boost???
Post 49551 by mike 850 on 2005-10-13 16:03:57
hi, got a bit of a prob, got a 95 850 t5, ive fitted a mbc and boost gauge, the prob is the boost will quickly rise to aroun .6 bar but then drop down to around .4, adjustin the mbc doesnt seem to be making any difference, could this be a boost leak? where do i start first, eg the pipes connected to the mbc? thanks in advance
Post 49553 by Unknown on 2005-10-13 16:19:55
[QUOTE=mike 850]hi, got a bit of a prob, got a 95 850 t5, ive fitted a mbc and boost gauge, the prob is the boost will quickly rise to aroun .6 bar but then drop down to around .4, adjustin the mbc doesnt seem to be making any difference, could this be a boost leak? where do i start first, eg the pipes connected to the mbc? thanks in advance[/QUOTE] Standard T5s should be .8 bar from memory. Do you have this problem without the MBC ?
Post 49555 by spesh on 2005-10-13 16:23:31
.8 of a bar seems a bit high for standard boost, the t4's run that standard but im sure the T5's are more like 7 so .5.
Post 49556 by Unknown on 2005-10-13 16:25:06
[QUOTE=spesh].8 of a bar seems a bit high for standard boost, the t4's run that standard but im sure the T5's are more like 7 so .5.[/QUOTE] T5R is .8 as standard I know that much. 1.2 with 15t rica 1.3 with 19t rica
Post 49557 by Al115 on 2005-10-13 16:26:49
My V70 1999 should have been 0.7bar / 10psi as stock.
Post 49560 by volvotuning on 2005-10-13 16:33:51
Most standard 850 T5s run around 0.5 to 0.6 bar. Adam.
Post 49567 by mike 850 on 2005-10-13 16:49:10
before the mbc it would go up to .6 bar, when i first put the mbc on i set it on .8 and it stayed there to the redline , now it seems to drop off? it does seem to sound louder( rushing air) but not sure if thats coz of the k&n
Post 49606 by Lee-J-T5 on 2005-10-13 18:50:34
My 96 T5 always boosted to 0.5 bar as standard, I fitted the gauge before the MBC. Now it goes up to 1 bar and settles at 0.9 pulling like a train
Post 49614 by craig on 2005-10-13 19:02:57
check your hoses arent too long or too soft cos this will cause that to happen also what type did you get and are the hoses held on securely and not leaking .if you post a picture that might help
Post 49677 by mike 850 on 2005-10-13 22:28:32
just to update, i am a TOTAL tw@t :) , after changing all the vacum hoses to the mbc, i realised that where i mounted the mbc i taped some foam around to cusion it from rubbing against the intake hose :slap: :slap: this totally blocked the pin hole on the end of the mbc, took this off and now its back to .9 bar and holds all the way :B_steerin , all i can say is im an idiot but im so pleased i found out what the prob was!! thanks for all the help
Post 49695 by Unknown on 2005-10-13 23:22:16
Well it's all a learning experience. I'm glad you got it all sorted.
