6 speed gear upgrade
Post 585425 by T5frankie on 2013-03-17 17:41:23
this has been done before
Post 585426 by JT on 2013-03-17 17:41:51
nice work :)
is the extra gear high or low?
Post 585427 by oblark on 2013-03-17 17:42:32
[QUOTE=T5frankie;585425]this has been done before[/QUOTE]
And ..............
Post 585430 by oblark on 2013-03-17 17:44:21
[QUOTE=JT;585426]nice work :)
is the extra gear high or low?[/QUOTE]
6th gear is 0.65 to 1, the m56 box 5th gear is 0.77 to 1
Post 585431 by M-R-P on 2013-03-17 17:44:32
Sweet mate, does it have volvo stamped on the housing?
Post 585432 by oblark on 2013-03-17 17:45:11
[QUOTE=M-R-P;585431]Sweet mate, does it have volvo stamped on the housing?[/QUOTE]
Of course :)
Post 585434 by theflyingbrick on 2013-03-17 17:46:45
this could be a very good upgrade especially when it comes to motorway driving,i reckon its gonna save a few quid on petrol with an extra gear,how long before your driving it?? be good to know the results ;)
Post 585437 by JT on 2013-03-17 17:52:02
[QUOTE=oblark;585430]6th gear is 0.65 to 1, the m56 box 5th gear is 0.77 to 1[/QUOTE]
dam n blast! lol
I need a low range box then......:(
Post 585438 by p fandango on 2013-03-17 17:53:13
M56H is 0.70:1, the Volvo M66 also has a 0.70:1. Whats the FDR on the Crocus box?
Post 585439 by p fandango on 2013-03-17 17:56:13
& according to HERE the Crocus is also 0.70:1 with a 4.0 FDR, exactly the same as 5th on the T-5
Post 585440 by stribo on 2013-03-17 17:57:04
Glad it's fitted up O.K. mate.
Post 585441 by oblark on 2013-03-17 18:01:35
[QUOTE=p fandango;585439]& according to HERE the Crocus is also 0.70:1 with a 4.0 FDR, exactly the same as 5th on the T-5[/QUOTE]
http://www.focusstoc.com/forums/topic/47711-confirmation-of-gear-ratios/
Post 585445 by p fandango on 2013-03-17 18:08:39
[QUOTE=oblark;585441]http://www.focusstoc.com/forums/topic/47711-confirmation-of-gear-ratios/[/QUOTE]
2009, seems longer ago than that lol. My mistake about the 4.00 FDR, i was looking at the M66W (which does have the 0.65:1 on 6th)
Post 585461 by nottsgreent5 on 2013-03-17 19:04:28
Dont quote me on this but think someone told me a while ago later v70/s60 fitted with the six spees boxes linkage will fit the 850 shift assembly
Post 585462 by oblark on 2013-03-17 19:09:24
[QUOTE=nottsgreent5;585461]Dont quote me on this but think someone told me a while ago later v70/s60 fitted with the six spees boxes linkage will fit the 850 shift assembly[/QUOTE]
Thanks for that, I`ll look into it :)
Post 585469 by Nealevo on 2013-03-17 19:28:04
I'm pretty gutted now, I had a complete ST which had been vandal damaged, I wanted the 18s and seats, looked into the gearbox fitting and was told it wouldn't fit, scrapped the whole car :(
Post 585504 by oblark on 2013-03-17 22:00:08
Found this on a ford forum about m66 gear ratio`s
Post No. 4
http://www.volvocarclubsa.co.za/viewtopic.php?t=3300&p=54726
Post 585506 by Kingsford G on 2013-03-17 22:14:35
Interestng upgrade,keep us posting mate.
