Post 588092 by JamesT5 on 2013-03-24 12:13:21
I thought I'd do another "How To" thread, this time how to remove the D.I.M (Instrument Cluster) from a Phase 2 V70. This is a nice simple job that just about anyone can do.
Tools
[LIST]
[*]Flat Headed Screw Driver
[/LIST]
[LIST]
[*]Torx 25 Driver
[/LIST]
METHOD
[LIST]
[*]Firstly, disconnect the negative battery terminal. Go back to the drivers seat and tilt the steering wheel down so it's in its lowest position, this gives you more room during to do the job.
[/LIST]
[LIST]
[*]Next, take a flat headed screw driver, place it between the plastic instrument cluster trim and the dashboad dome and gently prise off the plastic trim, starting at the top and then doing the same at the bottom (see photos).
[/LIST]
[LIST]
[*]Now take the screwdriver and gently prise the two piece of steering column trim apart from both sides so that the top piece is free (see photos).
[/LIST]
[LIST]
[*]Lift the instrument cluster surround and steering column trim piece out together (they are joined together by a piece of vinyl/faux leather so they'll come out together)
[/LIST]
[LIST]
[*]Next, look at the instrument cluster and using your Torx 25 driver, remove the 4 Torx 25 screws at each corner that are holding the unit in as seen in the photos below.
[/LIST]
[LIST]
[*]Once all 4 Torx 25 screws are out, you need to put your hand on the top of the instrument cluster and tilt it forward as seen in the photo below.
[/LIST]
[LIST]
[*]Now look at the back of the instrument cluster and you will see a big green electrical connector, disconnect this and then the instrument cluster can simply be lifted out.
[/LIST]
That's it, the DIM is out and now you can send it for repair or replace it with that new overpriced one from the dealers, it's entirely up to you. In my case, I've just taken mine out to show you how it all comes out, a nice easy job for anyone!
Any questions, please ask.
Regards
James
Post 588137 by Harvey on 2013-03-24 15:27:52
I think the next easy job you should show us is.....................................................how to fit a LSD.
That would be a nice long read.
Nice to see you are getting more confident to work on your car.
Post 588140 by JamesT5 on 2013-03-24 15:36:21
[QUOTE=Harvey;588137]I think the next easy job you should show us is.....................................................how to fit a LSD.
Nice to see you are getting more confident to work on your car.[/QUOTE]
Errrrrr, let me think......... if you're referring to a Limited-Slip Differential then no, Gearbox issues are going to a specalist. But thanks for the vote of confidence all the same. :B_thumb:
Alot of this is just down to pure necessity and cost cutting but there are some jobs that no matter how limited I am on funds, I will never tackle myself. I won't do brakes on a daily runner nor suspension/steering related stuff other than perhaps changing the droplinks or something of that nature.
I seem to be ok with 'modules' or stuff like that, but anything that keeps the car from hitting the tarmac is definatley a no for me. :D :nono:
Post 588547 by stephenevans99 on 2013-03-25 12:32:25
Love these 'How To' threads with decent pics....makes it so easy to follow & understand the procedure.
:B_thumb:
Post 588567 by JamesT5 on 2013-03-25 14:51:11
[QUOTE=stephenevans99;588547]Love these 'How To' threads with decent pics....makes it so easy to follow & understand the procedure.
:B_thumb:[/QUOTE]
Thanks, I actually enjoy doing them although for the more experienced on the forum they probably are less useful than they are for people like myself who struggle with the more basic tasks. My "How To" guides are aimed more at the beginner level hence some of the 'how to suck eggs' instructions in there.
But that said, I'm glad you like them and I'm sure someone will find them useful which is why i did them. I've also got a record that I can refer to if I forget anything in the future.
Post 588571 by p fandango on 2013-03-25 15:01:03
[QUOTE=JamesT5;588567]Thanks, I actually enjoy doing them although for the more experienced on the forum they probably are less useful than they are for people like myself who struggle with the more basic tasks. My "How To" guides are aimed more at the beginner level hence some of the 'how to suck eggs' instructions in there.[/QUOTE]
i find them very usefull, i tend to be more 850 based so everything i do for the S60 is looked up then forgotten about. Especially as i keep threatening to get the bulbs replaced on the DIM
Post 588578 by JamesT5 on 2013-03-25 15:28:50
[QUOTE=p fandango;588571]i find them very usefull, i tend to be more 850 based so everything i do for the S60 is looked up then forgotten about. Especially as i keep threatening to get the bulbs replaced on the DIM[/QUOTE]
Once the DIM is out, the bulbs are easy as they are just those twist in ones like minture versions of a brake lamp. :)
Post 588582 by M-R-P on 2013-03-25 15:35:41
[QUOTE=JamesT5;588578]Once the DIM is out, the bulbs are easy as they are just those twist in ones like minture versions of a brake lamp. :)[/QUOTE]
They're T5 wedge bulbs (oh the irony) and you need to use tape to remove them from the twisty-holder-thingy.
Personally, I wouldn't bother Pedro... You risk upsetting your repaired dim :(
Post 588585 by JamesT5 on 2013-03-25 15:38:48
[QUOTE=M-R-P;588582]They're T5 wedge bulbs (oh the irony) and you need to use tape to remove them from the twisty-holder-thingy.
Personally, I wouldn't bother Pedro... You risk upsetting your repaired dim :([/QUOTE]
Sorry but I have to disagree, I was able to pull bulbs are reinstall them at random, provided you put a grey bulb in a slot labelled grey, and a blue bulb in a slot labelled blue. :)
Post 588587 by p fandango on 2013-03-25 15:43:39
got a feeling we just replaced the whole bulb including the plastic holder when we did my old mans (might be why they were so dear). I've got to get my engineer to sort his previous mistake & get the righthand side of the cluster working so i change them then
Post 588588 by M-R-P on 2013-03-25 15:46:17
You were able to pull the bulb from its black, blue or grey holder by hand James?
Getting them out of the dim is easy but getting the glass bit out of the plastic bit (the only way to change them to led) requires wrapping the bulb with tape.
I have a how-to on my led conversation thread iirc.
Post 588590 by JamesT5 on 2013-03-25 15:53:41
[QUOTE=M-R-P;588588]You were able to pull the bulb from its black, blue or grey holder by hand James?
I have a how-to on my led conversation thread iirc.[/QUOTE]
Changing the bulbs over like for like is easy, they're designed to be changed from the back of the unit and are swapped over like a brake light bulb.
Post 588591 by M-R-P on 2013-03-25 16:07:03
[QUOTE=JamesT5;588590]Changing the bulbs over like for like is easy, they're designed to be changed from the back of the unit and are swapped over like a brake light bulb.[/QUOTE]
I think you're missing my point mate - like for like is easy, as you say, it just twists in but to upgrade the bulb, you need to remove it from the dim and pull the glass bit from the plastic bit.
