Post 573274 by volvovirgin on 2013-02-14 12:27:32
Hi, not long had my volvo v70 and got the above message, tht was yesterday. This morning the engine symbol came on, which according to the book is an emissiin fault. Can anyone tell me if this is a minor or major issue. I have had performance cars before and always knew wot it needed.
Post 573276 by M-R-P on 2013-02-14 12:34:56
Know anybody with a code reader?
Post 573277 by volvovirgin on 2013-02-14 12:38:18
Going to the garage later and they will use one. Im not too worried about, just my other half.
Post 573353 by Santa on 2013-02-14 15:37:22
Is it an automatic/geartronic?
Post 573676 by volvovirgin on 2013-02-15 12:31:54
[QUOTE=Santa;573353]Is it an automatic/geartronic?[/QUOTE]
Its an auto, Santa.
Computer has been reset now, just got to keep an eye on it. Apparently Volvo say they dont change the transmission fluid ever.
Post 573680 by cookie on 2013-02-15 12:53:08
they may not have a specific mileage to replace fluid, but it may need replacing, there is plenty across the forums (Here. T5D5 and VOC) about flushing, and whatever you do, if you do flush, is use GENUINE FLUID, 12 litres is about 150 quid, cheaper fluid (better/equivalent or whatever people try and tell you) budget 2500 for box replacement.
you will read about people having gearbox service/flushed etc by a specialist, then have problems - in the past 10 odd years I've been around forums, I haven't found one that involves use of genuine fluid, I have always flushed mine with genuine, and never had a problem, and I do take my cars on track.
Post 573775 by Harvey on 2013-02-15 16:59:19
At main dealer it's about £200 with a software update.
They did my auto 18 months ago the fluid was very dirty it should be red in colour and clear,
Google a search for the dipstick on the gearbox it's at the front of the box very low down not easy to find it its yellow in colour bit will be dirty with road dirt.
Post 573789 by Kingsford G on 2013-02-15 17:17:57
For 5 speed boxes its mobil 1 3309 which is what genuine oil is.I`ve done mine today with castrol transmax dex 3.Flashed 12-13L to get it nice and red.
Post 578187 by jdavis on 2013-02-26 09:15:24
Is it a simple case of draining fluid via dipstick and then refilling or is there a drain plug? Going to purchase an evacuation pump and some oil on payday to change mine