Post 585507 by merc85 on 2013-03-17 22:16:41
Awesome mate, good luck with the build, looking smart
Post 585509 by p fandango on 2013-03-17 22:23:43
[QUOTE=oblark;585504]Found this on a ford forum about m66 gear ratio`s
Post No. 4
http://www.volvocarclubsa.co.za/viewtopic.php?t=3300&p=54726[/QUOTE]
i'm not convinced he's got his numbers right, the Volvo ratios he's quoting are for the M66W yet with the FDR of the M66. He also says the F*rd box has 4.00 FDR
Post 585510 by p fandango on 2013-03-17 22:29:01
M66 (S60R AWD)
FDR = 3.77:1
1st = 3.38:1
2nd = 2.05:1
3rd = 1.43:1
4th = 1.08:1
5th = 0.86:1
6th = 0.70:1
top speed = 182mph
M66W (T-5)
FDR = 4.00:1
1st = 3.39:1
2nd = 1.91:1
3rd = 1.27:1
4th = 0.95:1
5th = 0.78:1
6th = 0.65:1
top speed = 185mph
M66D (D-5)
FDR = 4.00:1
1st = 3.39:1
2nd = 1.91:1
3rd = 1.19:1
4th = 0.84:1
5th = 0.65:1
6th = 0.54:1
top speed = 223mph
Post 585515 by Harvey on 2013-03-17 23:03:54
Found this in my book
[/IMG]
Post 585534 by GregE102 on 2013-03-18 00:32:17
I have an M66 T5 fitted and working with mine now, Tim Williams did it all for me but he did have to make a custom linkage to make it work correctly!
Post 585574 by oblark on 2013-03-18 10:50:53
[QUOTE=p fandango;585510]M66 (S60R AWD)
FDR = 3.77:1
1st = 3.38:1
2nd = 2.05:1
3rd = 1.43:1
4th = 1.08:1
5th = 0.86:1
6th = 0.70:1
top speed = 182mph
M66W (T-5)
FDR = 4.00:1
1st = 3.39:1
2nd = 1.91:1
3rd = 1.27:1
4th = 0.95:1
5th = 0.78:1
6th = 0.65:1
top speed = 185mph
M66D (D-5)
FDR = 4.00:1
1st = 3.39:1
2nd = 1.91:1
3rd = 1.19:1
4th = 0.84:1
5th = 0.65:1
6th = 0.54:1
top speed = 223mph[/QUOTE]
Should have got a m66d box 223mph ;)
Post 585576 by p fandango on 2013-03-18 10:58:43
[QUOTE=oblark;585574]Should have got a m66d box 223mph ;)[/QUOTE]
The TDi 5cog I've got does 203mph@6500rpm
Post 585683 by Brett855tdi on 2013-03-18 20:20:37
I bet the d5 box would be good for mpg, but i also guess it would be too long for a t5.
I take it the M66w and M66D are the same box just different ratios, and the d5 box would fit?
what cars were the M66w fitted to?
Post 585686 by p fandango on 2013-03-18 20:27:52
[QUOTE=Brett855tdi;585683]I bet the d5 box would be good for mpg, but i also guess it would be too long for a t5.
what cars were the M66w fitted to?[/QUOTE]
S60 t-5
Post 585844 by lance on 2013-03-19 07:59:37
I love the 6 speed box in my v50 t5 same as the focus 70 mph = 2400 rpm so better mpg, plus when you have had 6 gears going back to a 5 is like going back to a 4 your always looking for the extra gear that's not there!
Post 590933 by claymore on 2013-03-31 20:26:20
What's different about the rear mount?
Post 590947 by oblark on 2013-03-31 20:40:46
The M56 will not fit on the M66 box, and the M66 mount will not fit under the turbo
Post 591024 by Wobbly Dave on 2013-03-31 21:32:10
How are you going to get around the reverse gate problem?
Post 591028 by oblark on 2013-03-31 21:36:10
[QUOTE=Wobbly Dave;591024]How are you going to get around the reverse gate problem?[/QUOTE]
What reverse gate problem ?
Post 591036 by Wobbly Dave on 2013-03-31 21:48:41
To engage the reverse gear (up & far left) on the 6 speed manual you have to push the lever down before you can get it. It sits adjacent to 1st.
That gate protection is on the stick/selector AFAIK. Without it I am fairly sure you can select reverse whilst moving forward (unlikely) or more likely select reverse, when setting off.
Post 591044 by oblark on 2013-03-31 21:54:43
[QUOTE=Wobbly Dave;591036]To engage the reverse gear (up & far left) on the 6 speed manual you have to push the lever down before you can get it. It sits adjacent to 1st.
That gate protection is on the stick/selector AFAIK. Without it I am fairly sure you can select reverse whilst moving forward (unlikely) or more likely select reverse, when setting off.[/QUOTE]
On the box I`ve got reverse is over by 5th and 6th
1 3 5
2 4 6 R
Post 591049 by Wobbly Dave on 2013-03-31 21:56:30
Must be different to the one on my diesel s40 then. I thought they were all
R 1 3 5
_ 2 4 6
not that I was trying to throw a spanner in the works, just more of a heads up.
