Post 561418 by t5 pete on 2013-01-10 17:35:44
Where the best place to get a set of over sized pistons for my 850 t5 is it a case of dealer only or are there other places. Cheers
The only pistons you can get from Volvo/ FRF volvo are 0.40mm oversize. These prices are from FRF volvo, main dealers are more. 5 x piston kit (piston + gudgen pin) part No. 272307 £436.06 inc vat + del 5 x rings 31330722 £155.04 inc vat + del
I'm sure I read somewhere that Sten Parner did the forged rods and pistons for around £834 Though I maybe wrong, his website has changed, but I'm sure it said rods and pistons for 8750 SEK You would have to contact them to see what the deal is.
How about these from RSI international, I think its what I have in mine. http://yhst-26451710505916.stores.yahoo.net/rsituwawhpi.html
Cheers every one looks like volvo is the way to go as ive allready got rods so will drop block off at machine shop
[QUOTE=t5 pete;561481]Cheers every one looks like volvo is the way to go as ive allready got rods so will drop block off at machine shop[/QUOTE] Depending how much wear you have on the bores will tell you if you can use oversize oem Volvo pistons mate
[QUOTE=smithy;561489]Depending how much wear you have on the bores will tell you if you can use oversize oem Volvo pistons mate[/QUOTE] OEM volvo oversize pistons only come in one size 81.40mm
[QUOTE=oblark;561491]OEM volvo oversize pistons only come in one size 81.40mm[/QUOTE] Yep and would be pointless not to do it while its all out
