New engine top bush phase 2
Post 582595 by Harvey on 2013-03-09 21:38:15
Just came accross this new square top engine bush in poly http://www.google.co.uk/url?sa=t&rct=j&q=PFV907987&source=web&cd=1&ved=0CDQQFjAA&url=http%3A%2F%2Fwww.partsforvolvosonline.com%2Fproduct_info.php%3FcPath%3D2_546_385_389%26products_id%3D7986&ei=las7UYfKKYjb7Ab16IFw&usg=AFQjCNGyyFltH9CF86kbdUpdUAlJKo0drg S70/C70/S60/S80/V70/XC90 Petrol Upper Engine Mount Bush (Cross Shape) To fit: S60 2001-2009 S80 2001-2006 V70 inc XC 2002-2008 XC90 2003 onwards  S70 1999-2000 V70 1999-2000 C70 1999-2005 The cross shape bush is designed for the later style of Volvo housing, which replaces the earleir round version. Image shows bush insert with original housing for reference, bush insert only is supplied Equivalent original Volvo part numbers: 30680770 (for reference only) Ref: PFV907987
Post 582601 by JamesT5 on 2013-03-09 21:45:18
[QUOTE=Harvey;582595]Just came accross this new square top engine bush in poly http://www.google.co.uk/url?sa=t&rct=j&q=PFV907987&source=web&cd=1&ved=0CDQQFjAA&url=http%3A%2F%2Fwww.partsforvolvosonline.com%2Fproduct_info.php%3FcPath%3D2_546_385_389%26products_id%3D7986&ei=las7UYfKKYjb7Ab16IFw&usg=AFQjCNGyyFltH9CF86kbdUpdUAlJKo0drg S70/C70/S60/S80/V70/XC90 Petrol Upper Engine Mount Bush (Cross Shape) To fit: S60 2001-2009 S80 2001-2006 V70 inc XC 2002-2008 XC90 2003 onwards  S70 1999-2000 V70 1999-2000 C70 1999-2005 The cross shape bush is designed for the later style of Volvo housing, which replaces the earleir round version. Image shows bush insert with original housing for reference, bush insert only is supplied Equivalent original Volvo part numbers: 30680770 (for reference only) Ref: PFV907987[/QUOTE] Yes, Parts For Volvos posted a thread about this already, yesterday. The price looks good too!
Post 582653 by Wobbly Dave on 2013-03-09 23:21:31
I am sending PFV a spare so they can fit the new bush & post instructions. http://www.vpcuk.org/forums/showthread.php?49410-Powerflex-Upper-Engine-Mount-Bushes-1999-onwards-Cross-Square-Shape-Now-Available
Post 582671 by Harvey on 2013-03-10 07:44:05
Is there any feedback what the noise level is like yet.
Post 582791 by Wobbly Dave on 2013-03-10 15:21:35
[QUOTE=Harvey;582671]Is there any feedback what the noise level is like yet.[/QUOTE] Give us chance! - I haven't managed to send them the unit yet LOL!!
Post 582819 by Harvey on 2013-03-10 17:03:48
[QUOTE=Wobbly Dave;582791]Give us chance! - I haven't managed to send them the unit yet LOL!![/QUOTE] No no I ment from the makers of the bush,they must have fitted it to see what it was like. I have a old alu bracket and might try ( buy ) one if the noise level is not changed to much.
Post 582937 by volvokid on 2013-03-10 21:16:34
Lee has it on his, and prefers it to the yellow poly mount, a lot less vibration but still has a bit of grunt to it.
Post 582969 by Harvey on 2013-03-10 21:47:07
[QUOTE=volvokid;582937]Lee has it on his, and prefers it to the yellow poly mount, a lot less vibration but still has a bit of grunt to it.[/QUOTE] I know the round bush kit has been around for a long time,I changed the one on my motor for a volvo one again as there was not a poly one that fitted as its the square type mount.
Post 584695 by LeeT5 on 2013-03-16 01:44:03
I like the idea of this poly mount as it looks like it would fit better and work better than the yellow round type, which after about 6 months starts to chew itself up and tear. Looks good too! i may consider getting one. I take it you have to cut out your oe black bush to fit? Or do they supply the bracket? Never tried removing black square bush so i wouldn't know.
Post 584758 by jotter22 on 2013-03-16 07:33:31
Looking at Wobblys square rubber bush it is held in with 2 large plates i cant see it needing a lot of work to get it out if they think that is needed to keep it in place Tony.
Post 584775 by Harvey on 2013-03-16 09:06:15
On my old mount bush it just fell it bits when I renewed it,still have the old alu bracket so might give one of them a go when I hear a bit of feed back.
Post 584776 by jotter22 on 2013-03-16 09:10:06
it should have a plastic sleeve inside the bracket that was attached to the rubber...I have just removed the rubber remains from my old one. Tony.