Post 591252 by stribo on 2013-04-01 00:25:35
The R has the same layout as Rob's, i.e. with reverse next to 6th
Post 591333 by lance on 2013-04-01 10:10:36
Yeah the 2.0d and t5 use a different pattern
Post 599144 by oblark on 2013-04-21 21:48:30
Made the most of the weather on Saturday and knocked up the rear engine/gearbox mount
The next job will be to make a new downpipe :)
Post 599149 by MA'R'K on 2013-04-21 21:56:01
Interesting project.....gearbox will probably be my next build, so watching closely ;)
Post 613534 by oblark on 2013-06-04 20:37:57
Finally finished the gear linkage bracket off and fitted it tonight :)
Here`s a short video of me going up through the gears
[video=youtube;HixuAz5iZug]http://www.youtube.com/watch?feature=player_detailpage&v=HixuAz5iZug[/video]
Post 613859 by GregE102 on 2013-06-05 19:50:52
You will Love it! I love my 6 speed box they are great!
Post 613868 by cherry1809 on 2013-06-05 20:17:39
Also looking at doing the same. Good write up :)
Post 613885 by Biff on 2013-06-05 20:50:14
I'd love to carry this conversion off.
Nice handy work fella.
Post 624625 by oblark on 2013-07-11 20:23:01
Got bored at work today so I made these............................ some brass linkage bushes.
Post 624632 by graemewelch on 2013-07-11 20:46:03
nice touch. wish i could do a bit turning and milling
Post 642666 by jdavis on 2013-09-09 14:20:42
good work there!
Post 642672 by Tomcat on 2013-09-09 14:29:58
Awesome write up, looking forward to seeing it finished, then I can go find one for myself,lol.
Post 642677 by M-R-P on 2013-09-09 15:18:08
[QUOTE=oblark;624625]Got bored at work today so I made these............................ some brass linkage bushes.
[/QUOTE]
The brass bush kit for the Toyota MR2 is a direct fit if anybody's looking to replace their bushes (a good idea when fitting the short-shift kit)
Post 642679 by Tomcat on 2013-09-09 15:24:51
Where's the short shift kit available from?
Post 642681 by M-R-P on 2013-09-09 15:28:43
I think IPD do one. There may be one or two of mine floating about somewhere but I don't have any.
Post 642682 by oblark on 2013-09-09 15:34:29
[QUOTE=M-R-P;642677]The brass bush kit for the Toyota MR2 is a direct fit if anybody's looking to replace their bushes (a good idea when fitting the short-shift kit)[/QUOTE]
The mr2 bush cost money and mine cost nothing :)
Post 651520 by charlie-r on 2013-10-10 20:12:47
[QUOTE=M-R-P;642681]I think IPD do one. There may be one or two of mine floating about somewhere but I don't have any.[/QUOTE]
Got any pics of the ones you (used to) do? Tried hunting but can't see any if you don't mind of course :) cheers.
Post 651528 by M-R-P on 2013-10-10 20:32:33
[QUOTE=charlie-r;651520]Got any pics of the ones you (used to) do? Tried hunting but can't see any if you don't mind of course :) cheers.[/QUOTE]
Maybe Stribo, Nordic or TheFlyingBrick can post a pic.
V70Graham might have had a pic on his "relentless pursuit of perfection" thread.
Post 651531 by stribo on 2013-10-10 20:45:17
I haven't got a pic of mine. :(
Post 651580 by Tomcat on 2013-10-10 23:05:31
Wouldn't mind a short shift kit, fancy making some more?
Post 651584 by M-R-P on 2013-10-10 23:14:57
[QUOTE=stribo;651531]I haven't got a pic of mine. :([/QUOTE]
go and take one then.
lazy git :)
Post 651586 by M-R-P on 2013-10-10 23:17:23
[QUOTE=Tomcat;651580]Wouldn't mind a short shift kit, fancy making some more?[/QUOTE]
I'll look for the pattern I was working on for the 2nd version of the plate.
no promises tho.
Post 651587 by theflyingbrick on 2013-10-10 23:18:26
yeah short shift kit mmmmmmmmmmmmmmm its tasty :redface: sorry haven't got any pics
back on topic....I love the linkage pics your work is outstanding mate :)
Post 651588 by M-R-P on 2013-10-10 23:30:31
Lazy gits...
Here's a pic of Graham's plate, now on Stribo's car...
