one of the lateral link arm bushes- there are 2 a short and a long- you just change the arm. the front of rear trailing arm bushes are something else- original part difficult to fir and has to be compressed as it goes in. our local independent fits our > 1999 bushes which are the same as first original part having a metal shell and dont need compressing. these can be fitted to all s40/v40 up to 2004
